Trying to understand the biggest excpetion ever
urbanze
Postby urbanze » Fri Apr 12, 2019 1:16 pm
Hi guys, I doing some automated test with my product (esp32 wroom) and after 3 days of massive tests which consist of an relay turning power supply ON/OFF (both states in random times), rarely some debug excpetion occur (not fatal because RTC WDT reset board) and its very "insane/big". I just want to undestand why this exception occur, just to learn more :D
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:4140
load:0x40078000,len:9948
ho 0 tail 12 room 4
load:0x40080400,len:6428
entry 0x400806c8
I (250) cpu_start: Pro cpu up.
I (250) cpu_start: Application information:
I (250) cpu_start: App version:      50b9041-dirty
I (252) cpu_start: ELF file SHA256:  77aeb06747742a24...
I (258) cpu_start: ESP-IDF:          v4.0-dev-76-g96aa08a0f-dirty
I (265) cpu_start: Starting app cpu, entry point is 0x400811e8
0x400811e8: call_start_cpu1 at /home/ze/esp/esp-idf/components/esp32/cpu_start.c:267
I (0) cpu_start: App cpu up.
I (275) heap_init: Initializing. RAM available for dynamic allocation:
I (282) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (288) heap_init: At 3FFB94B8 len 00026B48 (154 KiB): DRAM
I (295) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (301) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (307) heap_init: At 4008C83C len 000137C4 (77 KiB): IRAM
I (314) cpu_start: Pro cpu start user code
I (331) esp_core_dump_flash: Init core dump to flash
I (331) esp_core_dump_flash: Found partition 'coredump' @ 39e000 204800 bytes
E (341) esp_core_dump_common: Core dump data CRC check failed: 0xf4b7ca1e -> 0x82115ff6!
I (343) cpu_start: Starting scheduler on PRO CPU.
��*�����Ɂz�������r��������"��՝�*��ѽ�R*Ձ•ѽ�*͹�I-�J���5�Guru Meditation Error: Core  0 panic'ed (Double exception)
Core 0 register dump:
PC      : 0x400803c0  PS      : 0x00060136  A0      : 0x400803ce  A1      : 0x3fffffce
0x400803c0: _DoubleExceptionVector at /home/ze/esp/esp-idf/components/freertos/xtensa_vectors.S:543
0x400803ce: _DoubleExceptionVector at /home/ze/esp/esp-idf/components/freertos/xtensa_vectors.S:548
A2      : 0x00000000  A3      : 0xf65b0cdc  A4      : 0x00000000  A5      : 0x8003ab7c
A6      : 0x0000000a  A7      : 0x00000021  A8      : 0x80609040  A9      : 0x0000cdcd
A10     : 0x80609072  A11     : 0x00000004  A12     : 0x00000014  A13     : 0x00000000
A14     : 0x00000000  A15     : 0xffffff00  SAR     : 0x00000037  EXCCAUSE: 0x00000002
EXCVADDR: 0x4000000a  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
ELF file SHA256: Guru Meditation Error: Core  0 panic'ed (Unhandled debug exception)
Debug exception reason: BREAK instr
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3ffffc3e
A2      : 0x3ffffd6e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3ffffe3e
A6      : 0x000000fb  A7      : 0x0000003f  A8      : 0x00000040  A9      : 0x40082081
0x40082081: _xt_user_exc at /home/ze/esp/esp-idf/components/freertos/xtensa_vectors.S:687
A10     : 0x3f400020  A11     : 0x3ffffe7e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x00000000  A15     : 0x00000001  SAR     : 0x00000016  EXCCAUSE: 0x00000001
EXCVADDR: 0x00000080  LBEG    : 0x4000c349  LEND    : 0x4000c36b  LCOUNT  : 0x00000000
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3ffff8ae
A2      : 0x3ffff9de  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3ffffaae
A10     : 0x3f400020  A11     : 0x3ffffaee  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffff0e  A15     : 0x00000002  SAR     : 0x0000001f  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3ffff51e
A2      : 0x3ffff64e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3ffff71e
A10     : 0x3f400020  A11     : 0x3ffff75e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3ffffb7e  A15     : 0x00000008  SAR     : 0x00000018  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3ffff18e
A2      : 0x3ffff2be  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3ffff38e
A10     : 0x3f400020  A11     : 0x3ffff3ce  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3ffff7ee  A15     : 0x00000008  SAR     : 0x00000011  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffedfe
A2      : 0x3fffef2e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffeffe
A10     : 0x3f400020  A11     : 0x3ffff03e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3ffff45e  A15     : 0x00000008  SAR     : 0x0000001a  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffea6e
A2      : 0x3fffeb9e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffec6e
A10     : 0x3f400020  A11     : 0x3fffecae  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3ffff0ce  A15     : 0x00000008  SAR     : 0x00000013  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffe6de
A2      : 0x3fffe80e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffe8de
A10     : 0x3f400020  A11     : 0x3fffe91e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffed3e  A15     : 0x00000008  SAR     : 0x0000001c  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffe34e
A2      : 0x3fffe47e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffe54e
A10     : 0x3f400020  A11     : 0x3fffe58e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffe9ae  A15     : 0x00000008  SAR     : 0x00000015  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffdfbe
A2      : 0x3fffe0ee  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffe1be
A10     : 0x3f400020  A11     : 0x3fffe1fe  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffe61e  A15     : 0x00000008  SAR     : 0x0000001e  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffdc2e
A2      : 0x3fffdd5e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffde2e
A10     : 0x3f400020  A11     : 0x3fffde6e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffe28e  A15     : 0x00000008  SAR     : 0x00000017  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffd89e
A2      : 0x3fffd9ce  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffda9e
A10     : 0x3f400020  A11     : 0x3fffdade  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffdefe  A15     : 0x00000008  SAR     : 0x00000020  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffd50e
A2      : 0x3fffd63e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffd70e
A10     : 0x3f400020  A11     : 0x3fffd74e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffdb6e  A15     : 0x00000008  SAR     : 0x00000019  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffd17e
A2      : 0x3fffd2ae  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffd37e
A10     : 0x3f400020  A11     : 0x3fffd3be  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffd7de  A15     : 0x00000008  SAR     : 0x00000012  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffcdee
A2      : 0x3fffcf1e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffcfee
A10     : 0x3f400020  A11     : 0x3fffd02e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffd44e  A15     : 0x00000008  SAR     : 0x0000001b  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffca5e
A2      : 0x3fffcb8e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffcc5e
A10     : 0x3f400020  A11     : 0x3fffcc9e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffd0be  A15     : 0x00000008  SAR     : 0x00000014  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffc6ce
A2      : 0x3fffc7fe  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffc8ce
A10     : 0x3f400020  A11     : 0x3fffc90e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffcd2e  A15     : 0x00000008  SAR     : 0x0000001d  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffc33e
A2      : 0x3fffc46e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffc53e
A10     : 0x3f400020  A11     : 0x3fffc57e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffc99e  A15     : 0x00000008  SAR     : 0x00000016  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffbfae
A2      : 0x3fffc0de  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffc1ae
A10     : 0x3f400020  A11     : 0x3fffc1ee  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffc60e  A15     : 0x00000008  SAR     : 0x0000001f  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffbc1e
A2      : 0x3fffbd4e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffbe1e
A10     : 0x3f400020  A11     : 0x3fffbe5e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffc27e  A15     : 0x00000008  SAR     : 0x00000018  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffb88e
A2      : 0x3fffb9be  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffba8e
A10     : 0x3f400020  A11     : 0x3fffbace  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffbeee  A15     : 0x00000008  SAR     : 0x00000011  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffb4fe
A2      : 0x3fffb62e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffb6fe
A10     : 0x3f400020  A11     : 0x3fffb73e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffbb5e  A15     : 0x00000008  SAR     : 0x0000001a  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffb16e
A2      : 0x3fffb29e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffb36e
A10     : 0x3f400020  A11     : 0x3fffb3ae  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffb7ce  A15     : 0x00000008  SAR     : 0x00000013  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffadde
A2      : 0x3fffaf0e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffafde
A10     : 0x3f400020  A11     : 0x3fffb01e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffb43e  A15     : 0x00000008  SAR     : 0x0000001c  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffaa4e
A2      : 0x3fffab7e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffac4e
A10     : 0x3f400020  A11     : 0x3fffac8e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffb0ae  A15     : 0x00000008  SAR     : 0x00000015  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffa6be
A2      : 0x3fffa7ee  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffa8be
A10     : 0x3f400020  A11     : 0x3fffa8fe  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffad1e  A15     : 0x00000008  SAR     : 0x0000001e  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fffa32e
A2      : 0x3fffa45e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffa52e
A10     : 0x3f400020  A11     : 0x3fffa56e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffa98e  A15     : 0x00000008  SAR     : 0x00000017  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff9f9e
A2      : 0x3fffa0ce  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fffa19e
A10     : 0x3f400020  A11     : 0x3fffa1de  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffa5fe  A15     : 0x00000008  SAR     : 0x00000020  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff9c0e
A2      : 0x3fff9d3e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff9e0e
A10     : 0x3f400020  A11     : 0x3fff9e4e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fffa26e  A15     : 0x00000008  SAR     : 0x00000019  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff987e
A2      : 0x3fff99ae  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff9a7e
A10     : 0x3f400020  A11     : 0x3fff9abe  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff9ede  A15     : 0x00000008  SAR     : 0x00000012  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff94ee
A2      : 0x3fff961e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff96ee
A10     : 0x3f400020  A11     : 0x3fff972e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff9b4e  A15     : 0x00000008  SAR     : 0x0000001b  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff915e
A2      : 0x3fff928e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff935e
A10     : 0x3f400020  A11     : 0x3fff939e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff97be  A15     : 0x00000008  SAR     : 0x00000014  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff8dce
A2      : 0x3fff8efe  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff8fce
A10     : 0x3f400020  A11     : 0x3fff900e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff942e  A15     : 0x00000008  SAR     : 0x0000001d  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff8a3e
A2      : 0x3fff8b6e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff8c3e
A10     : 0x3f400020  A11     : 0x3fff8c7e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff909e  A15     : 0x00000008  SAR     : 0x00000016  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff86ae
A2      : 0x3fff87de  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff88ae
A10     : 0x3f400020  A11     : 0x3fff88ee  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff8d0e  A15     : 0x00000008  SAR     : 0x0000001f  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff831e
A2      : 0x3fff844e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff851e
A10     : 0x3f400020  A11     : 0x3fff855e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff897e  A15     : 0x00000008  SAR     : 0x00000018  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff7f8e
A2      : 0x3fff80be  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff818e
A10     : 0x3f400020  A11     : 0x3fff81ce  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff85ee  A15     : 0x00000008  SAR     : 0x00000011  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff7bfe
A2      : 0x3fff7d2e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff7dfe
A10     : 0x3f400020  A11     : 0x3fff7e3e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff825e  A15     : 0x00000008  SAR     : 0x0000001a  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff786e
A2      : 0x3fff799e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff7a6e
A10     : 0x3f400020  A11     : 0x3fff7aae  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff7ece  A15     : 0x00000008  SAR     : 0x00000013  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff74de
A2      : 0x3fff760e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff76de
A10     : 0x3f400020  A11     : 0x3fff771e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff7b3e  A15     : 0x00000008  SAR     : 0x0000001c  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff714e
A2      : 0x3fff727e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff734e
A10     : 0x3f400020  A11     : 0x3fff738e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff77ae  A15     : 0x00000008  SAR     : 0x00000015  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff6dbe
A2      : 0x3fff6eee  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff6fbe
A10     : 0x3f400020  A11     : 0x3fff6ffe  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff741e  A15     : 0x00000008  SAR     : 0x0000001e  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff6a2e
A2      : 0x3fff6b5e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff6c2e
A10     : 0x3f400020  A11     : 0x3fff6c6e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff708e  A15     : 0x00000008  SAR     : 0x00000017  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff669e
A2      : 0x3fff67ce  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff689e
A10     : 0x3f400020  A11     : 0x3fff68de  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff6cfe  A15     : 0x00000008  SAR     : 0x00000020  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff630e
A2      : 0x3fff643e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff650e
A10     : 0x3f400020  A11     : 0x3fff654e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff696e  A15     : 0x00000008  SAR     : 0x00000019  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff5f7e
A2      : 0x3fff60ae  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff617e
A10     : 0x3f400020  A11     : 0x3fff61be  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff65de  A15     : 0x00000008  SAR     : 0x00000012  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff5bee
A2      : 0x3fff5d1e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff5dee
A10     : 0x3f400020  A11     : 0x3fff5e2e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff624e  A15     : 0x00000008  SAR     : 0x0000001b  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff585e
A2      : 0x3fff598e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff5a5e
A10     : 0x3f400020  A11     : 0x3fff5a9e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff5ebe  A15     : 0x00000008  SAR     : 0x00000014  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff54ce
A2      : 0x3fff55fe  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff56ce
A10     : 0x3f400020  A11     : 0x3fff570e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff5b2e  A15     : 0x00000008  SAR     : 0x0000001d  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff513e
A2      : 0x3fff526e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff533e
A10     : 0x3f400020  A11     : 0x3fff537e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff579e  A15     : 0x00000008  SAR     : 0x00000016  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff4dae
A2      : 0x3fff4ede  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff4fae
A10     : 0x3f400020  A11     : 0x3fff4fee  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff540e  A15     : 0x00000008  SAR     : 0x0000001f  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff4a1e
A2      : 0x3fff4b4e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff4c1e
A10     : 0x3f400020  A11     : 0x3fff4c5e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff507e  A15     : 0x00000008  SAR     : 0x00000018  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff468e
A2      : 0x3fff47be  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff488e
A10     : 0x3f400020  A11     : 0x3fff48ce  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff4cee  A15     : 0x00000008  SAR     : 0x00000011  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff42fe
A2      : 0x3fff442e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff44fe
A10     : 0x3f400020  A11     : 0x3fff453e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff495e  A15     : 0x00000008  SAR     : 0x0000001a  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff3f6e
A2      : 0x3fff409e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff416e
A10     : 0x3f400020  A11     : 0x3fff41ae  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff45ce  A15     : 0x00000008  SAR     : 0x00000013  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff3bde
A2      : 0x3fff3d0e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff3dde
A10     : 0x3f400020  A11     : 0x3fff3e1e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff423e  A15     : 0x00000008  SAR     : 0x0000001c  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff384e
A2      : 0x3fff397e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff3a4e
A10     : 0x3f400020  A11     : 0x3fff3a8e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff3eae  A15     : 0x00000008  SAR     : 0x00000015  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff34be
A2      : 0x3fff35ee  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff36be
A10     : 0x3f400020  A11     : 0x3fff36fe  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff3b1e  A15     : 0x00000008  SAR     : 0x0000001e  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff312e
A2      : 0x3fff325e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff332e
A10     : 0x3f400020  A11     : 0x3fff336e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff378e  A15     : 0x00000008  SAR     : 0x00000017  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff2d9e
A2      : 0x3fff2ece  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff2f9e
A10     : 0x3f400020  A11     : 0x3fff2fde  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff33fe  A15     : 0x00000008  SAR     : 0x00000020  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff2a0e
A2      : 0x3fff2b3e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff2c0e
A10     : 0x3f400020  A11     : 0x3fff2c4e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff306e  A15     : 0x00000008  SAR     : 0x00000019  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff267e
A2      : 0x3fff27ae  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff287e
A10     : 0x3f400020  A11     : 0x3fff28be  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff2cde  A15     : 0x00000008  SAR     : 0x00000012  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff22ee
A2      : 0x3fff241e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff24ee
A10     : 0x3f400020  A11     : 0x3fff252e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff294e  A15     : 0x00000008  SAR     : 0x0000001b  EXCCAUSE: 0x00000001
PC      : 0x400803c0  PS      : 0x00040036  A0      : 0x00000041  A1      : 0x3fff1f5e
A2      : 0x3fff208e  A3      : 0x00000000  A4      : 0x00000009  A5      : 0x3fff215e
A10     : 0x3f400020  A11     : 0x3fff219e  A12     : 0x00000009  A13     : 0x0000005e
A14     : 0x3fff25be  A15     : 0x00000008  SAR     : 0x00000014  EXCCAUSE: 0x00000001
ELF file SHA256: Guru Meditation Error: Core �ets Jun  8 2016 00:22:57
ho 0 tail 12 room 4
entry 0x400806c8
Apparently, this exception keep printing while RTC_WDT not trigger (5sec), after this, esp start normally.
Users browsing this forum: Baidu [Spider] and 178 guests
