The examples show how to add PEM certificate to the flash (howsmyssl_com_root_cert.pem)
All working fine to connect through HTTPS to our server. But a certificate has an expiration date.
So after September I imagine the communication will suddenly stop, and we will not be able to do OTA to fix it.
Are my assumptions correct? how can I make esp download latest PEM when it expires?
EDIT: there is a ENABLE_MBEDTLS_CERTIFICATE_EXPIRACY_CHECK option in menuconfig disabled by default.
Does this mean it will not break and I don't have to worry?
PEM Certificate expires in September?
- gunar.kroeger
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
- gunar.kroeger
Re: PEM Certificate expires in September?
found this post that seems to confirm it:gunar.kroeger wrote: ↑Fri May 31, 2019 2:21 pmEDIT: there is a ENABLE_MBEDTLS_CERTIFICATE_EXPIRACY_CHECK option in menuconfig disabled by default.
viewtopic.php?t=7585
- gunar.kroeger
It just isn't clear to me if we have to do anything special in the server to keep the certificate forever or something
We generated a certificate that will expire in 7 days so we can test it
Users browsing this forum: No registered users and 225 guests
