Hello everyone!
I am an amateur that's just starting with electronics coming from a programming background.
Till now i was using esp826 (esp12 modules). For those ones you had to pull up or down several pins in order for the module to be able to work.
I want to make a prototype board with the ESP32-WROOM-32 or 32D module. I have tested the firmware and the other electronics with a dev board and it works fine. What i want to know is the exact wiring that is needed for the ESP32 to power up and start running the program that is inside while being stable. I understand how to put it in boot mode. I want to know whats the configuration that it needs in order to be stable(assuming my power supply is stable and sufficient of course).
Thank you a lot in advance.
ESP wroom moduels wiring for normal use.
Users browsing this forum: Baidu [Spider], Vineethad and 230 guests
