gpio_matrix_in or gpio_matrix_out vs. gpio_set_direction
Postby rudi ;-) » Sat Mar 11, 2017 10:24 am
hi guys
honest, have thinked
gpio_matrix_out(PIN_SMI_MDIO, EMAC_MDO_O_IDX, 0, 0);
gpio_matrix_in(PIN_SMI_MDIO, EMAC_MDI_I_IDX, 0);
set the Direction BIT of the GPIO
in this example MDIO is in and output
https://esp32.com/viewtopic.php?f=12&p=6422#p6401
? we need to set the BIT again for input with
https://esp32.com/viewtopic.php?f=12&p=6422#p6418
gpio_set_direction(PIN_SMI_MDIO, GPIO_MODE_INPUT);
Re: gpio_matrix_in or gpio_matrix_out vs. gpio_set_direction
Postby rudi ;-) » Wed Mar 15, 2017 9:27 am
hi guys
sry for the push
but for me this is honest not clear 100 procent
igrr
Postby igrr » Wed Mar 15, 2017 1:59 pm
No, gpio_matrix_in doesn't set input enable. It only writes to the GPIO_FUNCx_IN_SEL_CFG_REG register.
Postby rudi ;-) » Wed Mar 15, 2017 3:04 pm
ok,
i must ask again:
here in this example: GPIO18
https://github.com/espressif/esp-idf/bl ... main.c#L42
is used for MDIO
https://github.com/espressif/esp-idf/bl ... ain.c#L138
why we need not use
that the pin is input mode
if we use example gpio32 or 33
we need explizite to use
that the gpio32 or gpio33 is in INPUT mode too.
https://esp32.com/viewtopic.php?f=12&t= ... 6508#p6458
is mean GPIO_FUNCx_IN_SEL_CFG_REG is not valid for "GPIO MODE" that then is used for FUNC set pin?
other words:
if we use other function of GPIO as there is named as "FUNC" PIN "NAME"
( use function1 gpio )
then we need to use the GPIO API for set it as INPUT pin by using gpio_set_direction too?
igrr
Postby igrr » Thu Mar 16, 2017 8:23 am
I think the difference you see between GPIO18 and GPIO32 is that GPIO18 has "input enable" bit set by default, while GPIO32 has this bit cleared when it gets configured as an XTAL input pin during startup. This is why you need to set "input enable" for GPIO32 explicitly.
Postby rudi ;-) » Thu Mar 16, 2017 8:39 am
now is clear.
thank you.
Users browsing this forum: PerplexityBot, Semrush [Bot] and 2 guests
