Debugging pthreads
PeterR
Debugging pthreads
Postby PeterR » Fri Jun 07, 2019 12:26 pm
I am using C++11 std::thread for portability. Sometimes I see:
***ERROR*** A stack overflow in task pthread has been detected.
abort() was called at PC 0x4008496c on core 0
0x4008496c: vApplicationStackOverflowHook at C:/msys32/home/Pete/esp/esp-idf/components/esp32/panic.c:716
The error report does not seem to include an Id or name. How would I find out which task is at fault?
mikemoy
Re: Debugging pthreads
Postby mikemoy » Fri Jun 07, 2019 1:23 pm
You want to look into GetTaskHighWaterMark.
This is what I use on all my tasks to see how close they come to running out of stack.
#define STACK_SIZE_IdleLoop 2048		// stack size for idleLoop
TaskHandle_t TaskHandle_IdleLoop;
  GetTaskHighWaterMark( TaskHandle_t task_handle )
 	Input Params:
    - task_handle: The task name you want to examine
  Returns:  high water mark for tasks stack
  Example:  printf("Stack Water Mark: %u\r\n", GetTaskHighWaterMark( xTask1 ) );
  Notes:    The lower the result, means the closer you are to running out of
            stack space.
UBaseType_t GetTaskHighWaterMark( TaskHandle_t task_handle )
  UBaseType_t uxHighWaterMark;
  uxHighWaterMark = uxTaskGetStackHighWaterMark( task_handle );
  return uxHighWaterMark;
  GetTaskHighWaterMarkPercent( TaskHandle_t task_handle, uint32_t stack_allotment )
 	Input Params:
   	- stack_allotment:  How much stack space did you allocate to it when you created it
  Returns: float with the % of stacke used
  Example:   printf("Stack Used %04.1f%%\r\n", GetTaskHighWaterMarkPercent(xTask1, 2048) );
  Notes:
float GetTaskHighWaterMarkPercent( TaskHandle_t task_handle, uint32_t stack_allotment )
  uint32_t diff = stack_allotment - uxHighWaterMark;
  float result = ((float)diff / (float)stack_allotment) * 100.0;
  return result;
  	idleloop()
void idleloop(void * parameter)
	for (;;)
		printf("Stack Used %04.1f%%\r\n", GetTaskHighWaterMarkPercent(TaskHandle_IdleLoop, STACK_SIZE_IdleLoop) );
		vTaskDelay(500 / portTICK_PERIOD_MS);
   app_main
void app_main()
	xTaskCreate(idleloop, "idleloop", STACK_SIZE_IdleLoop, NULL, 1, &TaskHandle_IdleLoop);
PeterR
Postby PeterR » Fri Jun 07, 2019 1:55 pm
Thanks, always nice to get some neat, commented code. I will use that for my FreeRTOS code.
But... I am using C++11 'tasks' not FreeRTOS.
So I am looking for a way to get std::thread.id out onto console.
Users browsing this forum: CatNoir, Google [Bot] and 114 guests
