ESP32 AT Commands : Build failed with ESP IDF 4.0
Mickael
Postby Mickael » Wed Jul 24, 2019 10:11 am
Hello !
I'm using ESP-IDF 4.0, the last version of ESP32-AT https://github.com/espressif/esp32-at and MSYS2 (because I'm using Windows). The other examples of ESP-IDF works fine but when I'm trying to build ESP32-AT, I have this error :
micka@DESKTOP-2H3RRPN MINGW32 ~/esp/esp32-at
$ make
Makefile:29: There is no module_config/module_wroom-32,Using module_config/module_esp32_default
fatal: le chemin de destination '/home/micka/esp/esp-idf' existe déjà et n'est pas un répertoire vide.
fatal: la référence n'est pas un arbre : 91f29bef172a082cbd8f0208ed1757ede0e1d635
/home/micka/esp/esp32-at/tools/mkfatfs/Makefile.projbuild:13: avertissement : surchargement de la recette pour la cible « clean »
/home/micka/esp/esp-idf/components/app_update/Makefile.projbuild:56: avertissement : ancienne recette ignorée pour la cible « clean »
Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: esp32-2019r1
Compiler version: 8.2.0
Python requirements from C:/msys32/home/micka/esp/esp-idf/requirements.txt are satisfied.
CC build/bootloader/bootloader_support/src/bootloader_random.o
CC build/bootloader/bootloader_support/src/flash_encrypt.o
CC build/bootloader/bootloader_support/src/esp_image_format.o
CC build/bootloader/bootloader_support/src/flash_partitions.o
CC build/bootloader/bootloader_support/src/bootloader_clock.o
CC build/bootloader/bootloader_support/src/bootloader_common.o
CC build/bootloader/bootloader_support/src/bootloader_utility.o
CC build/bootloader/bootloader_support/src/bootloader_init.o
CC build/bootloader/bootloader_support/src/flash_qio_mode.o
CC build/bootloader/bootloader_support/src/bootloader_flash.o
CC build/bootloader/bootloader_support/src/esp32/flash_encrypt.o
CC build/bootloader/bootloader_support/src/esp32/bootloader_sha.o
CC build/bootloader/bootloader_support/src/esp32/secure_boot.o
CC build/bootloader/bootloader_support/src/esp32/secure_boot_signatures.o
AR build/bootloader/bootloader_support/libbootloader_support.a
CC build/bootloader/log/log.o
AR build/bootloader/log/liblog.a
CC build/bootloader/spi_flash/spi_flash_rom_patch.o
AR build/bootloader/spi_flash/libspi_flash.a
CC build/bootloader/micro-ecc/micro-ecc/uECC.o
AR build/bootloader/micro-ecc/libmicro-ecc.a
CC build/bootloader/soc/esp32/emac_hal.o
CC build/bootloader/soc/esp32/rtc_clk.o
CC build/bootloader/soc/esp32/rtc_time.o
CC build/bootloader/soc/esp32/rtc_sleep.o
CC build/bootloader/soc/esp32/gpio_periph.o
CC build/bootloader/soc/esp32/rtc_clk_init.o
CC build/bootloader/soc/esp32/spi_periph.o
CC build/bootloader/soc/esp32/rtc_init.o
CC build/bootloader/soc/esp32/sdio_slave_periph.o
CC build/bootloader/soc/esp32/rtc_wdt.o
CC build/bootloader/soc/esp32/sdmmc_periph.o
CC build/bootloader/soc/esp32/cpu_util.o
CC build/bootloader/soc/esp32/rtc_periph.o
CC build/bootloader/soc/esp32/rtc_pm.o
CC build/bootloader/soc/esp32/soc_memory_layout.o
CC build/bootloader/soc/src/soc_include_legacy_warn.o
CC build/bootloader/soc/src/memory_layout_utils.o
CC build/bootloader/soc/src/lldesc.o
CC build/bootloader/soc/src/hal/spi_hal.o
CC build/bootloader/soc/src/hal/spi_hal_iram.o
CC build/bootloader/soc/src/hal/spi_flash_hal.o
CC build/bootloader/soc/src/hal/spi_flash_hal_iram.o
CC build/bootloader/soc/src/hal/spi_slave_hal.o
CC build/bootloader/soc/src/hal/spi_slave_hal_iram.o
AR build/bootloader/soc/libsoc.a
CC build/bootloader/main/bootloader_start.o
AR build/bootloader/main/libmain.a
CC build/bootloader/efuse/esp32/esp_efuse_table.o
CC build/bootloader/efuse/src/esp_efuse_fields.o
CC build/bootloader/efuse/src/esp_efuse_utility.o
CC build/bootloader/efuse/src/esp_efuse_api.o
AR build/bootloader/efuse/libefuse.a
LD build/bootloader/bootloader.elf
esptool.py v2.7-dev
building AT customized partition table module_config/module_esp32_default/at_customize.csv
building AT customized partition table succeed
generating AT customized partition bins to /home/micka/esp/esp32-at/build/customized_partitions
generating ble_data.bin: python /home/micka/esp/esp32-at/tools/BLEService.py -t /home/micka/esp/esp32-at/build/customized_partitions/ble_data.bin /home/micka/esp/esp32-at/components/customized_partitions/raw_data/ble_data/example.csv
C:/msys32/home/micka/esp/esp32-at/tools/BLEService.py:357: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
  config = yaml.load(cf)
AT customized partitions successfully generated: ble_data
generating server_cert.bin: python /home/micka/esp/esp32-at/tools/AtPKI.py generate_bin -b /home/micka/esp/esp32-at/build/customized_partitions/server_cert cert /home/micka/esp/esp32-at/components/customized_partitions/raw_data/server_cert/server_cert.crt
AT customized partitions successfully generated: server_cert
generating server_key.bin: python /home/micka/esp/esp32-at/tools/AtPKI.py generate_bin -b /home/micka/esp/esp32-at/build/customized_partitions/server_key key /home/micka/esp/esp32-at/components/customized_partitions/raw_data/server_key/server.key
AT customized partitions successfully generated: server_key
generating server_ca.bin: python /home/micka/esp/esp32-at/tools/AtPKI.py generate_bin -b /home/micka/esp/esp32-at/build/customized_partitions/server_ca ca /home/micka/esp/esp32-at/components/customized_partitions/raw_data/server_ca/server_ca.crt
AT customized partitions successfully generated: server_ca
generating client_cert.bin: python /home/micka/esp/esp32-at/tools/AtPKI.py generate_bin -b /home/micka/esp/esp32-at/build/customized_partitions/client_cert cert /home/micka/esp/esp32-at/components/customized_partitions/raw_data/client_cert/client_cert_00.crt cert /home/micka/esp/esp32-at/components/customized_partitions/raw_data/client_cert/client_cert_01.crt
AT customized partitions successfully generated: client_cert
generating client_key.bin: python /home/micka/esp/esp32-at/tools/AtPKI.py generate_bin -b /home/micka/esp/esp32-at/build/customized_partitions/client_key key /home/micka/esp/esp32-at/components/customized_partitions/raw_data/client_key/client_key_00.key key /home/micka/esp/esp32-at/components/customized_partitions/raw_data/client_key/client_key_01.key
AT customized partitions successfully generated: client_key
generating client_ca.bin: python /home/micka/esp/esp32-at/tools/AtPKI.py generate_bin -b /home/micka/esp/esp32-at/build/customized_partitions/client_ca ca /home/micka/esp/esp32-at/components/customized_partitions/raw_data/client_ca/client_ca_00.crt ca /home/micka/esp/esp32-at/components/customized_partitions/raw_data/client_ca/client_ca_01.crt
AT customized partitions successfully generated: client_ca
generating factory_param.bin(): python /home/micka/esp/esp32-at/tools/factory_param_generate.py -t /home/micka/esp/esp32-at/build/customized_partitions/factory_param.bin /home/micka/esp/esp32-at/components/customized_partitions/raw_data/factory_param/factory_param_data.csv
generate parameter bin: platform PLATFORM_ESP32, module name WROOM-32
generate parameter bin: platform PLATFORM_ESP32, module name WROVER-32
generate parameter bin: platform PLATFORM_ESP32, module name PICO-D4
generate parameter bin: platform PLATFORM_ESP32, module name SOLO-1
AT customized partitions successfully generated: factory_param
AT customized bin generation finished
Building partitions from /home/micka/esp/esp32-at/module_config/module_esp32_default/partitions_at.csv...
CC build/app_trace/heap_trace_tohost.o
CC build/app_trace/app_trace.o
CC build/app_trace/host_file_io.o
CC build/app_trace/app_trace_util.o
CC build/app_trace/gcov/gcov_rtio.o
AR build/app_trace/libapp_trace.a
App "esp-at" version: ESP-AT
CC build/app_update/esp_app_desc.o
CC build/app_update/esp_ota_ops.o
AR build/app_update/libapp_update.a
CXX build/asio/asio/asio/src/asio.o
AR build/asio/libasio.a
AR build/at/libat.a
CC build/bootloader_support/src/bootloader_random.o
CC build/bootloader_support/src/flash_encrypt.o
CC build/bootloader_support/src/esp_image_format.o
CC build/bootloader_support/src/flash_partitions.o
CC build/bootloader_support/src/bootloader_clock.o
CC build/bootloader_support/src/bootloader_common.o
CC build/bootloader_support/src/bootloader_utility.o
CC build/bootloader_support/src/flash_qio_mode.o
CC build/bootloader_support/src/bootloader_flash.o
CC build/bootloader_support/src/idf/bootloader_sha.o
CC build/bootloader_support/src/idf/secure_boot_signatures.o
AR build/bootloader_support/libbootloader_support.a
CC build/bt/controller/bt.o
CC build/bt/host/bluedroid/bta/dm/bta_dm_cfg.o
CC build/bt/host/bluedroid/bta/dm/bta_dm_main.o
CC build/bt/host/bluedroid/bta/dm/bta_dm_pm.o
CC build/bt/host/bluedroid/bta/dm/bta_dm_act.o
CC build/bt/host/bluedroid/bta/dm/bta_dm_ci.o
CC build/bt/host/bluedroid/bta/dm/bta_dm_co.o
CC build/bt/host/bluedroid/bta/dm/bta_dm_sco.o
CC build/bt/host/bluedroid/bta/dm/bta_dm_api.o
CC build/bt/host/bluedroid/bta/gatt/bta_gatts_utils.o
CC build/bt/host/bluedroid/bta/gatt/bta_gattc_act.o
CC build/bt/host/bluedroid/bta/gatt/bta_gattc_ci.o
CC build/bt/host/bluedroid/bta/gatt/bta_gatts_act.o
CC build/bt/host/bluedroid/bta/gatt/bta_gattc_utils.o
CC build/bt/host/bluedroid/bta/gatt/bta_gatts_co.o
CC build/bt/host/bluedroid/bta/gatt/bta_gattc_api.o
CC build/bt/host/bluedroid/bta/gatt/bta_gatts_main.o
CC build/bt/host/bluedroid/bta/gatt/bta_gattc_cache.o
CC build/bt/host/bluedroid/bta/gatt/bta_gattc_co.o
CC build/bt/host/bluedroid/bta/gatt/bta_gatts_api.o
CC build/bt/host/bluedroid/bta/gatt/bta_gatt_common.o
CC build/bt/host/bluedroid/bta/gatt/bta_gattc_main.o
CC build/bt/host/bluedroid/bta/hh/bta_hh_cfg.o
CC build/bt/host/bluedroid/bta/hh/bta_hh_main.o
CC build/bt/host/bluedroid/bta/hh/bta_hh_act.o
CC build/bt/host/bluedroid/bta/hh/bta_hh_le.o
CC build/bt/host/bluedroid/bta/hh/bta_hh_utils.o
CC build/bt/host/bluedroid/bta/hh/bta_hh_api.o
CC build/bt/host/bluedroid/bta/sdp/bta_sdp_api.o
CC build/bt/host/bluedroid/bta/sdp/bta_sdp_cfg.o
CC build/bt/host/bluedroid/bta/sdp/bta_sdp_act.o
CC build/bt/host/bluedroid/bta/sdp/bta_sdp.o
CC build/bt/host/bluedroid/bta/av/bta_av_aact.o
CC build/bt/host/bluedroid/bta/av/bta_av_sbc.o
CC build/bt/host/bluedroid/bta/av/bta_av_main.o
CC build/bt/host/bluedroid/bta/av/bta_av_act.o
CC build/bt/host/bluedroid/bta/av/bta_av_ci.o
CC build/bt/host/bluedroid/bta/av/bta_av_cfg.o
CC build/bt/host/bluedroid/bta/av/bta_av_ssm.o
CC build/bt/host/bluedroid/bta/av/bta_av_api.o
CC build/bt/host/bluedroid/bta/ar/bta_ar.o
CC build/bt/host/bluedroid/bta/sys/bta_sys_conn.o
CC build/bt/host/bluedroid/bta/sys/utl.o
CC build/bt/host/bluedroid/bta/sys/bta_sys_main.o
CC build/bt/host/bluedroid/bta/jv/bta_jv_cfg.o
CC build/bt/host/bluedroid/bta/jv/bta_jv_main.o
CC build/bt/host/bluedroid/bta/jv/bta_jv_act.o
CC build/bt/host/bluedroid/bta/jv/bta_jv_api.o
CC build/bt/host/bluedroid/bta/hf_client/bta_hf_client_cmd.o
CC build/bt/host/bluedroid/bta/hf_client/bta_hf_client_at.o
CC build/bt/host/bluedroid/bta/hf_client/bta_hf_client_main.o
CC build/bt/host/bluedroid/bta/hf_client/bta_hf_client_act.o
CC build/bt/host/bluedroid/bta/hf_client/bta_hf_client_sdp.o
CC build/bt/host/bluedroid/bta/hf_client/bta_hf_client_sco.o
CC build/bt/host/bluedroid/bta/hf_client/bta_hf_client_api.o
CC build/bt/host/bluedroid/bta/hf_client/bta_hf_client_rfc.o
CC build/bt/host/bluedroid/device/controller.o
CC build/bt/host/bluedroid/device/bdaddr.o
CC build/bt/host/bluedroid/device/interop.o
CC build/bt/host/bluedroid/hci/hci_packet_factory.o
CC build/bt/host/bluedroid/hci/hci_layer.o
CC build/bt/host/bluedroid/hci/packet_fragmenter.o
CC build/bt/host/bluedroid/hci/hci_audio.o
CC build/bt/host/bluedroid/hci/hci_packet_parser.o
CC build/bt/host/bluedroid/hci/hci_hal_h4.o
CC build/bt/host/bluedroid/main/bte_init.o
CC build/bt/host/bluedroid/main/bte_main.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/decoder-sbc.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/bitalloc-sbc.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/oi_codec_version.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/framing-sbc.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/synthesis-8-generated.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/decoder-private.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/bitalloc.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/alloc.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/dequant.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/framing.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/synthesis-dct8.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/decoder-oina.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/synthesis-sbc.o
CC build/bt/host/bluedroid/external/sbc/decoder/srce/bitstream-decode.o
CC build/bt/host/bluedroid/external/sbc/encoder/srce/sbc_encoder.o
CC build/bt/host/bluedroid/external/sbc/encoder/srce/sbc_dct_coeffs.o
CC build/bt/host/bluedroid/external/sbc/encoder/srce/sbc_enc_bit_alloc_mono.o
CC build/bt/host/bluedroid/external/sbc/encoder/srce/sbc_enc_coeffs.o
CC build/bt/host/bluedroid/external/sbc/encoder/srce/sbc_analysis.o
CC build/bt/host/bluedroid/external/sbc/encoder/srce/sbc_enc_bit_alloc_ste.o
CC build/bt/host/bluedroid/external/sbc/encoder/srce/sbc_dct.o
CC build/bt/host/bluedroid/external/sbc/encoder/srce/sbc_packing.o
CC build/bt/host/bluedroid/external/sbc/plc/sbc_plc.o
CC build/bt/host/bluedroid/btc/core/btc_dm.o
CC build/bt/host/bluedroid/btc/core/btc_config.o
CC build/bt/host/bluedroid/btc/core/btc_sec.o
CC build/bt/host/bluedroid/btc/core/btc_profile_queue.o
CC build/bt/host/bluedroid/btc/core/btc_sm.o
CC build/bt/host/bluedroid/btc/core/btc_ble_storage.o
CC build/bt/host/bluedroid/btc/core/btc_storage.o
CC build/bt/host/bluedroid/btc/core/btc_dev.o
CC build/bt/host/bluedroid/btc/core/btc_main.o
CC build/bt/host/bluedroid/btc/core/btc_util.o
CC build/bt/host/bluedroid/btc/profile/esp/blufi/blufi_protocol.o
CC build/bt/host/bluedroid/btc/profile/esp/blufi/blufi_prf.o
CC build/bt/host/bluedroid/btc/profile/std/gap/bta_gap_bt_co.o
CC build/bt/host/bluedroid/btc/profile/std/gap/btc_gap_ble.o
CC build/bt/host/bluedroid/btc/profile/std/gap/btc_gap_bt.o
CC build/bt/host/bluedroid/btc/profile/std/gatt/btc_gatt_common.o
CC build/bt/host/bluedroid/btc/profile/std/gatt/btc_gattc.o
CC build/bt/host/bluedroid/btc/profile/std/gatt/btc_gatt_util.o
CC build/bt/host/bluedroid/btc/profile/std/gatt/btc_gatts.o
CC build/bt/host/bluedroid/btc/profile/std/a2dp/btc_a2dp_control.o
CC build/bt/host/bluedroid/btc/profile/std/a2dp/btc_av.o
CC build/bt/host/bluedroid/btc/profile/std/a2dp/bta_av_co.o
CC build/bt/host/bluedroid/btc/profile/std/a2dp/btc_a2dp.o
CC build/bt/host/bluedroid/btc/profile/std/a2dp/btc_a2dp_source.o
CC build/bt/host/bluedroid/btc/profile/std/a2dp/btc_a2dp_sink.o
CC build/bt/host/bluedroid/btc/profile/std/avrc/bta_avrc_co.o
CC build/bt/host/bluedroid/btc/profile/std/avrc/btc_avrc.o
CC build/bt/host/bluedroid/btc/profile/std/spp/btc_spp.o
CC build/bt/host/bluedroid/btc/profile/std/hf_client/btc_hf_client.o
CC build/bt/host/bluedroid/btc/profile/std/hf_client/bta_hf_client_co.o
CC build/bt/host/bluedroid/stack/btm/btm_devctl.o
CC build/bt/host/bluedroid/stack/btm/btm_sco.o
CC build/bt/host/bluedroid/stack/btm/btm_ble_addr.o
CC build/bt/host/bluedroid/stack/btm/btm_ble_multi_adv.o
CC build/bt/host/bluedroid/stack/btm/btm_ble_gap.o
CC build/bt/host/bluedroid/stack/btm/btm_ble_bgconn.o
CC build/bt/host/bluedroid/stack/btm/btm_acl.o
CC build/bt/host/bluedroid/stack/btm/btm_ble_privacy.o
CC build/bt/host/bluedroid/stack/btm/btm_dev.o
CC build/bt/host/bluedroid/stack/btm/btm_main.o
CC build/bt/host/bluedroid/stack/btm/btm_inq.o
CC build/bt/host/bluedroid/stack/btm/btm_ble_adv_filter.o
CC build/bt/host/bluedroid/stack/btm/btm_pm.o
CC build/bt/host/bluedroid/stack/btm/btm_ble.o
CC build/bt/host/bluedroid/stack/btm/btm_sec.o
CC build/bt/host/bluedroid/stack/btm/btm_ble_cont_energy.o
CC build/bt/host/bluedroid/stack/btm/btm_ble_batchscan.o
CC build/bt/host/bluedroid/stack/btu/btu_init.o
CC build/bt/host/bluedroid/stack/btu/btu_task.o
CC build/bt/host/bluedroid/stack/btu/btu_hcif.o
CC build/bt/host/bluedroid/stack/gap/gap_utils.o
CC build/bt/host/bluedroid/stack/gap/gap_api.o
CC build/bt/host/bluedroid/stack/gap/gap_conn.o
CC build/bt/host/bluedroid/stack/gap/gap_ble.o
CC build/bt/host/bluedroid/stack/gatt/gatt_utils.o
CC build/bt/host/bluedroid/stack/gatt/gatt_api.o
CC build/bt/host/bluedroid/stack/gatt/gatt_auth.o
CC build/bt/host/bluedroid/stack/gatt/att_protocol.o
CC build/bt/host/bluedroid/stack/gatt/gatt_sr.o
CC build/bt/host/bluedroid/stack/gatt/gatt_main.o
CC build/bt/host/bluedroid/stack/gatt/gatt_attr.o
CC build/bt/host/bluedroid/stack/gatt/gatt_cl.o
CC build/bt/host/bluedroid/stack/gatt/gatt_db.o
CC build/bt/host/bluedroid/stack/hcic/hcicmds.o
CC build/bt/host/bluedroid/stack/hcic/hciblecmds.o
CC build/bt/host/bluedroid/stack/l2cap/l2c_api.o
CC build/bt/host/bluedroid/stack/l2cap/l2c_ble.o
CC build/bt/host/bluedroid/stack/l2cap/l2c_link.o
CC build/bt/host/bluedroid/stack/l2cap/l2c_fcr.o
CC build/bt/host/bluedroid/stack/l2cap/l2c_csm.o
CC build/bt/host/bluedroid/stack/l2cap/l2cap_client.o
CC build/bt/host/bluedroid/stack/l2cap/l2c_ucd.o
CC build/bt/host/bluedroid/stack/l2cap/l2c_main.o
CC build/bt/host/bluedroid/stack/l2cap/l2c_utils.o
CC build/bt/host/bluedroid/stack/sdp/sdp_api.o
CC build/bt/host/bluedroid/stack/sdp/sdp_server.o
CC build/bt/host/bluedroid/stack/sdp/sdp_main.o
CC build/bt/host/bluedroid/stack/sdp/sdp_discovery.o
CC build/bt/host/bluedroid/stack/sdp/sdp_db.o
CC build/bt/host/bluedroid/stack/sdp/sdp_utils.o
CC build/bt/host/bluedroid/stack/smp/smp_l2c.o
CC build/bt/host/bluedroid/stack/smp/p_256_multprecision.o
CC build/bt/host/bluedroid/stack/smp/smp_cmac.o
CC build/bt/host/bluedroid/stack/smp/aes.o
CC build/bt/host/bluedroid/stack/smp/smp_br_main.o
CC build/bt/host/bluedroid/stack/smp/smp_keys.o
CC build/bt/host/bluedroid/stack/smp/smp_act.o
CC build/bt/host/bluedroid/stack/smp/p_256_ecc_pp.o
CC build/bt/host/bluedroid/stack/smp/smp_utils.o
CC build/bt/host/bluedroid/stack/smp/smp_api.o
CC build/bt/host/bluedroid/stack/smp/p_256_curvepara.o
CC build/bt/host/bluedroid/stack/smp/smp_main.o
CC build/bt/host/bluedroid/stack/avct/avct_ccb.o
CC build/bt/host/bluedroid/stack/avct/avct_api.o
CC build/bt/host/bluedroid/stack/avct/avct_l2c.o
CC build/bt/host/bluedroid/stack/avct/avct_lcb_act.o
CC build/bt/host/bluedroid/stack/avct/avct_lcb.o
CC build/bt/host/bluedroid/stack/avrc/avrc_sdp.o
CC build/bt/host/bluedroid/stack/avrc/avrc_utils.o
CC build/bt/host/bluedroid/stack/avrc/avrc_api.o
CC build/bt/host/bluedroid/stack/avrc/avrc_bld_tg.o
CC build/bt/host/bluedroid/stack/avrc/avrc_pars_tg.o
CC build/bt/host/bluedroid/stack/avrc/avrc_bld_ct.o
CC build/bt/host/bluedroid/stack/avrc/avrc_opt.o
CC build/bt/host/bluedroid/stack/avrc/avrc_pars_ct.o
CC build/bt/host/bluedroid/stack/avdt/avdt_ad.o
CC build/bt/host/bluedroid/stack/avdt/avdt_scb_act.o
CC build/bt/host/bluedroid/stack/avdt/avdt_msg.o
CC build/bt/host/bluedroid/stack/avdt/avdt_scb.o
CC build/bt/host/bluedroid/stack/avdt/avdt_ccb_act.o
CC build/bt/host/bluedroid/stack/avdt/avdt_ccb.o
CC build/bt/host/bluedroid/stack/avdt/avdt_api.o
CC build/bt/host/bluedroid/stack/avdt/avdt_l2c.o
CC build/bt/host/bluedroid/stack/a2dp/a2d_api.o
CC build/bt/host/bluedroid/stack/a2dp/a2d_sbc.o
CC build/bt/host/bluedroid/stack/rfcomm/rfc_utils.o
CC build/bt/host/bluedroid/stack/rfcomm/rfc_ts_frames.o
CC build/bt/host/bluedroid/stack/rfcomm/rfc_l2cap_if.o
CC build/bt/host/bluedroid/stack/rfcomm/port_utils.o
CC build/bt/host/bluedroid/stack/rfcomm/port_api.o
CC build/bt/host/bluedroid/stack/rfcomm/port_rfc.o
CC build/bt/host/bluedroid/stack/rfcomm/rfc_mx_fsm.o
CC build/bt/host/bluedroid/stack/rfcomm/rfc_port_fsm.o
CC build/bt/host/bluedroid/stack/rfcomm/rfc_port_if.o
CC build/bt/host/bluedroid/api/esp_hf_client_api.o
CC build/bt/host/bluedroid/api/esp_gatt_common_api.o
CC build/bt/host/bluedroid/api/esp_gatts_api.o
CC build/bt/host/bluedroid/api/esp_gap_ble_api.o
CC build/bt/host/bluedroid/api/esp_blufi_api.o
CC build/bt/host/bluedroid/api/esp_gattc_api.o
CC build/bt/host/bluedroid/api/esp_a2dp_api.o
CC build/bt/host/bluedroid/api/esp_gap_bt_api.o
CC build/bt/host/bluedroid/api/esp_bt_device.o
CC build/bt/host/bluedroid/api/esp_bt_main.o
CC build/bt/host/bluedroid/api/esp_spp_api.o
CC build/bt/host/bluedroid/api/esp_avrc_api.o
CC build/bt/common/osi/allocator.o
CC build/bt/common/osi/thread.o
CC build/bt/common/osi/buffer.o
CC build/bt/common/osi/alarm.o
CC build/bt/common/osi/hash_functions.o
CC build/bt/common/osi/osi.o
CC build/bt/common/osi/mutex.o
CC build/bt/common/osi/list.o
CC build/bt/common/osi/config.o
CC build/bt/common/osi/fixed_queue.o
CC build/bt/common/osi/hash_map.o
CC build/bt/common/osi/semaphore.o
CC build/bt/common/osi/future.o
CC build/bt/common/btc/core/btc_manage.o
CC build/bt/common/btc/core/btc_alarm.o
CC build/bt/common/btc/core/btc_task.o
AR build/bt/libbt.a
CC build/coap/libcoap/src/address.o
CC build/coap/libcoap/src/async.o
CC build/coap/libcoap/src/block.o
CC build/coap/libcoap/src/coap_event.o
CC build/coap/libcoap/src/coap_hashkey.o
CC build/coap/libcoap/src/coap_session.o
CC build/coap/libcoap/src/coap_time.o
CC build/coap/libcoap/src/coap_debug.o
CC build/coap/libcoap/src/encode.o
CC build/coap/libcoap/src/mem.o
CC build/coap/libcoap/src/net.o
CC build/coap/libcoap/src/option.o
CC build/coap/libcoap/src/pdu.o
CC build/coap/libcoap/src/resource.o
CC build/coap/libcoap/src/str.o
CC build/coap/libcoap/src/subscribe.o
CC build/coap/libcoap/src/uri.o
CC build/coap/libcoap/src/coap_notls.o
CC build/coap/port/coap_io.o
AR build/coap/libcoap.a
CC build/console/linenoise/linenoise.o
CC build/console/argtable3/argtable3.o
CC build/console/commands.o
CC build/console/split_argv.o
AR build/console/libconsole.a
AR build/customized_partitions/libcustomized_partitions.a
CXX build/cxx/cxx_exception_stubs.o
CXX build/cxx/cxx_guards.o
AR build/cxx/libcxx.a
CC build/driver/rtc_module.o
CC build/driver/i2c.o
CC build/driver/sdmmc_host.o
CC build/driver/spi_slave.o
CC build/driver/can.o
CC build/driver/sdmmc_transaction.o
CC build/driver/mcpwm.o
CC build/driver/rmt.o
CC build/driver/sdspi_crc.o
CC build/driver/pcnt.o
CC build/driver/timer.o
CC build/driver/gpio.o
CC build/driver/sdspi_host.o
CC build/driver/uart.o
CC build/driver/ledc.o
CC build/driver/periph_ctrl.o
CC build/driver/i2s.o
CC build/driver/sdio_slave.o
CC build/driver/sdspi_transaction.o
CC build/driver/sigmadelta.o
CC build/driver/spi_master.o
CC build/driver/spi_common.o
AR build/driver/libdriver.a
CC build/efuse/esp32/esp_efuse_table.o
CC build/efuse/src/esp_efuse_fields.o
CC build/efuse/src/esp_efuse_utility.o
CC build/efuse/src/esp_efuse_api.o
AR build/efuse/libefuse.a
CC build/esp-tls/esp_tls.o
AR build/esp-tls/libesp-tls.a
CC build/esp32/int_wdt.o
CC build/esp32/brownout.o
CC build/esp32/system_api.o
CC build/esp32/esp_himem.o
CC build/esp32/dport_access.o
CC build/esp32/hw_random.o
CC build/esp32/pm_esp32.o
CC build/esp32/reset_reason.o
CC build/esp32/intr_alloc.o
CC build/esp32/cache_err_int.o
CC build/esp32/spiram.o
CC build/esp32/clk.o
CC build/esp32/spiram_psram.o
CC build/esp32/esp_timer_esp32.o
CC build/esp32/pm_trace.o
CC build/esp32/crosscore_int.o
CC build/esp32/cache_sram_mmu.o
CC build/esp32/cpu_start.o
CC build/esp32/sleep_modes.o
CC build/esp32/task_wdt.o
CC build/esp32/esp_adapter.o
CC build/esp32/panic.o
AS build/esp32/dport_panic_highint_hdl.o
AR build/esp32/libesp32.a
CC build/esp_adc_cal/esp_adc_cal.o
AR build/esp_adc_cal/libesp_adc_cal.a
CC build/esp_common/src/esp_timer.o
CC build/esp_common/src/stack_check.o
CC build/esp_common/src/esp_err_to_name.o
CC build/esp_common/src/pm_locks.o
CC build/esp_common/src/ipc.o
CC build/esp_common/src/ets_timer_legacy.o
CC build/esp_common/src/freertos_hooks.o
CC build/esp_common/src/dbg_stubs.o
AR build/esp_common/libesp_common.a
CC build/esp_eth/src/esp_eth_phy_rtl8201.o
CC build/esp_eth/src/esp_eth_phy_dm9051.o
CC build/esp_eth/src/esp_eth_phy_dp83848.o
CC build/esp_eth/src/esp_eth_mac_dm9051.o
CC build/esp_eth/src/esp_eth.o
CC build/esp_eth/src/esp_eth_mac_esp32.o
CC build/esp_eth/src/esp_eth_phy_ip101.o
CC build/esp_eth/src/esp_eth_phy_lan8720.o
AR build/esp_eth/libesp_eth.a
CC build/esp_event/esp_event_private.o
CC build/esp_event/event_loop_legacy.o
CC build/esp_event/esp_event.o
CC build/esp_event/event_send.o
CC build/esp_event/default_event_loop.o
AR build/esp_event/libesp_event.a
CC build/esp_gdbstub/src/gdbstub.o
CC build/esp_gdbstub/src/packet.o
CC build/esp_gdbstub/esp32/gdbstub_esp32.o
CC build/esp_gdbstub/xtensa/gdbstub_xtensa.o
AR build/esp_gdbstub/libesp_gdbstub.a
CC build/esp_http_client/esp_http_client.o
CC build/esp_http_client/lib/http_utils.o
CC build/esp_http_client/lib/http_auth.o
CC build/esp_http_client/lib/http_header.o
AR build/esp_http_client/libesp_http_client.a
CC build/esp_http_server/src/httpd_sess.o
CC build/esp_http_server/src/httpd_parse.o
CC build/esp_http_server/src/httpd_uri.o
CC build/esp_http_server/src/httpd_txrx.o
CC build/esp_http_server/src/httpd_main.o
CC build/esp_http_server/src/util/ctrl_sock.o
AR build/esp_http_server/libesp_http_server.a
CC build/esp_https_ota/src/esp_https_ota.o
AR build/esp_https_ota/libesp_https_ota.a
CC build/esp_local_ctrl/src/esp_local_ctrl_transport_ble.o
CC build/esp_local_ctrl/src/esp_local_ctrl.o
CC build/esp_local_ctrl/src/esp_local_ctrl_handler.o
CC build/esp_local_ctrl/proto-c/esp_local_ctrl.pb-c.o
AR build/esp_local_ctrl/libesp_local_ctrl.a
CC build/esp_ringbuf/ringbuf.o
AR build/esp_ringbuf/libesp_ringbuf.a
CC build/esp_rom/esp_rom.o
AR build/esp_rom/libesp_rom.a
CC build/esp_websocket_client/esp_websocket_client.o
AR build/esp_websocket_client/libesp_websocket_client.a
CC build/esp_wifi/src/wifi_init.o
CC build/esp_wifi/src/coexist.o
CC build/esp_wifi/src/crypto_ops.o
CC build/esp_wifi/src/mesh_event.o
CC build/esp_wifi/src/phy_init.o
CC build/esp_wifi/src/restore.o
CC build/esp_wifi/src/smartconfig.o
CC build/esp_wifi/src/lib_printf.o
AR build/esp_wifi/libesp_wifi.a
CC build/espcoredump/src/core_dump_uart.o
CC build/espcoredump/src/core_dump_common.o
CC build/espcoredump/src/core_dump_flash.o
CC build/espcoredump/src/core_dump_port.o
AR build/espcoredump/libespcoredump.a
CC build/expat/expat/expat/lib/xmltok_impl.o
CC build/expat/expat/expat/lib/xmlrole.o
CC build/expat/expat/expat/lib/xmlparse.o
CC build/expat/expat/expat/lib/xmltok.o
CC build/expat/expat/expat/lib/xmltok_ns.o
CC build/expat/expat/expat/lib/loadlibrary.o
AR build/expat/libexpat.a
CC build/fatfs/diskio/diskio.o
CC build/fatfs/diskio/diskio_sdmmc.o
CC build/fatfs/diskio/diskio_rawflash.o
CC build/fatfs/diskio/diskio_wl.o
CC build/fatfs/vfs/vfs_fat.o
CC build/fatfs/vfs/vfs_fat_spiflash.o
CC build/fatfs/vfs/vfs_fat_sdmmc.o
CC build/fatfs/port/freertos/ffsystem.o
CC build/fatfs/src/ffunicode.o
CC build/fatfs/src/ff.o
AR build/fatfs/libfatfs.a
CC build/freemodbus/common/esp_modbus_slave.o
CC build/freemodbus/common/esp_modbus_master.o
CC build/freemodbus/modbus/mb.o
CC build/freemodbus/modbus/mb_m.o
CC build/freemodbus/modbus/ascii/mbascii.o
CC build/freemodbus/modbus/functions/mbutils.o
CC build/freemodbus/modbus/functions/mbfuncholding_m.o
CC build/freemodbus/modbus/functions/mbfunccoils_m.o
CC build/freemodbus/modbus/functions/mbfunccoils.o
CC build/freemodbus/modbus/functions/mbfuncdisc_m.o
CC build/freemodbus/modbus/functions/mbfuncdiag.o
CC build/freemodbus/modbus/functions/mbfuncother.o
CC build/freemodbus/modbus/functions/mbfuncdisc.o
CC build/freemodbus/modbus/functions/mbfuncinput_m.o
CC build/freemodbus/modbus/functions/mbfuncinput.o
CC build/freemodbus/modbus/functions/mbfuncholding.o
CC build/freemodbus/modbus/rtu/mbrtu.o
CC build/freemodbus/modbus/rtu/mbcrc.o
CC build/freemodbus/modbus/rtu/mbrtu_m.o
CC build/freemodbus/modbus/tcp/mbtcp.o
CC build/freemodbus/serial_slave/modbus_controller/mbc_serial_slave.o
CC build/freemodbus/serial_master/modbus_controller/mbc_serial_master.o
CC build/freemodbus/port/portevent.o
CC build/freemodbus/port/portserial.o
CC build/freemodbus/port/porttimer.o
CC build/freemodbus/port/port.o
CC build/freemodbus/port/portother.o
CC build/freemodbus/port/portserial_m.o
CC build/freemodbus/port/porttimer_m.o
CC build/freemodbus/port/portother_m.o
CC build/freemodbus/port/portevent_m.o
AR build/freemodbus/libfreemodbus.a
CC build/freertos/xtensa_overlay_os_hook.o
CC build/freertos/FreeRTOS-openocd.o
CC build/freertos/timers.o
CC build/freertos/tasks.o
CC build/freertos/event_groups.o
CC build/freertos/port.o
CC build/freertos/xtensa_init.o
CC build/freertos/list.o
CC build/freertos/croutine.o
CC build/freertos/queue.o
CC build/freertos/xtensa_intr.o
AS build/freertos/portasm.o
AS build/freertos/xtensa_vector_defaults.o
AS build/freertos/xtensa_vectors.o
AS build/freertos/xtensa_context.o
AS build/freertos/xtensa_intr_asm.o
AR build/freertos/libfreertos.a
CC build/heap/heap_caps_init.o
CC build/heap/heap_caps.o
CC build/heap/multi_heap.o
AR build/heap/libheap.a
AR build/idf_test/libidf_test.a
CC build/jsmn/src//jsmn.o
AR build/jsmn/libjsmn.a
CC build/json/cJSON/cJSON.o
CC build/json/cJSON/cJSON_Utils.o
AR build/json/libjson.a
CC build/libsodium/port/randombytes_esp32.o
CC build/libsodium/libsodium/src/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_aead/xchacha20poly1305/sodium/aead_xchacha20poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_auth/crypto_auth.o
CC build/libsodium/libsodium/src/libsodium/crypto_auth/hmacsha256/auth_hmacsha256.o
CC build/libsodium/libsodium/src/libsodium/crypto_auth/hmacsha512/auth_hmacsha512.o
CC build/libsodium/libsodium/src/libsodium/crypto_auth/hmacsha512256/auth_hmacsha512256.o
CC build/libsodium/libsodium/src/libsodium/crypto_box/crypto_box_easy.o
CC build/libsodium/libsodium/src/libsodium/crypto_box/crypto_box.o
CC build/libsodium/libsodium/src/libsodium/crypto_box/crypto_box_seal.o
CC build/libsodium/libsodium/src/libsodium/crypto_box/curve25519xsalsa20poly1305/box_curve25519xsalsa20poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/curve25519/ref10/curve25519_ref10.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/hchacha20/core_hchacha20.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/hsalsa20/ref2/core_hsalsa20_ref2.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/hsalsa20/core_hsalsa20.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/salsa/ref/core_salsa_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/crypto_generichash.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/generichash_blake2.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-sse41.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ssse3.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/generichash_blake2b.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-avx2.o
CC build/libsodium/libsodium/src/libsodium/crypto_hash/crypto_hash.o
CC build/libsodium/libsodium/src/libsodium/crypto_hash/sha256/hash_sha256.o
CC build/libsodium/libsodium/src/libsodium/crypto_hash/sha512/hash_sha512.o
CC build/libsodium/libsodium/src/libsodium/crypto_kdf/blake2b/kdf_blake2b.o
CC build/libsodium/libsodium/src/libsodium/crypto_kdf/crypto_kdf.o
CC build/libsodium/libsodium/src/libsodium/crypto_kx/crypto_kx.o
CC build/libsodium/libsodium/src/libsodium/crypto_onetimeauth/crypto_onetimeauth.o
CC build/libsodium/libsodium/src/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-encoding.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-fill-block-ssse3.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/pwhash_argon2i.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-fill-block-ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/blake2b-long.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-core.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/crypto_pwhash.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/pbkdf2-sha256.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/crypto_scrypt-common.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/pwhash_scryptsalsa208sha256.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/scrypt_platform.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/nosse/pwhash_scryptsalsa208sha256_nosse.o
CC build/libsodium/libsodium/src/libsodium/crypto_scalarmult/crypto_scalarmult.o
CC build/libsodium/libsodium/src/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.o
CC build/libsodium/libsodium/src/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.o
CC build/libsodium/libsodium/src/libsodium/crypto_secretbox/crypto_secretbox.o
CC build/libsodium/libsodium/src/libsodium/crypto_secretbox/crypto_secretbox_easy.o
CC build/libsodium/libsodium/src/libsodium/crypto_secretbox/xsalsa20poly1305/secretbox_xsalsa20poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/crypto_shorthash.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/siphash24/shorthash_siphash24.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/siphash24/shorthash_siphashx24.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/siphash24/ref/shorthash_siphashx24_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/siphash24/ref/shorthash_siphash24_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/crypto_sign.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/sign_ed25519.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/ref10/keypair.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/ref10/open.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/ref10/sign.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/ref10/obsolete.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/chacha20/stream_chacha20.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/chacha20/ref/chacha20_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/crypto_stream.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/salsa20/stream_salsa20.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/salsa20/ref/salsa20_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/xsalsa20/stream_xsalsa20.o
CC build/libsodium/libsodium/src/libsodium/crypto_verify/sodium/verify.o
CC build/libsodium/libsodium/src/libsodium/randombytes/randombytes.o
CC build/libsodium/libsodium/src/libsodium/sodium/utils.o
CC build/libsodium/libsodium/src/libsodium/sodium/runtime.o
CC build/libsodium/libsodium/src/libsodium/sodium/version.o
CC build/libsodium/libsodium/src/libsodium/sodium/core.o
CC build/libsodium/port/crypto_hash_mbedtls/crypto_hash_sha512_mbedtls.o
CC build/libsodium/port/crypto_hash_mbedtls/crypto_hash_sha256_mbedtls.o
AR build/libsodium/liblibsodium.a
CC build/log/log.o
AR build/log/liblog.a
CC build/lwip/apps/dhcpserver/dhcpserver.o
CC build/lwip/apps/ping/esp_ping.o
CC build/lwip/apps/ping/ping.o
CC build/lwip/apps/sntp/sntp.o
CC build/lwip/lwip/src/api/sockets.o
CC build/lwip/lwip/src/api/api_msg.o
CC build/lwip/lwip/src/api/err.o
CC build/lwip/lwip/src/api/if_api.o
CC build/lwip/lwip/src/api/netbuf.o
CC build/lwip/lwip/src/api/tcpip.o
CC build/lwip/lwip/src/api/netifapi.o
CC build/lwip/lwip/src/api/api_lib.o
CC build/lwip/lwip/src/api/netdb.o
CC build/lwip/lwip/src/apps/sntp/sntp.o
CC build/lwip/lwip/src/core/tcp_out.o
CC build/lwip/lwip/src/core/udp.o
CC build/lwip/lwip/src/core/altcp_tcp.o
CC build/lwip/lwip/src/core/def.o
CC build/lwip/lwip/src/core/altcp.o
CC build/lwip/lwip/src/core/stats.o
CC build/lwip/lwip/src/core/netif.o
CC build/lwip/lwip/src/core/pbuf.o
CC build/lwip/lwip/src/core/tcp_in.o
CC build/lwip/lwip/src/core/raw.o
CC build/lwip/lwip/src/core/ip.o
CC build/lwip/lwip/src/core/dns.o
CC build/lwip/lwip/src/core/altcp_alloc.o
CC build/lwip/lwip/src/core/timeouts.o
CC build/lwip/lwip/src/core/tcp.o
CC build/lwip/lwip/src/core/sys.o
CC build/lwip/lwip/src/core/memp.o
CC build/lwip/lwip/src/core/init.o
CC build/lwip/lwip/src/core/inet_chksum.o
CC build/lwip/lwip/src/core/mem.o
CC build/lwip/lwip/src/core/ipv4/icmp.o
CC build/lwip/lwip/src/core/ipv4/autoip.o
CC build/lwip/lwip/src/core/ipv4/ip4.o
CC build/lwip/lwip/src/core/ipv4/igmp.o
CC build/lwip/lwip/src/core/ipv4/ip4_addr.o
CC build/lwip/lwip/src/core/ipv4/etharp.o
CC build/lwip/lwip/src/core/ipv4/dhcp.o
CC build/lwip/lwip/src/core/ipv4/ip4_frag.o
CC build/lwip/lwip/src/core/ipv6/icmp6.o
CC build/lwip/lwip/src/core/ipv6/ethip6.o
CC build/lwip/lwip/src/core/ipv6/mld6.o
CC build/lwip/lwip/src/core/ipv6/nd6.o
CC build/lwip/lwip/src/core/ipv6/ip6.o
CC build/lwip/lwip/src/core/ipv6/ip6_addr.o
CC build/lwip/lwip/src/core/ipv6/inet6.o
CC build/lwip/lwip/src/core/ipv6/dhcp6.o
CC build/lwip/lwip/src/core/ipv6/ip6_frag.o
CC build/lwip/lwip/src/netif/bridgeif.o
CC build/lwip/lwip/src/netif/lowpan6_common.o
CC build/lwip/lwip/src/netif/lowpan6_ble.o
CC build/lwip/lwip/src/netif/lowpan6.o
CC build/lwip/lwip/src/netif/zepif.o
CC build/lwip/lwip/src/netif/bridgeif_fdb.o
CC build/lwip/lwip/src/netif/ethernet.o
CC build/lwip/lwip/src/netif/slipif.o
CC build/lwip/port/esp32/vfs_lwip.o
CC build/lwip/port/esp32/freertos/sys_arch.o
CC build/lwip/port/esp32/netif/ethernetif.o
CC build/lwip/port/esp32/netif/dhcp_state.o
CC build/lwip/port/esp32/netif/nettestif.o
CC build/lwip/port/esp32/netif/wlanif.o
CC build/lwip/port/esp32/debug/lwip_debug.o
AR build/lwip/liblwip.a
CC build/main/at_eth_init.o
CC build/main/at_default_config.o
CC build/main/at_upgrade.o
CC build/main/app_main.o
CC build/main/interface/uart/at_uart_task.o
AR build/main/libmain.a
CC build/mbedtls/mbedtls/library/poly1305.o
CC build/mbedtls/mbedtls/library/platform_util.o
CC build/mbedtls/mbedtls/library/havege.o
CC build/mbedtls/mbedtls/library/ssl_cookie.o
CC build/mbedtls/mbedtls/library/md5.o
CC build/mbedtls/mbedtls/library/certs.o
CC build/mbedtls/mbedtls/library/ssl_ciphersuites.o
CC build/mbedtls/mbedtls/library/camellia.o
CC build/mbedtls/mbedtls/library/x509_crl.o
CC build/mbedtls/mbedtls/library/threading.o
CC build/mbedtls/mbedtls/library/aesni.o
CC build/mbedtls/mbedtls/library/bignum.o
CC build/mbedtls/mbedtls/library/arc4.o
CC build/mbedtls/mbedtls/library/cipher_wrap.o
CC build/mbedtls/mbedtls/library/rsa_internal.o
CC build/mbedtls/mbedtls/library/aes.o
CC build/mbedtls/mbedtls/library/xtea.o
CC build/mbedtls/mbedtls/library/base64.o
CC build/mbedtls/mbedtls/library/sha512.o
CC build/mbedtls/mbedtls/library/pkcs11.o
CC build/mbedtls/mbedtls/library/ecdsa.o
CC build/mbedtls/mbedtls/library/asn1write.o
CC build/mbedtls/mbedtls/library/oid.o
CC build/mbedtls/mbedtls/library/ecjpake.o
CC build/mbedtls/mbedtls/library/ssl_tls.o
CC build/mbedtls/mbedtls/library/debug.o
CC build/mbedtls/mbedtls/library/aria.o
CC build/mbedtls/mbedtls/library/ecdh.o
CC build/mbedtls/mbedtls/library/x509_crt.o
CC build/mbedtls/mbedtls/library/ssl_srv.o
CC build/mbedtls/mbedtls/library/sha1.o
CC build/mbedtls/mbedtls/library/chacha20.o
CC build/mbedtls/mbedtls/library/md2.o
CC build/mbedtls/mbedtls/library/x509_create.o
CC build/mbedtls/mbedtls/library/cmac.o
CC build/mbedtls/mbedtls/library/gcm.o
CC build/mbedtls/mbedtls/library/version.o
CC build/mbedtls/mbedtls/library/pem.o
CC build/mbedtls/mbedtls/library/padlock.o
CC build/mbedtls/mbedtls/library/asn1parse.o
CC build/mbedtls/mbedtls/library/timing.o
CC build/mbedtls/mbedtls/library/ssl_cli.o
CC build/mbedtls/mbedtls/library/pkwrite.o
CC build/mbedtls/mbedtls/library/ssl_cache.o
CC build/mbedtls/mbedtls/library/sha256.o
CC build/mbedtls/mbedtls/library/md_wrap.o
CC build/mbedtls/mbedtls/library/entropy.o
CC build/mbedtls/mbedtls/library/hkdf.o
CC build/mbedtls/mbedtls/library/rsa.o
CC build/mbedtls/mbedtls/library/ripemd160.o
CC build/mbedtls/mbedtls/library/nist_kw.o
CC build/mbedtls/mbedtls/library/pkcs5.o
CC build/mbedtls/mbedtls/library/version_features.o
CC build/mbedtls/mbedtls/library/cipher.o
CC build/mbedtls/mbedtls/library/entropy_poll.o
CC build/mbedtls/mbedtls/library/dhm.o
CC build/mbedtls/mbedtls/library/error.o
CC build/mbedtls/mbedtls/library/ssl_ticket.o
CC build/mbedtls/mbedtls/library/x509.o
CC build/mbedtls/mbedtls/library/blowfish.o
CC build/mbedtls/mbedtls/library/chachapoly.o
CC build/mbedtls/mbedtls/library/ecp.o
CC build/mbedtls/mbedtls/library/md4.o
CC build/mbedtls/mbedtls/library/x509_csr.o
CC build/mbedtls/mbedtls/library/pkparse.o
CC build/mbedtls/mbedtls/library/md.o
CC build/mbedtls/mbedtls/library/ccm.o
CC build/mbedtls/mbedtls/library/pkcs12.o
CC build/mbedtls/mbedtls/library/ecp_curves.o
CC build/mbedtls/mbedtls/library/pk_wrap.o
CC build/mbedtls/mbedtls/library/x509write_crt.o
CC build/mbedtls/mbedtls/library/ctr_drbg.o
CC build/mbedtls/mbedtls/library/platform.o
CC build/mbedtls/mbedtls/library/pk.o
CC build/mbedtls/mbedtls/library/x509write_csr.o
CC build/mbedtls/mbedtls/library/des.o
CC build/mbedtls/mbedtls/library/hmac_drbg.o
CC build/mbedtls/mbedtls/library/memory_buffer_alloc.o
CC build/mbedtls/port/esp_sha512.o
CC build/mbedtls/port/esp_mem.o
CC build/mbedtls/port/esp_hardware.o
CC build/mbedtls/port/net_sockets.o
CC build/mbedtls/port/esp_bignum.o
CC build/mbedtls/port/esp_sha.o
CC build/mbedtls/port/esp_sha256.o
CC build/mbedtls/port/esp_sha1.o
CC build/mbedtls/port/mbedtls_debug.o
CC build/mbedtls/port/esp32/aes.o
CC build/mbedtls/port/esp32/sha.o
AR build/mbedtls/libmbedtls.a
CC build/mdns/mdns.o
CC build/mdns/mdns_networking.o
CC build/mdns/mdns_console.o
AR build/mdns/libmdns.a
AR build/mkfatfs/libmkfatfs.a
CC build/mqtt/esp-mqtt/mqtt_client.o
CC build/mqtt/esp-mqtt/lib/platform_esp32_idf.o
CC build/mqtt/esp-mqtt/lib/mqtt_msg.o
CC build/mqtt/esp-mqtt/lib/mqtt_outbox.o
AR build/mqtt/libmqtt.a
CC build/newlib/select.o
CC build/newlib/pthread.o
CC build/newlib/random.o
CC build/newlib/reent_init.o
CC build/newlib/pwrite.o
CC build/newlib/locks.o
CC build/newlib/pread.o
CC build/newlib/utime.o
CC build/newlib/poll.o
CC build/newlib/syscall_table.o
CC build/newlib/syscalls.o
CC build/newlib/termios.o
CC build/newlib/time.o
CC build/newlib/heap.o
AR build/newlib/libnewlib.a
CC build/nghttp/nghttp2/lib/nghttp2_map.o
CC build/nghttp/nghttp2/lib/nghttp2_queue.o
CC build/nghttp/nghttp2/lib/nghttp2_pq.o
CC build/nghttp/nghttp2/lib/nghttp2_submit.o
CC build/nghttp/nghttp2/lib/nghttp2_debug.o
CC build/nghttp/nghttp2/lib/nghttp2_hd_huffman_data.o
CC build/nghttp/nghttp2/lib/nghttp2_frame.o
CC build/nghttp/nghttp2/lib/nghttp2_helper.o
CC build/nghttp/nghttp2/lib/nghttp2_npn.o
CC build/nghttp/nghttp2/lib/nghttp2_option.o
CC build/nghttp/nghttp2/lib/nghttp2_buf.o
CC build/nghttp/nghttp2/lib/nghttp2_priority_spec.o
CC build/nghttp/nghttp2/lib/nghttp2_hd.o
CC build/nghttp/nghttp2/lib/nghttp2_stream.o
CC build/nghttp/nghttp2/lib/nghttp2_session.o
CC build/nghttp/nghttp2/lib/nghttp2_callbacks.o
CC build/nghttp/nghttp2/lib/nghttp2_rcbuf.o
CC build/nghttp/nghttp2/lib/nghttp2_hd_huffman.o
CC build/nghttp/nghttp2/lib/nghttp2_mem.o
CC build/nghttp/nghttp2/lib/nghttp2_version.o
CC build/nghttp/nghttp2/lib/nghttp2_outbound_item.o
CC build/nghttp/nghttp2/lib/nghttp2_http.o
CC build/nghttp/port/http_parser.o
AR build/nghttp/libnghttp.a
CXX build/nvs_flash/src/nvs_api.o
CXX build/nvs_flash/src/nvs_storage.o
CXX build/nvs_flash/src/nvs_pagemanager.o
CXX build/nvs_flash/src/nvs_encr.o
CXX build/nvs_flash/src/nvs_item_hash_list.o
CXX build/nvs_flash/src/nvs_page.o
CXX build/nvs_flash/src/nvs_ops.o
CXX build/nvs_flash/src/nvs_types.o
AR build/nvs_flash/libnvs_flash.a
CC build/openssl/library/ssl_stack.o
CC build/openssl/library/ssl_lib.o
CC build/openssl/library/ssl_x509.o
CC build/openssl/library/ssl_pkey.o
CC build/openssl/library/ssl_methods.o
CC build/openssl/library/ssl_cert.o
CC build/openssl/platform/ssl_port.o
CC build/openssl/platform/ssl_pm.o
AR build/openssl/libopenssl.a
CC build/protobuf-c/protobuf-c/protobuf-c/protobuf-c.o
AR build/protobuf-c/libprotobuf-c.a
CC build/protocomm/src/common/protocomm.o
CC build/protocomm/src/security/security1.o
CC build/protocomm/src/security/security0.o
CC build/protocomm/proto-c/sec0.pb-c.o
CC build/protocomm/proto-c/constants.pb-c.o
CC build/protocomm/proto-c/session.pb-c.o
CC build/protocomm/proto-c/sec1.pb-c.o
CC build/protocomm/src/simple_ble/simple_ble.o
CC build/protocomm/src/transports/protocomm_httpd.o
CC build/protocomm/src/transports/protocomm_console.o
CC build/protocomm/src/transports/protocomm_ble.o
AR build/protocomm/libprotocomm.a
CC build/pthread/pthread.o
CC build/pthread/pthread_cond_var.o
CC build/pthread/pthread_local_storage.o
AR build/pthread/libpthread.a
CC build/sdmmc/sdmmc_sd.o
CC build/sdmmc/sdmmc_cmd.o
CC build/sdmmc/sdmmc_mmc.o
CC build/sdmmc/sdmmc_common.o
CC build/sdmmc/sdmmc_io.o
CC build/sdmmc/sdmmc_init.o
AR build/sdmmc/libsdmmc.a
CC build/smartconfig_ack/smartconfig_ack.o
AR build/smartconfig_ack/libsmartconfig_ack.a
CC build/soc/esp32/emac_hal.o
CC build/soc/esp32/rtc_clk.o
CC build/soc/esp32/rtc_time.o
CC build/soc/esp32/rtc_sleep.o
CC build/soc/esp32/gpio_periph.o
CC build/soc/esp32/rtc_clk_init.o
CC build/soc/esp32/spi_periph.o
CC build/soc/esp32/rtc_init.o
CC build/soc/esp32/sdio_slave_periph.o
CC build/soc/esp32/rtc_wdt.o
CC build/soc/esp32/sdmmc_periph.o
CC build/soc/esp32/cpu_util.o
CC build/soc/esp32/rtc_periph.o
CC build/soc/esp32/rtc_pm.o
CC build/soc/esp32/soc_memory_layout.o
CC build/soc/src/soc_include_legacy_warn.o
CC build/soc/src/memory_layout_utils.o
CC build/soc/src/lldesc.o
CC build/soc/src/hal/spi_hal.o
CC build/soc/src/hal/spi_hal_iram.o
CC build/soc/src/hal/spi_flash_hal.o
CC build/soc/src/hal/spi_flash_hal_iram.o
CC build/soc/src/hal/spi_slave_hal.o
CC build/soc/src/hal/spi_slave_hal_iram.o
AR build/soc/libsoc.a
CC build/spi_flash/esp_flash_spi_init.o
CC build/spi_flash/memspi_host_driver.o
CC build/spi_flash/flash_ops.o
CC build/spi_flash/spi_flash_chip_issi.o
CC build/spi_flash/esp_flash_api.o
CC build/spi_flash/cache_utils.o
CC build/spi_flash/spi_flash_os_func_noos.o
CC build/spi_flash/spi_flash_chip_generic.o
CC build/spi_flash/spi_flash_rom_patch.o
CC build/spi_flash/partition.o
CC build/spi_flash/spi_flash_chip_drivers.o
CC build/spi_flash/flash_mmap.o
CC build/spi_flash/spi_flash_os_func_app.o
AR build/spi_flash/libspi_flash.a
CC build/spiffs/esp_spiffs.o
CC build/spiffs/spiffs_api.o
CC build/spiffs/spiffs/src/spiffs_hydrogen.o
CC build/spiffs/spiffs/src/spiffs_check.o
CC build/spiffs/spiffs/src/spiffs_nucleus.o
CC build/spiffs/spiffs/src/spiffs_gc.o
CC build/spiffs/spiffs/src/spiffs_cache.o
AR build/spiffs/libspiffs.a
CC build/tcp_transport/transport_strcasestr.o
CC build/tcp_transport/transport_tcp.o
CC build/tcp_transport/transport.o
CC build/tcp_transport/transport_ssl.o
CC build/tcp_transport/transport_utils.o
CC build/tcp_transport/transport_ws.o
AR build/tcp_transport/libtcp_transport.a
CC build/tcpip_adapter/event_handlers.o
CC build/tcpip_adapter/tcpip_adapter_lwip.o
AR build/tcpip_adapter/libtcpip_adapter.a
CC build/ulp/ulp_macro.o
CC build/ulp/ulp.o
AR build/ulp/libulp.a
CC build/unity/unity/src/unity.o
CC build/unity/unity_port_esp32.o
CC build/unity/unity_runner.o
AR build/unity/libunity.a
CC build/vfs/vfs.o
CC build/vfs/vfs_semihost.o
CC build/vfs/vfs_uart.o
AR build/vfs/libvfs.a
CXX build/wear_levelling/WL_Ext_Perf.o
CXX build/wear_levelling/Partition.o
CXX build/wear_levelling/SPI_Flash.o
CXX build/wear_levelling/WL_Ext_Safe.o
CXX build/wear_levelling/crc32.o
CXX build/wear_levelling/WL_Flash.o
CXX build/wear_levelling/wear_levelling.o
AR build/wear_levelling/libwear_levelling.a
CC build/wifi_provisioning/src/scheme_ble.o
CC build/wifi_provisioning/src/wifi_config.o
CC build/wifi_provisioning/src/handlers.o
CC build/wifi_provisioning/src/wifi_scan.o
CC build/wifi_provisioning/src/scheme_softap.o
CC build/wifi_provisioning/src/scheme_console.o
CC build/wifi_provisioning/src/manager.o
CC build/wifi_provisioning/proto-c/wifi_scan.pb-c.o
CC build/wifi_provisioning/proto-c/wifi_config.pb-c.o
CC build/wifi_provisioning/proto-c/wifi_constants.pb-c.o
AR build/wifi_provisioning/libwifi_provisioning.a
CC build/wpa_supplicant/port/os_xtensa.o
CC build/wpa_supplicant/src/ap/ap_config.o
CC build/wpa_supplicant/src/ap/wpa_auth.o
CC build/wpa_supplicant/src/ap/ieee802_1x.o
CC build/wpa_supplicant/src/ap/wpa_auth_ie.o
CC build/wpa_supplicant/src/common/wpa_common.o
CC build/wpa_supplicant/src/crypto/ms_funcs.o
CC build/wpa_supplicant/src/crypto/crypto_internal-cipher.o
CC build/wpa_supplicant/src/crypto/crypto_internal-modexp.o
CC build/wpa_supplicant/src/crypto/bignum.o
CC build/wpa_supplicant/src/crypto/sha1-pbkdf2.o
CC build/wpa_supplicant/src/crypto/aes-cbc.o
CC build/wpa_supplicant/src/crypto/md5.o
CC build/wpa_supplicant/src/crypto/rc4.o
CC build/wpa_supplicant/src/crypto/sha256.o
CC build/wpa_supplicant/src/crypto/dh_groups.o
CC build/wpa_supplicant/src/crypto/md4-internal.o
CC build/wpa_supplicant/src/crypto/sha1-internal.o
CC build/wpa_supplicant/src/crypto/aes-wrap.o
CC build/wpa_supplicant/src/crypto/crypto_mbedtls.o
CC build/wpa_supplicant/src/crypto/crypto_internal.o
CC build/wpa_supplicant/src/crypto/dh_group5.o
CC build/wpa_supplicant/src/crypto/des-internal.o
CC build/wpa_supplicant/src/crypto/crypto_internal-rsa.o
CC build/wpa_supplicant/src/crypto/aes-unwrap.o
CC build/wpa_supplicant/src/crypto/aes-internal-dec.o
CC build/wpa_supplicant/src/crypto/sha1.o
CC build/wpa_supplicant/src/crypto/aes-internal.o
CC build/wpa_supplicant/src/crypto/md5-internal.o
CC build/wpa_supplicant/src/crypto/sha256-internal.o
CC build/wpa_supplicant/src/crypto/aes-internal-enc.o
CC build/wpa_supplicant/src/eap_peer/eap_peap_common.o
CC build/wpa_supplicant/src/eap_peer/chap.o
CC build/wpa_supplicant/src/eap_peer/eap_mschapv2.o
CC build/wpa_supplicant/src/eap_peer/eap_peap.o
CC build/wpa_supplicant/src/eap_peer/eap_ttls.o
CC build/wpa_supplicant/src/eap_peer/eap_tls_common.o
CC build/wpa_supplicant/src/eap_peer/eap_tls.o
CC build/wpa_supplicant/src/eap_peer/mschapv2.o
CC build/wpa_supplicant/src/eap_peer/eap_common.o
CC build/wpa_supplicant/src/eap_peer/eap.o
CC build/wpa_supplicant/src/rsn_supp/wpa.o
CC build/wpa_supplicant/src/rsn_supp/wpa_ie.o
CC build/wpa_supplicant/src/tls/tls_internal.o
CC build/wpa_supplicant/src/tls/tlsv1_common.o
CC build/wpa_supplicant/src/tls/tlsv1_server_write.o
CC build/wpa_supplicant/src/tls/bignum.o
CC build/wpa_supplicant/src/tls/tlsv1_record.o
CC build/wpa_supplicant/src/tls/pkcs5.o
CC build/wpa_supplicant/src/tls/pkcs1.o
CC build/wpa_supplicant/src/tls/tlsv1_client_write.o
CC build/wpa_supplicant/src/tls/tlsv1_server_read.o
CC build/wpa_supplicant/src/tls/asn1.o
CC build/wpa_supplicant/src/tls/pkcs8.o
CC build/wpa_supplicant/src/tls/rsa.o
CC build/wpa_supplicant/src/tls/tlsv1_client.o
CC build/wpa_supplicant/src/tls/tlsv1_client_read.o
CC build/wpa_supplicant/src/tls/tlsv1_cred.o
CC build/wpa_supplicant/src/tls/x509v3.o
CC build/wpa_supplicant/src/tls/tlsv1_server.o
CC build/wpa_supplicant/src/utils/uuid.o
CC build/wpa_supplicant/src/utils/wpabuf.o
CC build/wpa_supplicant/src/utils/ext_password.o
CC build/wpa_supplicant/src/utils/base64.o
CC build/wpa_supplicant/src/utils/common.o
CC build/wpa_supplicant/src/utils/wpa_debug.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpa_main.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpa2.o
CC build/wpa_supplicant/src/esp_supplicant/esp_hostap.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wps.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpas_glue.o
CC build/wpa_supplicant/src/wps/wps_enrollee.o
CC build/wpa_supplicant/src/wps/wps_attr_build.o
CC build/wpa_supplicant/src/wps/wps_registrar.o
CC build/wpa_supplicant/src/wps/wps_common.o
CC build/wpa_supplicant/src/wps/wps.o
CC build/wpa_supplicant/src/wps/wps_dev_attr.o
CC build/wpa_supplicant/src/wps/wps_attr_parse.o
CC build/wpa_supplicant/src/wps/wps_validate.o
CC build/wpa_supplicant/src/wps/wps_attr_process.o
AR build/wpa_supplicant/libwpa_supplicant.a
CC build/xtensa/trax.o
CC build/xtensa/debug_helpers.o
CC build/xtensa/eri.o
AS build/xtensa/debug_helpers_asm.o
AR build/xtensa/libxtensa.a
Generating esp32.project.ld
  File "C:/msys32/home/micka/esp/esp-idf/tools/ldgen/ldgen.py", line 150, in <module>
    main()
  File "C:/msys32/home/micka/esp/esp-idf/tools/ldgen/ldgen.py", line 114, in main
    sdkconfig = SDKConfig(kconfig_file, config_file)
  File "C:/msys32/home/micka/esp/esp-idf/tools/ldgen/sdkconfig.py", line 50, in __init__
    self.config = kconfiglib.Kconfig(kconfig_file)
  File "C:/msys32/home/micka/esp/esp-idf/tools/kconfig_new/kconfiglib.py", line 656, in __init__
    self.top_node)  # prev_node
  File "C:/msys32/home/micka/esp/esp-idf/tools/kconfig_new/kconfiglib.py", line 1583, in _parse_block
    self._enter_file(sourced_file)
  File "C:/msys32/home/micka/esp/esp-idf/tools/kconfig_new/kconfiglib.py", line 1167, in _enter_file
    .format(self._filename, self._linenr, e.message))
IOError: C:/msys32/home/micka/esp/esp-idf/Kconfig:67: Could not open 'C:msys32homemickaspesp-idfcomponentsapp_updateKconfig.projbuild' (ENOENT: No such file or directory). Perhaps the $srctree environment variable (which was unset) is set incorrectly. Note that the current value of $srctree is saved when the Kconfig instance is created (for consistency and to cleanly separate instances). Also note that e.g. $FOO in a 'source' statement does not refer to the environment variable FOO, but rather to the Kconfig Symbol FOO (which would commonly have 'option env="FOO"' in its definition).
make: *** [/home/micka/esp/esp-idf/components/esp32/Makefile.projbuild:17: /home/micka/esp/esp32-at/build/esp32/esp32.project.ld] Error 1
I really don't know how to resolve them either the why i have these errors.
If somebody can help me please.
And sorry for my poor English :)
Mickael
Helen L
Re: ESP32 AT Commands : Build failed with ESP IDF 4.0
Postby Helen L » Mon Jul 29, 2019 11:21 am
It seems that IDF 4.0 changed a lot, it is a big version. Maybe it is too new to the AT.
I guess that the AT project has a specific version of IDF as its submodule, maybe you can compile AT according to its readme.
Mickael
Postby Mickael » Mon Jul 29, 2019 2:50 pm
Thank you for your answer !
The readme file is not updated because in "ESP_AT_Get_Started.md" we have :
Since we updated the toolchain recently, it is not compatible with the old version. Please use the toolchain we provided in the esp32-at/esp-idf/docs/get-started/linux-setup.rst and esp32-at/esp-idf/docs/get-started/windows-setup.rst to build your ESP32 AT project.
And there is no "esp32-at/esp-idf/docs/get-started/windows-setup.rst" on the project.
And of course I already tried 3.2.2 , 3.3, 3.3beta IDF version with these toolchain version : https://dl.espressif.com/dl/esp32_win32 ... 181001.zip
https://dl.espressif.com/dl/esp32_win32 ... 190611.zip
But the result is the same.
jiachongss
Postby jiachongss » Tue Jul 30, 2019 7:29 am
Hi ,
Esp32-AT project does not support user-specified IDF, especially version 4.0.
How to compile ESP AT, see https://github.com/espressif/esp32-at/b ... Started.md
I hope I can help you,Good luck
Mickael
Postby Mickael » Tue Jul 30, 2019 2:12 pm
Hi @jiachongss !
Thank you
But as I said before https://github.com/espressif/esp32-at/b ... Started.md is not updated because there is no IDF inside Esp32-At project, which was the case in the old version of Esp32-At project but not in the current version :cry:
On Linux it works with version v3.3-beta3 of the IDF and v5.2.0 of the toolchain. But I want to do it on Windows :)
WiFive
Postby WiFive » Wed Jul 31, 2019 8:01 am
if you add these to the top of ldgen.mk it will work
COMPONENT_KCONFIGS := $(foreach component,$(COMPONENT_PATHS),$(wildcard $(component)/Kconfig))
COMPONENT_KCONFIGS_PROJBUILD := $(foreach component,$(COMPONENT_PATHS),$(wildcard $(component)/Kconfig.projbuild))
Mickael
Postby Mickael » Wed Jul 31, 2019 9:26 am
Thank you so much @WiFive, it's works ! :D
boriss2oo6
Postby boriss2oo6 » Sat Sep 07, 2019 9:28 am
I encountered the same issue on windows when i tried to build esp-at firmware. By default it comes with esp-idf 3.3 and i tried with a several revisions but without luck. Also tried with 4.0 and the same. I managed to build with 3.2 (latest revision) but i wanted to build with 4.0 and i found this topic. After adding
to top of ldgen.mk i receive lots of errors:
LD build/esp-at.elf
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_wifiCmd.o):(.rodata+0x4): undefined reference to `g_wifi_default_wps_crypto_funcs'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_exeCmdCifsr+0x18): undefined reference to `esp_eth_get_mac'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_loop_socket_send+0x8): undefined reference to `lwip_sendto_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_setupCmdCipRecvData+0x14): undefined reference to `lwip_recv_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_exeCmdCipstatus+0xc): undefined reference to `lwip_getsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_exeCmdCipstatus+0x10): undefined reference to `lwip_getsockname_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_creat_loop_socket+0x0): undefined reference to `lwip_bind_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_loop_socket_recv+0x0): undefined reference to `lwip_recvfrom_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_setupCmdCipserver+0x20): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_setupCmdCipserver+0x24): undefined reference to `lwip_listen_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_socket_retry_conn+0x20): undefined reference to `lwip_connect_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_socket_server_listen+0x3c): undefined reference to `lwip_accept_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.literal.at_sending_data+0x24): undefined reference to `lwip_send_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o): In function `at_exeCmdCifsr':
(.text.at_exeCmdCifsr+0x143): undefined reference to `esp_eth_get_mac'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_loop_socket_send+0x3a): undefined reference to `lwip_sendto_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o): In function `at_setupCmdCipRecvData':
(.text.at_setupCmdCipRecvData+0xca): undefined reference to `lwip_recv_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o): In function `at_exeCmdCipstatus':
(.text.at_exeCmdCipstatus+0x53): undefined reference to `lwip_getsockopt_r'
(.text.at_exeCmdCipstatus+0x7a): undefined reference to `lwip_getsockname_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_creat_loop_socket+0x3f): undefined reference to `lwip_bind_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_loop_socket_recv+0xf): undefined reference to `lwip_recvfrom_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o): In function `at_setupCmdCipserver':
(.text.at_setupCmdCipserver+0x10f): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipserver+0x121): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipserver+0x158): undefined reference to `lwip_bind_r'
(.text.at_setupCmdCipserver+0x182): undefined reference to `lwip_getsockopt_r'
(.text.at_setupCmdCipserver+0x1a9): undefined reference to `lwip_listen_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0xab): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0xbe): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0xdb): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0xf2): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x106): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x11c): more undefined references to `lwip_setsockopt_r' follow
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x12d): undefined reference to `lwip_connect_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x18e): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x1a1): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x1be): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x1d5): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x1e9): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x1ff): more undefined references to `lwip_setsockopt_r' follow
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x210): undefined reference to `lwip_connect_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x236): undefined reference to `lwip_getsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_retry_conn+0x378): undefined reference to `lwip_bind_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_server_listen+0x9b): undefined reference to `lwip_accept_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_socket_server_listen+0x351): undefined reference to `lwip_getsockname_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o): In function `at_sending_data':
(.text.at_sending_data+0xf1): undefined reference to `lwip_sendto_r'
(.text.at_sending_data+0x155): undefined reference to `lwip_getsockopt_r'
(.text.at_sending_data+0x211): undefined reference to `lwip_send_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o): In function `at_setupCmdCipstart':
(.text.at_setupCmdCipstart+0x41c): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0x438): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0x45f): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0x483): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0x4a1): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_setupCmdCipstart+0x4c1): more undefined references to `lwip_setsockopt_r' follow
(.text.at_setupCmdCipstart+0x526): undefined reference to `lwip_bind_r'
(.text.at_setupCmdCipstart+0x578): undefined reference to `lwip_connect_r'
(.text.at_setupCmdCipstart+0x5b1): undefined reference to `lwip_getsockopt_r'
(.text.at_setupCmdCipstart+0x672): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0x68e): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0x6b5): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0x6d9): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0x6f7): undefined reference to `lwip_setsockopt_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_setupCmdCipstart+0x717): more undefined references to `lwip_setsockopt_r' follow
(.text.at_setupCmdCipstart+0x77d): undefined reference to `lwip_bind_r'
(.text.at_setupCmdCipstart+0x7d0): undefined reference to `lwip_connect_r'
(.text.at_setupCmdCipstart+0x809): undefined reference to `lwip_getsockopt_r'
(.text.at_setupCmdCipstart+0xa63): undefined reference to `lwip_bind_r'
(.text.at_setupCmdCipstart+0xad2): undefined reference to `lwip_setsockopt_r'
(.text.at_setupCmdCipstart+0xb2d): undefined reference to `lwip_getsockname_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_process_recv_socket+0x42): undefined reference to `lwip_recvfrom_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o):(.text.at_process_recv_socket+0x70): undefined reference to `lwip_recv_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_ipCmd.o): In function `at_transparent_transmit_tcpip':
(.text.at_transparent_transmit_tcpip+0x8a): undefined reference to `lwip_setsockopt_r'
(.text.at_transparent_transmit_tcpip+0xd0): undefined reference to `lwip_sendto_r'
(.text.at_transparent_transmit_tcpip+0xfa): undefined reference to `lwip_send_r'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_init_para.o):(.literal.at_nvm_init+0x4): undefined reference to `esp_eth_set_mac'
E:/msys32/home/Boriss/esp/esp-at12/components/at/lib\libesp32_at_core.a(at_init_para.o): In function `at_nvm_init':
(.text.at_nvm_init+0xf6): undefined reference to `esp_eth_set_mac'
make: *** [E:/msys32/home/boriss/esp/esp-idf/make/project.mk:523: /home/Boriss/esp/esp-at12/build/esp-at.elf] Error 1
Thanks in advance.
Users browsing this forum: Google [Bot], Oromis and 41 guests
