Toolchain xtensa-esp32-elf-win32-esp32-2019r1-8.2.0.zip missing
Postby rudi ;-) » Tue Sep 17, 2019 7:41 am
Hi Guys
where we find the toolchain esp32-2019r1 ?
the provided link looks 404.
taken from here
thank you!
Re: Toolchain xtensa-esp32-elf-win32-esp32-2019r1-8.2.0.zip missing
Postby rudi ;-) » Tue Sep 17, 2019 7:51 am
can it bee there is a small typo in the link?
ESP32S2:: dl.espressif.com/dl/xtensa-esp32-elf-win32-esp32-2019r1-8.2.0.zip
LATEST:: dl.espressif.com/dl/xtensa-esp32-elf-gcc8_2_0-esp32-2019r1-win32.zip
ESP32S2:
https://dl.espressif.com/dl/xtensa-esp3 ... -8.2.0.zip
Latest:
https://dl.espressif.com/dl/xtensa-esp3 ... -win32.zip
thank you!
Postby rudi ;-) » Tue Sep 17, 2019 7:56 am
missing the ESP32S2 toolchain for windows :)
( not the installer )
Postby rudi ;-) » Tue Sep 17, 2019 8:08 am
ok i know, we have from Angus nice how to
and the toolchain is there for ESP32S2 and Windows.
but i get
$ make -j4 all
Toolchain path: /opt/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc
WARNING: Toolchain version is not supported: esp32s2-dev-4-g3a626e93
Expected to see version: esp32-2019r1
Please check ESP-IDF setup instructions and update the toolchain, or proceed at your own risk.
Compiler version: 8.2.0
Postby rudi ;-) » Tue Sep 17, 2019 8:11 am
$ printenv PATH
/opt/xtensa-esp32s2-elf/bin:/mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
$ printenv IDF_PATH
c:/msys32/home/sysop/esp32s2/esp-idf
Postby rudi ;-) » Tue Sep 17, 2019 8:16 am
C:/msys32/home/sysop/esp32s2/esp-idf/components/soc/esp32/include/soc/cpu.h: Assembler messages:
C:/msys32/home/sysop/esp32s2/esp-idf/components/soc/esp32/include/soc/cpu.h:59: Error: invalid register 'MEMCTL' for 'wsr' instruction
i think i miss something :)
the ESP32S2 IDF Path is set, and right, but it points to the esp32 include soc cpu.h
can we Define the target "ESP32S2" or must we Define the target in a Makefile?
Postby rudi ;-) » Tue Sep 17, 2019 9:21 am
WiFive wrote:
Tue Sep 17, 2019 8:47 am
https://esp32.com/viewtopic.php?t=12183
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) Project Configuration
CONFIG_IDF_TARGET_ESP32=y
CONFIG_IDF_TARGET="esp32"
# CONFIG_IDF_TARGET_ESP32S2BETA is not set
# SDK tool configuration
:roll:
txs WiFive,
And also as a user, is a bit confusing that when you open the sdkconfig you see:
# CONFIG_IDF_TARGET_ESP32 is not set
CONFIG_IDF_TARGET="esp32s2beta"
CONFIG_IDF_TARGET_ESP32S2BETA=y
When the ESP32 target is set
i will have a try again and post result asap ( not just in time but next 8 hours )
txs WiFive!!!
txs @fasani
Postby rudi ;-) » Tue Sep 17, 2019 9:52 am
feature/esp32s2beta
ifdef IDF_TARGET
ifneq ($(IDF_TARGET),esp32)
$(error GNU Make based build system only supports esp32 target, but IDF_TARGET is set to $(IDF_TARGET))
endif
else
export IDF_TARGET := esp32
endif
Postby rudi ;-) » Tue Sep 17, 2019 11:18 am
feature/esp32s2beta
ifdef IDF_TARGET
endif
else
endif
changed it to :
ifdef IDF_TARGET
@echo "IDF TARGET WAS SET:" $(IDF_TARGET)
# ifneq ($(IDF_TARGET),esp32)
ifneq ($(IDF_TARGET),esp32s2beta)
# $(error GNU Make based build system only supports esp32 target, but IDF_TARGET is set to $(IDF_TARGET))
$(error GNU Make based build system only supports esp32s2beta target, but IDF_TARGET is set to $(IDF_TARGET))
endif
else
# export IDF_TARGET := esp32
export IDF_TARGET := esp32s2beta
endif
and we get ( automatically )
btw just in time searching the missing added (esp32s2beta) INCLUDE_PATH
In file included from C:/msys32/home/sysop/esp32s2/esp-idf/components/soc/esp32s2beta/include/soc/dport_reg.h:184,
                 from C:/msys32/home/sysop/esp32s2/esp-idf/components/app_trace/app_trace.c:160:
C:/msys32/home/sysop/esp32s2/esp-idf/components/soc/esp32s2beta/include/soc/dport_access.h:20:10: fatal error: esp32s2beta/dport_access.h: No such file or directory
 #include "esp32s2beta/dport_access.h"
compilation terminated.
Users browsing this forum: Google [Bot] and 22 guests
