Isolate GPIO (not RTC) during deep-sleep
Posted: Wed Jun 05, 2019 11:53 am
by davdav
Hi everybody,
I have the necessity to isolate some GPIO (not RTC) like GPIO16, GPIO18, GPIO22 and GPIO23 during deepsleep in ESP32-WROOM32D module.
In my case GPIO22 and GPIO23 are outputs and using
	gpio_hold_en();
	gpio_deep_sleep_hold_en();
I'm able to fix their status during deep-sleep and wakeup stub.
GPIO16 and GPIO18 are used for I2C bus and have external pull-up resistors. Before entring in deep-sleep should I change them to output mode, set high level and hold their status? Or they are automatically isolated from the external resistors?
Re: Isolate GPIO (not RTC) during deep-sleep
Posted: Wed Jun 12, 2019 2:10 am
by ESP_houwenxiang
Hi, davdav
You do not need to reconfigure the GPIO mode before entering deep-sleep. When `gpio_deep_sleep_hold_en` is called, all digital GPIOs will remain in their current state. But after the chip wakes up from deep sleep and calls `gpio_deep_sleep_hold_dis`, all digital GPIOs will be reset to the default mode. In this case, you need to reconfigure the GPIO before this function call.
thanks !!
Posted: Wed Jun 12, 2019 9:17 am
by davdav
Hi, davdav
thanks !!
Thank you @ESP_houwenxiang,
In practice, if device wakes-up and I DON'T call `gpio_deep_sleep_hold_dis`, digital GPIO (not RTC) inputs should work as before entering in deep-sleep, right? I.e. in my particular case GPIO16 and GPIO18 will still work as I2C bus. Consider that at every start-up (not regarding if it is a wake up from or a power-on) I init the I2C driver.
However, I will do some test in order to understand how it works, because documentation in my opininon is not so clear regarding the "hold" functionality.
thanks
Posted: Thu Jun 13, 2019 9:39 am
by ESP_houwenxiang
Yes, all states will remain in the state before sleep. the GPIO can not input or output as you wanted. so, `gpio_deep_sleep_hold_dis` should be called if you want I2C bus works.
Posted: Sat Dec 26, 2020 7:53 am
by andrewandroid
Hey davdav and ESP_houwenxiang
Thanks for posting details.
I have exactly the same problem, I believe. Did you get this working?
Here's my setup:
I have three non-RTC GPIO pins (16, 17, 18), and I want them to stay HIGH during deep sleep.
I'm using Arduino IDE:
// Stop doing PWM.
ledcDetachPin(16);
pinMode(16,OUTPUT);
digitalWrite(16, HIGH);
ledcDetachPin(17);
pinMode(17,OUTPUT);
digitalWrite(17, HIGH);
ledcDetachPin(18);
pinMode(18,OUTPUT);
digitalWrite(18, HIGH);
gpio_hold_en((gpio_num_t) 16);
gpio_hold_en((gpio_num_t) 17);
gpio_hold_en((gpio_num_t) 18);
delay(10000);
esp_deep_sleep_start();
Problem:
Pin 16 and 17 go to LOW as soon as I call `esp_deep_sleep_start()`. They should stay HIGH.
Did your IDF code work?
I've read a number of other posts about this topic, and I'm not sure what the problem is.
Would really appreciate any help or hints anyone can give.
Thanks,
Andrew
