Hi!
How to make ESP32 output 20MHZ's clock? And can you provide code?
Re: How to make ESP32 output 20MHZ's clock
Do you mean you want a square wave output on a GPIO pin that has a frequency of 20MHz? If so, you can likely use the PWM functions.
OK ,Thank you,sorry for my bad English.I will check it
seems pwm can only be used to generate 333k clock ... what about higher frequencies ?
- ESP_krzychb
- Contact:
roctwo wrote:How to make ESP32 output 20MHZ's clock? And can you provide code?
Below is an example how to generate 20MHz square wave at 50% duty on GPIO18.
- #include "driver/ledc.h"
- ledc_timer_config_t ledc_timer = {
- .speed_mode = LEDC_HIGH_SPEED_MODE,
- .timer_num = LEDC_TIMER_0,
- .bit_num = 2,
- .freq_hz = 20000000
- ledc_channel_config_t ledc_channel = {
- .channel = LEDC_CHANNEL_0,
- .gpio_num = 18,
- .timer_sel = LEDC_TIMER_0,
- .duty = 2
- void app_main()
- ledc_timer_config(&ledc_timer);
- ledc_channel_config(&ledc_channel);
- while (1) {
Users browsing this forum: No registered users and 211 guests
