ESP32 compiling time is way too long!
bonmotwang
Postby bonmotwang » Tue May 14, 2019 8:27 pm
Hello other developers.
ESP32 takes minutes to compile. How do you guys live with the long compiling time?
Every change takes minutes to verify.
I guess at the later stage in the development it is probably fine.
But at beginning it is really slowing things done!
Paul
username
Re: ESP32 compiling time is way too long!
Postby username » Tue May 14, 2019 9:37 pm
The initial build takes a bit. On my system it takes 15 seconds. Once you make a change it will recompile just that file. So it sounds like you possibly got something messed up in your setup install.
Make sure you add the -jx option to make. I.E. make -jx. where x is how many cores your PC has.
fly135
Postby fly135 » Tue May 14, 2019 9:42 pm
I think -jx is x = 2 x cores because each core supports two threads. Also if you are running win10 you should disable defender from scanning your development directory.
John A
username
Postby username » Tue May 14, 2019 10:15 pm
Correct. My current system is a 8 core. so that would be: make -j16. I should have been more clear, just assumed people knew.
ESP_Angus
Postby ESP_Angus » Wed May 15, 2019 1:47 am
Yes, after the initial build only changed source files should be compiled.
The only exception is if you edit the menuconfig. In this case all files need re-compilation with the new config settings.
If you're not seeing this, it may be a bug - please provide some more details so we can help you figure it out.
As others have said, running "make -jN" and (on Windows) disabling Defender or adding Defender exceptions for IDF paths & tools will improve performance a lot.
You can also get better Windows performance by moving to the new CMake build system, but Eclipse support for this is still pending. https://docs.espressif.com/projects/esp ... ted-cmake/
bonmotwang
Postby bonmotwang » Wed May 15, 2019 3:09 am
I am running it on Windows 7.
This is the build output when I start build:
23:08:25 **** Incremental Build of configuration Default for project blink ****
make -j8 all
bonmotwang
Postby bonmotwang » Wed May 15, 2019 3:13 am
Output.txt attached.
I didn't change any code. Just compile, it always takes almost a minute to finish.
output.txt
(35.38 KiB) Downloaded 832 times
bonmotwang
Postby bonmotwang » Wed May 15, 2019 3:30 am
I compiled the project in mingw32 command line.
It only compiles the changes. and much faster.
I attached the output.
So there much be some setting in Eclipse messed up the build?
Paul
output in mingw32.txt
(715 Bytes) Downloaded 792 times
ESP_Angus
Postby ESP_Angus » Wed May 15, 2019 3:48 am
Hi Paul,
There's more console output in the Eclipse log, but you'll probably get the same console output in MINGW with "make V=1" - verbose output.
48 seconds is a long time, as the Eclipse build log shows that nothing was actually compiled (it just looks at each component and says "nothing needs compiling here").
What ESP-IDF version do you have?
bonmotwang
Postby bonmotwang » Wed May 15, 2019 6:43 pm
My ESP-IDF version:
Paul@W510 MINGW32 ~/esp/esp-idf
# git describe
v4.0-dev-311-g70eda3d22
Paul
Users browsing this forum: ESP_Roland, GooseGoose and 95 guests
