Hello people,
Id like to run the code as below.
while(1) {
while((PORT & 0x20)=0);
doit();
But system reboot occurs.
If possible, could anybody tell me how ?
Thank you.
Is eternal spinlock possible?
Re: Is eternal spinlock possible?
Normally, this should not reboot. Can you give a bit more context: the SDK you use, the actual code that reboots?
First, I have to say that I have solved the problem by disabling WDT in menuconfig.
Then, I show the source code and monitor output.
Thank you.
source code
void app_main()
portMUX_TYPE mutex = portMUX_INITIALIZER_UNLOCKED;
portENTER_CRITICAL(&mutex);
gpio_set_direction(PIN, GPIO_MODE_OUTPUT);
for (int k = 0; k < 3; k++)
PORT |= (1 << PIN);
for (unsigned int i = 0; i < 0x1fffff; i++) asm volatile("nop\n\t");
PORT &= ~(1 << PIN);
while (1);
portEXIT_CRITICAL(&mutex);
monitor output
ets Jun 8 2016 00:22:57
rst:0x7 (TG0WDT_SYS_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6436
load:0x40078000,len:11304
load:0x40080400,len:6752
entry 0x40080768
W (172) boot: PRO CPU has been reset by WDT.
W (172) boot: WDT reset info: PRO CPU PC=0x400d1f19
0x400d1f19: app_main at C:/tmp/msys32/home/koichi/esp32_al422b_ov7670/main/esp32
_al422b_ov7670.c:257 (discriminator 1)
W (173) boot: WDT reset info: APP CPU PC=0x400e2496 (waiti mode)
0x400e2496: esp_pm_impl_waiti at C:/tmp/msys32/opt/esp-idf/components/esp32/pm_e
sp32.c:493
I (180) boot: ESP-IDF v4.0-dev-489-gc2aef48a5 2nd stage bootloader
I (187) boot: compile time 23:54:47
I (191) boot: Enabling RNG early entropy source...
I (197) boot: SPI Speed : 40MHz
I (201) boot: SPI Mode : DIO
I (205) boot: SPI Flash Size : 4MB
I (209) boot: Partition Table:
I (213) boot: ## Label Usage Type ST Offset Length
I (220) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (228) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (235) boot: 2 factory factory app 00 00 00010000 00100000
I (243) boot: End of partition table
I (247) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x0889c ( 3
4972) map
I (268) esp_image: segment 1: paddr=0x000188c4 vaddr=0x3ffb0000 size=0x01e88 (
7816) load
I (272) esp_image: segment 2: paddr=0x0001a754 vaddr=0x40080000 size=0x00400 (
1024) load
0x40080000: _WindowOverflow4 at C:/tmp/msys32/opt/esp-idf/components/freertos/xt
ensa_vectors.S:1779
I (277) esp_image: segment 3: paddr=0x0001ab5c vaddr=0x40080400 size=0x054b4 ( 2
1684) load
I (294) esp_image: segment 4: paddr=0x00020018 vaddr=0x400d0018 size=0x12480 ( 7
4880) map
0x400d0018: _flash_cache_start at ??:?
I (321) esp_image: segment 5: paddr=0x000324a0 vaddr=0x400858b4 size=0x02618 (
9752) load
0x400858b4: vPortYieldOtherCore at C:/tmp/msys32/opt/esp-idf/components/freertos
/port.c:403
I (330) boot: Loaded app from partition at offset 0x10000
I (330) boot: Disabling RNG early entropy source...
I (332) cpu_start: Pro cpu up.
I (336) cpu_start: Application information:
Thank you.
source code
void app_main()
PORT |= (1 << PIN);
while (1);
monitor output
entry 0x40080768
sp32.c:493
4972) map
7816) load
1024) load
ensa_vectors.S:1779
1684) load
4880) map
9752) load
/port.c:403
Please do not do that. ESP-IDF is not made to have interrupts disabled for a long time while you're bitbanging data; the watchdog timer is there for a reason. Have you tried using one of the many, many peripherals the ESP32 has to do stuff like this fully automatically instead?
Thank you for your advise. All that I need is H/W interrupt which guarantees a delay less than several tens or hundreds of micro seconds. I think the delay guaranteed on ESP32 is several tens of msec, so I tried that attempt.
Actually, I will not do eternal spinlock. I will send data to serve via wifi, which the interrupt handler get, once per hour. A task switch is to be occurred at the time.
If you know, could you let me know how long the delay on ESP32 is.
Thank you.
Thank you.
Can you explain a bit more about what you're trying to achieve? Are you trying to implement a protocol in software or something?
Users browsing this forum: No registered users and 115 guests
