Esp entering boot mode
yogeshwaran774
Postby yogeshwaran774 » Tue Sep 24, 2019 5:15 pm
  1. In my project i am using esp32, it is flashing properly and working fine but sometimes if i switch off and turn it on it is going to boot mode and it is not coming from that even if i switch off and switch on again. if i leave for sometime then switch it on then working properly and in my design enable is pulled up, gpio 0 is not connected to anything and 10uf electrolytic capacitor near to esp32.
  2.
  3. Can some one help to find out how it is going into boot mode randomly?
ESP_Dazz
Re: Esp entering boot mode
Postby ESP_Dazz » Tue Oct 08, 2019 8:21 am
GPIO0 should be internally pulled up, so leaving the PIN floating usually isn't an issue. However, keep in mind the internal pull-ups are quite weak (45 K Ohms). Is GPIO0 left completely floating or is it connected to something else (e.g. PCB trace)? Does the issue still persist if you externally apply a stronger pull-up to GPIO0?
yogeshwaran774
Postby yogeshwaran774 » Mon Jun 29, 2020 7:39 am
Gpio 0 has 10K pull up in pcb but still issue persist
Users browsing this forum: No registered users and 18 guests
