How is 240 Mhz cpu clock achieved?
greengnu
Postby greengnu » Wed Oct 09, 2019 9:01 am
The esp32 technical reference manual section 3.2.2 states that PLL_CLK is an internal clock with 320Mhz frequency and section 3.2.3 states:
<<As Figure 6 shows, CPU_CLK is the master clock for both CPU cores. CPU_CLK clock can be as high as 160 MHz when the CPU is in high performance mode. Alternatively, the CPU can run at lower frequencies to reduce power consumption>>
However, all esp32 modules that I got go up to 240Mhz. How is that cpu clock achieved? Is PLL_CLK running at 480Mhz rather than 320?
WiFive
Re: How is 240 Mhz cpu clock achieved?
Postby WiFive » Wed Oct 09, 2019 9:24 am
Yes
greengnu
Postby greengnu » Wed Oct 09, 2019 9:27 am
yes?
greengnu
Postby greengnu » Wed Oct 09, 2019 9:28 am
I assume 'yes' means PLL_CLK runs at 480 Mhz?
What about the other clock sources?
Where can I find a version of the technical reference manual that has correct clocking information?
WiFive
Postby WiFive » Wed Oct 09, 2019 10:05 am
Correct. Only pll clk and CPU clk are affected. Apb clk is still 80mhz.
Users browsing this forum: MSN [Bot] and 24 guests
