[SOLVED] mDNS
davdav
[SOLVED] mDNS
Postby davdav » Tue May 07, 2019 10:57 am
Hi eveybody,
I'm testing mDNS component and I have setup it using this simple code:
    	//initialize mDNS service
    	esp_err_t err = mdns_init();
		if (err)
			ESP_LOGW(TAG_WIFI, "MDNS Init failed: 0x%X\n", err);
		else
			//set hostname
			mdns_hostname_set("avior");
			//set default instance
			mdns_instance_name_set("AVIOR");
If I ping from a linux PC I got the below result. Please note "espessif.station"
 ping avior.local
PING avior.local (10.0.0.12) 56(84) bytes of data.
64 bytes from espressif.station (10.0.0.12): icmp_seq=1 ttl=255 time=100 ms
64 bytes from espressif.station (10.0.0.12): icmp_seq=2 ttl=255 time=318 ms
64 bytes from espressif.station (10.0.0.12): icmp_seq=3 ttl=255 time=242 ms
64 bytes from espressif.station (10.0.0.12): icmp_seq=4 ttl=255 time=161 ms
64 bytes from espressif.station (10.0.0.12): icmp_seq=5 ttl=255 time=82.8 ms
64 bytes from espressif.station (10.0.0.12): icmp_seq=6 ttl=255 time=311 ms
^C
--- avior.local ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5006ms
rtt min/avg/max/mdev = 82.871/202.686/318.001/94.113 ms
Where does "espressif.station" come from? I have searched on esp-idf folder and on forum but I'm not able to find it.
How to change it?
WiFive
Re: mDNS
Postby WiFive » Tue May 07, 2019 11:15 am
tcpip_adapter_set_hostname
davdav
Re: mDNS
Postby davdav » Tue May 07, 2019 11:49 am
Thanks @WiFive. Got it.
Users browsing this forum: No registered users and 131 guests
