stack overflow while using multiple UARTs
Posted: Thu Apr 25, 2019 6:04 pm
I am getting a stack overflow error when I try to display to the monitor ("make monitor") data received on UART 1 or 2. I am wondering if this is related to the the buffer sync problem (https://github.com/espressif/arduino-esp32/pull/1849) or is there something else I am missing?
/* UART Echo Example*/
#include <stdio.h>
#include "freertos/task.h"
#include "driver/uart.h"
#include "esp_log.h"
* This is an example which echos any data it receives on UART1 back to the sender,
* with hardware flow control turned off. It does not use UART driver event queue.
* - Port: UART1
* - Receive (Rx) buffer: on
* - Transmit (Tx) buffer: off
* - Flow control: off
* - Event queue: off
* - Pin assignment: see defines below
#define ECHO_TEST_TXD (GPIO_NUM_4)
#define ECHO_TEST_RXD (GPIO_NUM_5)
#define ECHO_TEST_RTS (UART_PIN_NO_CHANGE)
#define ECHO_TEST_CTS (UART_PIN_NO_CHANGE)
#define BUF_SIZE (2048)
static void echo_task()
/* Configure parameters of an UART driver,
* communication pins and install the driver */
uart_config_t uart_config = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
uart_param_config(UART_NUM_1, &uart_config);
uart_set_pin(UART_NUM_1, ECHO_TEST_TXD, ECHO_TEST_RXD, ECHO_TEST_RTS, ECHO_TEST_CTS);
uart_driver_install(UART_NUM_1, BUF_SIZE * 2, 0, 0, NULL, 0);
// Configure a temporary buffer for the incoming data
uint8_t *data = (uint8_t *) malloc(BUF_SIZE);
//uint8_t data[128];
while (1) {
// Read data from the UART
uart_read_bytes(UART_NUM_1, data, BUF_SIZE, 20 / portTICK_RATE_MS);
//int length = 0;
//ESP_ERROR_CHECK(uart_get_buffered_data_len(UART_NUM_1, (size_t*)&length));
//length = uart_read_bytes(UART_NUM_1, data, length, 100);
// send received data to "make monitor" output
printf((const char *)data);
void app_main()
printf("UART test\r\n\r\n");
xTaskCreate(echo_task, "uart_echo_task", 1024, NULL, 10, NULL);
The hardware setup is an EFM8 Sending RS232 serial at 115200 baud to GPIO 5 of the ESP32. This is the ADC reading in mv. It varies around this value. Here is a typical output (captured with PICO logic analyzer):I (188) boot: ESP-IDF v3.2-dev-640-gcc8ad721 2nd stage bootloader
I (188) boot: compile time 08:20:14
I (189) boot: Enabling RNG early entropy source...
I (209) boot: SPI Speed : 40MHz
I (222) boot: SPI Mode : DIO
I (235) boot: SPI Flash Size : 4MB
I (248) boot: Partition Table:
I (259) boot: ## Label Usage Type ST Offset Length
I (281) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (305) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (328) boot: 2 factory factory app 00 00 00010000 00100000
I (351) boot: End of partition table
I (364) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x095c4 ( 38340) map
I (475) esp_image: segment 1: paddr=0x000195ec vaddr=0x3ffb0000 size=0x02128 ( 8488) load
I (498) esp_image: segment 2: paddr=0x0001b71c vaddr=0x3ffb2128 size=0x00000 ( 0) load
I (499) esp_image: segment 3: paddr=0x0001b724 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at C:/msys32/home/Peter/esp/esp-idf/components/freertos/xtensa_vectors.S:1685
I (527) esp_image: segment 4: paddr=0x0001bb2c vaddr=0x40080400 size=0x044e4 ( 17636) load
I (597) esp_image: segment 5: paddr=0x00020018 vaddr=0x400d0018 size=0x1389c ( 80028) map
0x400d0018: _flash_cache_start at ??:?
I (771) esp_image: segment 6: paddr=0x000338bc vaddr=0x400848e4 size=0x055ec ( 21996) load
0x400848e4: vTaskDelete at C:/msys32/home/Peter/esp/esp-idf/components/freertos/tasks.c:4617
I (829) esp_image: segment 7: paddr=0x00038eb0 vaddr=0x400c0000 size=0x00000 ( 0) load
I (831) esp_image: segment 8: paddr=0x00038eb8 vaddr=0x50000000 size=0x00000 ( 0) load
I (887) boot: Loaded app from partition at offset 0x10000
I (888) boot: Disabling RNG early entropy source...
I (893) cpu_start: Pro cpu up.
I (903) cpu_start: Starting app cpu, entry point is 0x40080f0c
0x40080f0c: call_start_cpu1 at C:/msys32/home/Peter/esp/esp-idf/components/esp32/cpu_start.c:226
I (1) cpu_start: App cpu up.
I (936) heap_init: Initializing. RAM available for dynamic allocation:
I (957) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (975) heap_init: At 3FFB3178 len 0002CE88 (179 KiB): DRAM
I (995) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1014) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1034) heap_init: At 40089ED0 len 00016130 (88 KiB): IRAM
I (1054) cpu_start: Pro cpu start user code
I (360) cpu_start: Starting scheduler on PRO CPU.
UART test
1267
1267
1264
1264
1264
1264
1264
1264
1264
1264
1267
1264
1264
1264
1264
1264
1264
1267
1264
1264
1267
1261***ERROR*** A stack overflow in task uart_echo_task has been detected.
abort() was called at PC 0x4008815c on core 1
Packet Data
1: 1
2: 2
3: 6
4: 4
5: CR
6: LF
7: 1
8: 2
9: 6
10: 4
11: CR
12: LF
13: 1
14: 2
15: 6
16: 7
17: CR
18: LF
19: 1
20: 2
