ESP32 HID Keyboard USB
Hi, is it possible to use ESP32 (any ESP32 dev. kit) as HID keyboard with a help of Arduino Keyboard library or other when connected via USB to PC? Similarly to Arduino Leonardo, Zero...
Re: ESP32 HID Keyboard USB
HiHi, is it possible to use ESP32 (any ESP32 dev. kit) as HID keyboard with a help of Arduino Keyboard library or other when connected via USB to PC? Similarly to Arduino Leonardo, Zero...
you could connect to esp32 pins USB HID controller
also you could use V-USB ..
last but not least, you can use instead CP.. IC an cheap USB IC which support USB Serial, USB HID and so on,
what ever you need in the moment.
the comming new ESP32-S2 support USB itself, not sure when it comes out, but we get native USB on ESP in near time.
hope this helps
rudi
edit:
further info:
ESPUSB32 Full-speed USB Approach
ESPUSB
ESPUSB ESP32?
Angeliccare
Arduino versions are out for S2.
https://gist.github.com/brgaulin/2dec28 ... 354adf103d
https://github.com/chegewara/EspTinyUSB ... yboard.ino
https://github.com/cyborg5/TinyUSB_Mouse_and_Keyboard
Arduino-> ESP-IDF component versions.
None yet.
ESP-IDF versions:
none yet.
Looking for 2nd two of them.
None yet.
ESP-IDF versions:
none yet.
Users browsing this forum: coccocbot, PerplexityBot and 6 guests
