Hi, currently im in the process of getting the FCC certification on my product, which ESP32 ic on board. I have submitted the (ESP32&ESP8266_RF_Performance_Test) to the UL, but then they replied i still missing the fixed frequency guidelines for getting the FCC certification.
Can anyone please provide me the relevant information.. thank you.
the necessary documents for ESP32 FCC certification
Re: the necessary documents for ESP32 FCC certification
hiHi, currently im in the process of getting the FCC certification on my product, which ESP32 ic on board. I have submitted the (ESP32&ESP8266_RF_Performance_Test) to the UL, but then they replied i still missing the fixed frequency guidelines for getting the FCC certification.
grab it here (EN Version) or here CN Version
if there are missings parts bump the theme on again.
hope this helps
rudi
Hi Rudi,hi
hope this helps
rudi![]()
Thank you in advance.
My product is an onboard IC design, it needs to be done separately the FCC test. so i still need to submit my product to UL for testing FCC.![]()
I have submitted the product to UL to test it, but they replied they need the guidelines how to set the fixed frequency and so they can run the test.
I remember last time i can find the documentation of esp32 FCC test guide pdf on the espressif official website, but now i cant find it.
Hi Rudi,
hi,
this?
test tool
test bin files
-> feel free...
"This guide demonstrates how to run an RF related performance test and certification test using an RF tester to check an ESP32 / ESP8266 based product, either functioning as a standalone controller or an integrated part of MCU."
ESP32&ESP8266 RF Performance Test Demonstration
rudi
also here: ( please do allways download from origin the last version )
Last Version 2019 - 21 Jan V3.0
if you mean this
this was from 2016
there was also a FCC post on esp32.com
the second post you find the version from 2016
or here(pdf is inlcuded)
or here only the pdf:
allways check for newer things.
hope this helps
rudi
this was from 2016
hope this helps
rudi
Hi Rudi,if you mean this
this was from 2016
hope this helps
rudi![]()
Thank you very much
Hi Rudi,
Thank you very much![]()
, btw do you have the ESP32_Certification_and Test_Guide in Chinese version ?
ESP32&ESP8266 射频性能测试指南
本测试指南用于指导客户基于 ESP32/ESP8266 设计的产品,使用相关软件和仪器进行射频性能测试或认证测试,并针对“以 Wi-Fi 模组作为独立控制器”或“搭载主机 MCU”两种情况,分别介绍测试方法。
LINK V3 2019 CN
or here: PDF (CN) Only
also more tools in CN
feel free..
hope this helps
rudi
PS:
i am not sure, was the version 1.0 from DEZ 2016 available in Chinese version too,
i will search the next time and update the post if i find anything in this.
push
yes there was an CN version from 2016 DEZ ,
but i think not more -online- available.
you can visit web archiv from 2016 online but i think, the attached file ( esp32_cert_test_cn_20161202.zip ) is not available from 2016 there
hope this helps
rudi
hope this helps
rudi
push
hope this helps
rudi![]()
Hi Rudi, Thank you in advance
Users browsing this forum: PerplexityBot, Qwantbot and 7 guests
