[solved]convert mode selector to espNOW
sebasdt
Postby sebasdt » Sat Oct 17, 2020 2:05 pm
The idea behind this is:
I have made a Led matrix and want to "easily" change modes or set a value something, another person has done this(diod-dev https://github.com/Diod-dev/New_Visualizer_Skeleton) but it's done with serial communication and not espnow
The slave esp32 reads and acts on incoming messages from the master esp32, in the format of '< (letter) (3 digit number) >'.
For example, I would like to set the brightness to 50% then would send <B128>.
here are the example codes:
master
void setup{
Serial.begin(115200); // Serial monitor output
  Serial2.begin(115200);
  pinMode(ledPin, OUTPUT);
void loop() {
int updateCurrentBrightness() {
  currentBrightness = inputMasterBrightness.toInt();
  return currentBrightness;
void sendRequest(int req) {
  switch (req) {
  case 0:
    currentMode = req;
    Serial2.write('<');
    Serial2.write('f');
    Serial2.write('0');
    Serial2.write('0');
    Serial2.write('0');
    Serial2.write('>');
    break;
  case 1:
    currentMode = req;
    Serial2.write('<');
    Serial2.write('o');
    Serial2.write('0');
    Serial2.write('0');
    Serial2.write('0');
    Serial2.write('>');
    break;
  case 2:
    currentMode = req;
    Serial2.write('<');
    Serial2.write('s');
    for (int i = 0; i < inputHue.length(); i++) {
      Serial2.write(inputHue[i]);
    Serial2.write('>');
    break;
  case 3:
    currentMode = req;
    Serial2.write('<');
    Serial2.write('t');
    for (int i = 0; i < inputSat.length(); i++) {
      Serial2.write(inputSat[i]);
    Serial2.write('>');
    break;
  case 4:
    currentMode = req;
    Serial2.write('<');
    Serial2.write('b');
    for (int i = 0; i < inputVal.length(); i++) {
      Serial2.write(inputVal[i]);
    Serial2.write('>');
    break;
  case 5:
    currentMode = req;
    sendMVMode(req);
    break;
  case 6:
    currentMode = req;
    sendMVMode(req);
    break;
  case 7:
    currentMode = req;
    sendMVMode(req);
    break;
  case 8:
    currentMode = req;
    sendMVMode(req);
    break;
  case 9:
    currentMode = req;
    sendMVMode(req);
    break;
  case 10:
    currentMode = req;
    sendMVMode(req);
    break;
  case 11:
    currentMode = req;
    sendMVMode(req);
    break;
  case 12:
    currentMode = req;
    sendMVMode(req);
    break;
  case 13:
    currentMode = req;
    sendMVMode(req);
    break;
  case 14:
    currentMode = req;
    sendMVMode(req);
    break;
  case 15:
    currentMode = req;
    sendMVMode(req);
    break;
  case 16:
    currentMode = req;
    sendMVMode(req);
    break;
  case 17:
    currentMode = req;
    sendAmbMode(req);
    break;
  case 18:
    currentMode = req;
    sendAmbMode(req);
    break;
  case 19:
    currentMode = req;
    sendAmbMode(req);
    break;
  case 20:
    currentMode = req;
    sendAmbMode(req);
    break;
  case 21:
    currentMode = req;
    sendAmbMode(req);
    break;
  case 22:
    currentMode = req;
    sendAmbMode(req);
    break;
  case 23:
    //currentMode = req;
    Serial2.write('<');
    Serial2.write('z');
    for (int i = 0; i < inputMasterBrightness.length(); i++) {
      Serial2.write(inputMasterBrightness[i]);
    Serial2.write('>');
    break;
  case 98:
    currentMode = req;
    Serial2.write('<');
    Serial2.write('x');
    Serial2.write('0');
    Serial2.write('0');
    Serial2.write('0');
    Serial2.write('>');
    break;
  case 99:
    Serial2.write('<');
    Serial2.write('y');
    for (int i = 0; i < inputAudioMultiplier.length(); i++) {
      Serial2.write(inputAudioMultiplier[i]);
    Serial2.write('>');
    break;
void sendMVMode(int req) {
  currentMode = req;
  Serial2.write('<');
  Serial2.write('m');
  sendMode = currentMode - 4;
  sendModeStr = (String)sendMode;
  for (int i = 0; i < sendModeStr.length(); i++) {
    Serial2.write(sendModeStr[i]);
  Serial2.write('>');
void sendAmbMode(int req) {
  currentMode = req;
  Serial2.write('<');
  Serial2.write('a');
  sendMode = currentMode - 16;
  Serial2.write('>');
slave
// This file handles all incoming messages from ESP-32
// Reads and acts on incoming messages from ESP - 32, in the format of '< (letter) (3 digit number) >'. For exmaple, <b200>
// Variables for solid color
uint8_t solidHue = 0;
uint8_t solidSat = 255;
uint8_t solidVal = 255;
const byte numChars = 10;
char receivedChars[10];
char tempChars[3];
// TODO: use 'categories' instead of letters.
// variables to hold parsed data
//char category[1] = { 0 };
//int instruction = 0;
bool newCommand = false;
int audioMultiplier; // temp input variable before recording this input in variable 'mult'
void setup{
void doThingsWithCommands() {
  if (receivedChars[0] == 'a') { // Chooses an ambient pattern and displays it
    for (int i = 0; i < 3; i++) // Record the next 3 characters (numbers) to a holding string 'tempChars'
      tempChars[i] = receivedChars[i + 1];
    ambPattern = atoi(tempChars); // convert 'tempChars' to integer.
    patternMode = 3; // Used in normalOperation()
    Serial.println(ambPattern);
  else if (receivedChars[0] == 'b') {  // Sets the brightness when displaying a solid color
    patternMode = 4; // Used in normalOperation() to display a solid color
    solidVal = atoi(tempChars); // 'atoi' converts string of characters to integer
  else if (receivedChars[0] == 'f') { // The off button is set, last pattern mode is saved.
    patternModeOld = patternMode;
    patternMode = 0; // Used in normalOperation() to turn all LEDs off
  else if (receivedChars[0] == 'm') { // Chooses a music-visualizing pattern and displays it
    MVPattern = atoi(tempChars);
    patternMode = 2; // Used in normalOperation() to display a single music-visualizing pattern
    Serial.println(patternMode);
  if (receivedChars[0] == 'o') {
    Serial.println(patternModeOld);
    patternMode = patternModeOld; // Used in normalOperation(), returns to last patternMode
  else if (receivedChars[0] == 's') {
    solidHue = atoi(tempChars);
  else if (receivedChars[0] == 't') {
    solidSat = atoi(tempChars);
  else if (receivedChars[0] == 'x') {
    patternMode = 1; // Used in normalOperation() to enter mode of changing music-visualization patterns to the music
  else if (receivedChars[0] == 'y') {
    audioMultiplier = atoi(tempChars);
    mult = (double)audioMultiplier / 100;
  else if (receivedChars[0] == 'z') {
    masterBrightness = atoi(tempChars);
  else {}
// Reads incoming message from ESP-32, in the format of '< (letter) (3 digit number) >'. For exmaple, (<b200>)
void recWithStartEndMarkers() {
  static boolean recInProgress = false; // is a message currently being received?
  static byte ndx = 0; // index variable as receivedChars[] array populates
  char startMarker = '<'; // the first character sent by ESP-32 in a message
  char endMarker = '>'; // the last character sent by ESP-32 in a message
  char rc; // rc = each character as it comes in
  // While serial1 data is available and newCommand == false (the endMarker '>' hasn't been received yet)
  while (Serial1.available() && newCommand == false) {
    rc = Serial1.read(); // rc = new incoming character
    if (recInProgress == true) {
      if (rc != endMarker) {
        receivedChars[ndx] = rc;
        ndx++;
        //if (ndx >= numChars) // THESE 2 LINES FUCK UP THE LEDS
        //  ndx = numChars - 1;
      else {
        receivedChars[ndx] = '\0';
        ndx = 0;
        newCommand = true;
    else if (rc == startMarker)
      recInProgress = true;
    else {}
void parseData() {
  if (newCommand == true) {
    for (int i = 0; i < 4; i++)
      Serial.print(receivedChars[i]);
    Serial.println();
    doThingsWithCommands();
    newCommand = false;
void talkToESP() {
  recWithStartEndMarkers(); // constantly looking out for new messages
  parseData(); // after a message is received, act on it
Re: mode selector convert espNOW
Postby ESP_Sprite » Sun Oct 18, 2020 3:00 am
Okay; do you have a question?
sebasdt
Postby sebasdt » Sun Oct 18, 2020 9:35 am
oh sorry, I thought that I added the questions.
but anyway, I want to convert the code I provided from serial communication to espNOW.
what need to know if it's possible to send the format or characters (<b000>) via espNOW and how.
what would be the max number that I could send with espnow?
an idea I had was that you put the "ready to send format" in a char or string array and somehow send it over espnow
Postby ESP_Sprite » Tue Oct 20, 2020 1:55 am
Yes, that's perfectly possible. Per here you can send 250 bytes at a time; to send more, you'd need to implement some kind of fragmentation scheme.
sebasdt
Postby sebasdt » Fri Oct 23, 2020 1:08 pm
sorry for the long wait.
But in the meanwhile, I have found working codes for sending and receiving https://techtutorialsx.com/2019/10/27/e ... w-message/ also tried to learn how structs work and how to put data in them. searched it up and found this video about this topic. https://www.youtube.com/watch?v=1fi2CPGcdA8
I started to make code of what I have learned from the video and stumbled upon a compiler error. while trying to send the struct via espnow
This is al new for me, don't know what it really means.
I think that the way I'm trying to send the struct variable is causing problems.
Arduino\simple_mode_espnow_struct\simple_mode_espnow_struct.ino: In function 'void sendData()':
simple_mode_espnow_struct:296:78: error: expected primary-expression before ',' token
      esp_err_t result = esp_now_send(peer_addr, (uint8_t *) &send_Mode_struct, sizeof(send_Mode_struct));
exit status 1
here is the code I made and where the problem is.
// Import required libraries//
#include <esp_now.h>
#include <WiFi.h>
#define CHANNEL 3
#define NUM_SLAVES 20                   // ESP-Now can handle a maximum of 20 slaves
#define PRINTSCANRESULTS 0
const int DATASIZE = 48;
String modes;
int slaveCount = 0;                     // Keeps count of no. of slaves with the defined prefix
esp_now_peer_info_t slaves[NUM_SLAVES]; // Stores the information of each of the slave that is added as a peer
void initESPNow();
void manageSlaves();
void scanForSlaves();
void onDataSent(const uint8_t *mac_addr, esp_now_send_status_t status);
void onDataRecv(const uint8_t *mac_add, const uint8_t *data, int data_len);
void sendData();//to send the "normal" data
int number(int a, int b) {
  int n = random(a, b);
  return n;
char *alphabet[26] = {"a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "L", "m", "n", "o", "p", "q", "r", "s", "t", "u", "v", "w", "x", "y", "z"};
typedef struct {
  char *b;//begin character <
  char *Mode; //mode letter (alphabet)
  int Value; // value for the mode 0-255
  char *e; //end character >
} send_Mode_struct;
send_Mode_struct sendMode;
void setup() {
  // Serial port for debugging purposes
  pinMode(2, OUTPUT);
  //Set device in STA mode to begin with
  WiFi.mode(WIFI_MODE_STA);
  // This is the mac address of the Master in Station Mode
  Serial.print("STA MAC: ");
  Serial.println(WiFi.macAddress());
  // Init ESPNow with a fallback logic
  initESPNow();
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(onDataSent);
  esp_now_register_recv_cb(onDataRecv);
  scanForSlaves();
  manageSlaves();
  // send_Mode_struct sendMode;
  int i = number(0, 26);
  sendMode.b = "<";
  sendMode.Mode = alphabet[i];
  sendMode.Value = number(0, 255);
  sendMode.e = ">";
  delay(500);
  printStruct();
  Serial.println("setup done");
void loop() {
  sendRandom();
  delay(500);
  printStruct();
  delay(1000);
void sendRandom() {
  //send_Mode_struct sendMode;
  Serial.println("picking random number and letter");
  Serial.println("done picking random number letter");
void printStruct()
  Serial.println("sending mode");
  Serial.printf(sendMode.b);
  Serial.printf(sendMode.Mode);
  Serial.print(sendMode.Value);
  Serial.printf(sendMode.e);
  Serial.println("");
  Serial.println("done sending modes");
// Init ESP Now with fallback
void initESPNow()
  WiFi.disconnect();
  if (esp_now_init() == ESP_OK)
    Serial.println("ESPNow Init Success");
  else
    Serial.println("ESPNow Init Failed");
    ESP.restart();
// Scan for slaves in AP mode
  int8_t scanResults = WiFi.scanNetworks();
  //reset slaves
  memset(slaves, 0, sizeof(slaves));
  slaveCount = 0;
  Serial.println("");
  if (scanResults == 0)
    Serial.println("No WiFi devices in AP Mode found");
  else
    Serial.print("Found ");
    Serial.print(scanResults);
    Serial.println(" devices ");
    for (int i = 0; i < scanResults; i++)
      // Print SSID and RSSI for each device found
      String SSID = WiFi.SSID(i);
      int32_t RSSI = WiFi.RSSI(i);
      String BSSIDstr = WiFi.BSSIDstr(i);
      if (PRINTSCANRESULTS)
        Serial.print(i + 1);
        Serial.print(": ");
        Serial.print(SSID);
        Serial.print(" [");
        Serial.print(BSSIDstr);
        Serial.print("]");
        Serial.print(" (");
        Serial.print(RSSI);
        Serial.print(")");
        Serial.println("");
      delay(10);
      // Check if the current device starts with `Slave`
      if (SSID.indexOf("Slave") == 0)
        // SSID of interest
        Serial.print(": ");
        Serial.print(SSID);
        Serial.print(" [");
        Serial.print("]");
        Serial.print(" (");
        Serial.print(RSSI);
        Serial.print(")");
        Serial.println("");
        // Get BSSID => Mac Address of the Slave
        int mac[6];
        if (6 == sscanf(BSSIDstr.c_str(), "%x:%x:%x:%x:%x:%x%c",  &mac[0], &mac[1], &mac[2], &mac[3], &mac[4], &mac[5]))
          for (int j = 0; j < 6; j++)
            slaves[slaveCount].peer_addr[j] = (uint8_t)mac[j];
        slaves[slaveCount].channel = CHANNEL; // pick a channel
        slaves[slaveCount].encrypt = 0; // no encryption
        slaveCount++;
  if (slaveCount > 0)
    Serial.print(slaveCount); Serial.println(" Slave(s) found, processing..");
  else
    Serial.println("No Slave Found, trying again.");
  // clean up ram
  WiFi.scanDelete();
// Check if the slave is already paired with the master.
// If not, pair the slave with master
void manageSlaves()
  if (slaveCount > 0)
    for (int i = 0; i < slaveCount; i++)
      const esp_now_peer_info_t *peer = &slaves[i];
      const uint8_t *peer_addr = slaves[i].peer_addr;
      Serial.print("Processing: ");
        Serial.print((uint8_t) slaves[i].peer_addr[j], HEX);
        if (j != 5)
          Serial.print(":");
      Serial.print(" Status: ");
      // check if the peer exists
      bool exists = esp_now_is_peer_exist(peer_addr);
      if (exists)
        // Slave already paired.
        Serial.println("Already Paired");
      else
        // Slave not paired, attempt pair
        esp_err_t addStatus = esp_now_add_peer(peer);
        if (addStatus == ESP_OK)
          // Pair success
          Serial.println("Pair success");
        else if (addStatus == ESP_ERR_ESPNOW_NOT_INIT)
          // How did we get so far!!
          Serial.println("ESPNOW Not Init");
        else if (addStatus == ESP_ERR_ESPNOW_ARG)
          Serial.println("Add Peer - Invalid Argument");
        else if (addStatus == ESP_ERR_ESPNOW_FULL)
          Serial.println("Peer list full");
        else if (addStatus == ESP_ERR_ESPNOW_NO_MEM)
          Serial.println("Out of memory");
        else if (addStatus == ESP_ERR_ESPNOW_EXIST)
          Serial.println("Peer Exists");
        else
          Serial.println("Not sure what happened");
        delay(1000);
  else
    // No slave found to process
    Serial.println("No Slave found to process");
// send data
void sendData() {
  // pos++;
  for (int i = 0; i < slaveCount; i++) {
    if (i == 0) { // print only for first slave
      Serial.print("Sending: ");
      printStruct();
    Serial.print("Send Status: ");
    if (result == ESP_OK) {
      Serial.println("Success");
    } else if (result == ESP_ERR_ESPNOW_NOT_INIT) {
      Serial.println("ESPNOW not Init.");
    } else if (result == ESP_ERR_ESPNOW_ARG) {
      Serial.println("Invalid Argument");
    } else if (result == ESP_ERR_ESPNOW_INTERNAL) {
      Serial.println("Internal Error");
    } else if (result == ESP_ERR_ESPNOW_NO_MEM) {
      Serial.println("ESP_ERR_ESPNOW_NO_MEM");
    } else if (result == ESP_ERR_ESPNOW_NOT_FOUND) {
      Serial.println("Peer not found.");
    } else {
    delay(100);
// callback when data is sent from Master to Slave
  char macStr[18];
  // sendTime = millis();
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
           mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  Serial.print("Last Packet Sent to: ");
  Serial.println(macStr);
  Serial.print("Last Packet Send Status: ");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
// callback when data is received from Slave to Master
  char macStr[18];
           mac_add[0], mac_add[1], mac_add[2], mac_add[3], mac_add[4], mac_add[5]);
  Serial.print("Last Packet Recv from: ");
  Serial.print("Last Packet Recv Data: ");
  Serial.println(*data);
  Serial.println("");
Postby ESP_Sprite » Sun Oct 25, 2020 12:28 pm
Send_mode_struct is the name of the typedef, the 'blueprint' of variables of that type. You can't send that. You instantiate an actual variable, Send_Mode, later; did you mean to send that instead?
sebasdt
Postby sebasdt » Mon Oct 26, 2020 9:22 am
ESP_Sprite wrote: Send_mode_struct is the name of the typedef, the 'blueprint' of variables of that type. You can't send that. You instantiate an actual variable, Send_Mode, later; did you mean to send that instead?
yes, I did mean that thanks for the tip! I'm new to structs so I don't really know why some errors are appearing.
I attached a screenshot of both serial monitors (sender and receiver).
Somehow the sender and receiver aren't printing out the chars to the serial monitor.
the receiver isn't receiving anything even when the callback function is called the struct isn't filled.
espNOW s and r fail
espNOW s and r fail.png (110.1 KiB) Viewed 5212 times
code I made is here below.
sender:
#include <WiFi.h>
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message {
  char b;
  char Mode;
  int Value;
  char e;
} struct_message;
// Create a struct_message called myData
struct_message myData;
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("\r\nLast Packet Send Status:\t");
void setup() {
  // Init Serial Monitor
  // Set device as a Wi-Fi Station
  WiFi.mode(WIFI_STA);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  esp_now_peer_info_t peerInfo;
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    Serial.println("Failed to add peer");
    return;
   myData.b, "<";
  myData.Mode, "B";
  myData.Value = random(0, 255);
  myData.e, ">";
  printStruct();
void loop() {
  // Set values to send
  myData.b, "<";
  myData.Mode, "B";
  myData.e, ">";
  printStruct();
  // Send message via ESP-NOW
  esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
    Serial.println("Sent with success");
  else {
    Serial.println("Error sending the data");
  delay(2000);
void printStruct() {
  Serial.println(sizeof(myData));
  Serial.print("Char: ");
  Serial.println(myData. b);
  Serial.println(myData.Mode);
  Serial.print("Int: ");
  Serial.println(myData.Value);
  Serial.println(myData.e);
  Serial.println();
receiver:
#include <WiFi.h>
// Structure example to receive data
// Must match the sender structure
typedef struct sendModestruct {
  char b[21]; // 21if you need 20 characters
  char Mode[21]; // 21 if you need 20 characters
  int Value;
  char e[21]; // 21if you need 20 characters
} sendModestruct;
sendModestruct sendMode;
// callback function that will be executed when data is received
void onDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  Serial.print("data received: ");
  Serial.println(*incomingData);
  memcpy(&sendMode, incomingData, sizeof(sendMode));
  Serial.print("Bytes received: ");
  Serial.println(len);
  printStruct();
void setup() {
  // Initialize Serial Monitor
  // Init ESP-NOW
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info
void loop() {}
void printStruct()
  Serial.println("printing values");
  // Serial.println(sizeof(sendModestruct));
  Serial.print("char 1: ");
  Serial.println(sendMode.b);
  Serial.print("char 2:");
  Serial.println(sendMode.Mode);
  Serial.print("int: ");
  Serial.println(sendMode.Value);
  Serial.print("char 3:");
  Serial.println(sendMode.e);
  Serial.println("");
  Serial.println("done printing values");
Postby ESP_Sprite » Tue Oct 27, 2020 4:29 am
Your sender structure and your receiver structure are not the same.
sebasdt
Postby sebasdt » Wed Oct 28, 2020 9:19 am
Thanks! I don't know why I didn't see that right away. Such a nooby mistake.
Also, thank you all for the help so far! its really appreciated!
it's working now and converted the serial mode selection to espnow with no problems so far.
The next thing to do is select if the mode select needs to be activated. that would be simple. (last famous words)
basic explanation about the code.
Do whatever you want to do with this code but please reference the original creator of the code [urhttps://github.com/Diod-dev/New_Visualizer_Skeleton[/url]
Sender:
-Search on its own for receivers and add then to the send list.
-send the struct data every few seconds.
Receiver:
- setup as a receiver and receive data and process this.
here below are the sender and receiver codes.
sender:
//the original creator of this code: https://github.com/Diod-dev/New_Visualizer_Skeleton
#include <WiFi.h>
#define CHANNEL 3
#define NUM_SLAVES 3                   // ESP-Now can handle a maximum of 20 slaves
void initESPNow();
void sendData();//to send the mode data
// Stores LED state
uint8_t currentBrightness;
int currentMode;
int currentPattern;
int inputAudioMultiplier;
int inputHue = 0;
int inputSat = 255;
int inputVal = 255;
int inputMasterBrightness;
int sendAnimation;
//char *alphabet[26] = {"a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "L", "m", "n", "o", "p", "q", "r", "s", "t", "u", "v", "w", "x", "y", "z"};
  return n;
  char b[4];
  char Mode[4];
  int Value;
  char e[4];
} sendModestruct;
// Create a struct_message called sendMode
void setup() {
  initESPNow();
  scanForSlaves();
  manageSlaves();
void loop() {
  if (slaveCount > 0)
    inputVal = random(0, 360);
    inputSat = random(0, 255);
    inputHue = random(0, 255);
    inputAudioMultiplier = random(0, 255);
    currentBrightness = random(0, 255);
    for (int i = 0; i < 35; i++) {
      Serial.println(i);
      sendRequest(i);
      delay(1000);
  } else {
    scanForSlaves();
    manageSlaves();
    delay(2000);
  void fillRandom() {
  //sendModestruct sendMode;
  strcpy(sendMode.Mode, alphabet[i]);
  Serial.println("");
void printStruct()
  Serial.print("char 2: ");
  Serial.print("char 3: ");
  Serial.println("");
  currentBrightness = inputMasterBrightness;
  switch (req) {
    case 0:
      currentMode = req;//off command Also sets GPIO to LOW (blue light turns off)
      strcpy(sendMode.b, "<");
      strcpy(sendMode.Mode, "f");
      sendMode.Value = 000;
      strcpy(sendMode.e, ">");
      sendData();
      break;
    case 1: // on command Also sets GPIO to HIGH (blue light turns on)
      currentMode = req;
      strcpy(sendMode.Mode, "o");
      sendData();
      break;
    case 2: //send solidcolor and so a hue value
      currentMode = req;
      strcpy(sendMode.Mode, "s");
      sendMode.Value = inputHue;
      sendData();
      break;
    case 3:// Send the Saturation
      currentMode = req;
      strcpy(sendMode.Mode, "t");
      sendMode.Value = inputSat;
      sendData();
      break;
    case 4: // Send a GET request for the Brightness
      currentMode = req;
      strcpy(sendMode.Mode, "b");
      sendMode.Value = inputVal;
      sendData();
      break;
    case 5: //music parttern 1
      currentMode = req;
      sendMVMode(req);
      break;
    case 6://music parttern 2
      currentMode = req;
      sendMVMode(req);
      break;
    case 7://music parttern 3
      currentMode = req;
      sendMVMode(req);
      break;
    case 8://music parttern 4
      currentMode = req;
      sendMVMode(req);
      break;
    case 9://music parttern 5
      currentMode = req;
      sendMVMode(req);
      break;
    case 10://music parttern 6
      currentMode = req;
      sendMVMode(req);
      break;
    case 11://music parttern 7
      currentMode = req;
      sendMVMode(req);
      break;
    case 12://music parttern 8
      currentMode = req;
      sendMVMode(req);
      break;
    case 13://music parttern 9
      currentMode = req;
      sendMVMode(req);
      break;
    case 14://music parttern 10
      currentMode = req;
      sendMVMode(req);
      break;
    case 15://music parttern 11
      currentMode = req;
      sendMVMode(req);
      break;
    case 17://demo parttern 1
      currentMode = req;
      sendAmbMode(req);
      break;
    case 18://demo parttern 2
      currentMode = req;
      sendAmbMode(req);
      break;
    case 19://demo parttern 3
      currentMode = req;
      sendAmbMode(req);
      break;
    case 20://demo parttern 4
      currentMode = req;
      sendAmbMode(req);
      break;
    case 21://demo parttern 5
      currentMode = req;
      sendAmbMode(req);
      break;
    case 22://demo parttern 6
      currentMode = req;
      sendAmbMode(req);
      break;
    case 23://demo parttern 7
      currentMode = req;
      sendAmbMode(req);
      break;
    case 24://demo parttern 8
      currentMode = req;
      sendAmbMode(req);
      break;
    case 25://demo parttern 9
      currentMode = req;
      sendAmbMode(req);
      break;
    case 26://demo parttern 10
      currentMode = req;
      sendAmbMode(req);
      break;
    case 27://demo parttern 11
      currentMode = req;
      sendAmbMode(req);
      break;
    case 30:  // Send the master brightness to the mothership
      strcpy(sendMode.Mode, "z");
      sendMode.Value = inputMasterBrightness;
      sendData();
      break;
    case 31:// case 98 makes the patterns automatically switching
      currentMode = req;
      strcpy(sendMode.Mode, "x");
      sendData();
      break;
    case 32: // Send the audio sensitivity
      strcpy(sendMode.Mode, "y");
      sendMode.Value = inputAudioMultiplier;
      sendData();
      break;
  currentMode = req;
  sendAnimation = currentMode - 4;
  strcpy(sendMode.Mode, "m");
  sendMode.Value = sendAnimation;
  sendData();
  currentMode = req;
  sendAnimation = currentMode - 16;
  strcpy(sendMode.Mode, "a");
  sendData();
void initESPNow()
  WiFi.disconnect();
  else
    ESP.restart();
  //reset slaves
  slaveCount = 0;
  Serial.println("");
  else
        Serial.print(": ");
        Serial.print(SSID);
        Serial.print(" [");
        Serial.print("]");
        Serial.print(" (");
        Serial.print(RSSI);
        Serial.print(")");
        Serial.println("");
      delay(10);
        // SSID of interest
        Serial.print(": ");
        Serial.print(SSID);
        Serial.print(" [");
        Serial.print("]");
        Serial.print(" (");
        Serial.print(RSSI);
        Serial.print(")");
        Serial.println("");
        int mac[6];
        slaveCount++;
  if (slaveCount > 0)
  else
  // clean up ram
  WiFi.scanDelete();
void manageSlaves()
  if (slaveCount > 0)
        if (j != 5)
          Serial.print(":");
      if (exists)
      else
          // Pair success
        else
        delay(1000);
  else
// send data
void sendData() {
      printStruct();
    esp_err_t result = esp_now_send(peer_addr, (uint8_t *) &sendMode, sizeof(sendMode));
    } else {
    delay(100);
  char macStr[18];
Receiver:
// Reads and acts on incoming messages from ESP - 32 NOW, in the format of '< (letter) (3 digit number) >'. For exmaple, <b200>
  << This Device Slave >>
   Sample Serial log:
     AP Config Success. Broadcasting with AP: Slave:3C:71:BF:52:D1:14
     AP MAC: 3C:71:BF:52:D1:15
     ESPNow Init Success
     Last Packet Recv from: 24:0a:c4:0a:6f:08
     Last Packet Recv Data: 1
#include <WiFi.h>
#define CHANNEL 1
#define SENDCHANNEL 1
#define WIFI_DEFAULT_CHANNEL 3
esp_now_peer_info_t peer;
void initESPNow();
void configDeviceAP();
void addPeer(uint8_t *peerMacAddress);
void onDataRecv(const uint8_t *mac_addr, const uint8_t *data, int data_len);
int patternMode = 1;
int patternModeOld;
int ambPattern;
int MVPattern;
int masterBrightness = 5;
double mult = 1.00;
char receivedChar[4];
char oldMode[4];
int Value;
  char b[4]; // 10 if you need 9 characters
  char Mode[4]; // 21 if you need 20 characters
  int Value;
  char e[4]; // 5 if you need 4 characters
} sendModestruct;
  char macStr[18];
           mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
  newCommand = true;
 // Serial.print("Packet received: ");
 // Serial.println(*incomingData);
 // Serial.print("Bytes received: ");
 // Serial.println(len);
  //  printStruct();
void setup() {
  //Set device in AP mode to begin with
  WiFi.mode(WIFI_AP);
  // configure device AP mode
  configDeviceAP();
  // This is the mac address of the Slave in AP Mode
  Serial.print("AP MAC: ");
  Serial.println(WiFi.softAPmacAddress());
  initESPNow();
  // get recv packer info.
  /// esp_now_register_send_cb(onDataSent);
  if (receivedChar[0] == 'a') { // Chooses an ambient pattern and displays it
    Serial.println("a");
    ambPattern = Value;
  else if (receivedChar[0] == 'b') {  // Sets the brightness when displaying a solid color
    Serial.println("b");
    Serial.println(Value);
    solidVal = Value;
  else if (receivedChar[0] == 'f') { // The off button is set, last pattern mode is saved.
    Serial.println("f");
  else if (receivedChar[0] == 'm') { // Chooses a music-visualizing pattern and displays it
    Serial.println("m");
    MVPattern = Value;
  else if (receivedChar[0] == 'o') {
    Serial.println("o");
  else if (receivedChar[0] == 's') {
    Serial.println("s");
    solidHue = Value;
  else if (receivedChar[0] == 't') {
    Serial.println("t");
    solidSat = Value;
  else if (receivedChar[0] == 'x') {
    Serial.println("x");
  else if (receivedChar[0] == 'y') {
    Serial.println("y");
    audioMultiplier = Value;
  else if (receivedChar[0] == 'z') {
    Serial.println("z");
    masterBrightness = Value;
  else {}
void SelectMode() {
    Serial.println("new Mode beginning");
    oldMode[0] = sendMode.Mode[0];
    receivedChar[0] = sendMode.Mode[0];
    Value = sendMode.Value;
    newCommand = false;
    Serial.println("new Mode ending");
void talkToESP() {
  SelectMode(); // after a message is received, act on it
void loop() {
  talkToESP();
delay(75); // simulate doing something else
void printStruct()
  Serial.println("");
void initESPNow()
  WiFi.disconnect();
  if (esp_now_init() == ESP_OK) {
  else
    ESP.restart();
// config AP SSID
  String Prefix = "Slave:";
  String Mac = WiFi.macAddress();
  String SSID = Prefix + Mac;
  String Password = "123456789";
  bool result = WiFi.softAP(SSID.c_str(), Password.c_str(), CHANNEL, 0);
  if (!result)
    Serial.println("AP Config failed.");
  else
    Serial.println("AP Config Success. Broadcasting with AP: " + String(SSID));
// Add Master as a peer
  peer.channel = SENDCHANNEL;
  peer.ifidx = WIFI_IF_AP;
  peer.encrypt = 0;
  memcpy(peer.peer_addr, peerMacAddress, 6);
  esp_err_t addStatus = esp_now_add_peer(&peer);
    // Pair success
  else
    Serial.println("Not sure what WENT WRONG");
Users browsing this forum: arnoldb1778, Google [Bot], Kopplin and 257 guests
