#ifndef __WIFI_C__
#define __WIFI_C__
#include <esp_wifi.h>
#include <esp_event_loop.h>
#include <freertos/event_groups.h>
#include <esp_system.h>
#include <nvs_flash.h>
#include <sdkconfig.h>
#include </home/mallan/esp_printer/esp-idf/components/lwip/include/lwip/lwip/err.h>
#include </home/mallan/esp_printer/esp-idf/components/lwip/include/lwip/lwip/sockets.h>
#include </home/mallan/esp_printer/esp-idf/components/lwip/include/lwip/lwip/sys.h>
#include </home/mallan/esp_printer/esp-idf/components/lwip/include/lwip/lwip/netdb.h>
#include </home/mallan/esp_printer/esp-idf/components/lwip/include/lwip/lwip/dns.h>
#include </home/mallan/esp_printer/esp-idf/components/heap/include/esp_heap_caps.h>
#include "esp_log.h"
#include "wifi.h"
#include "extern_head.h"
#include "freertos/task.h"
#define EXAMPLE_ESP_WIFI_SSID "My_WIFI_PRINTER"
#define EXAMPLE_ESP_WIFI_PASS "myprinter"
#define EXAMPLE_MAX_STA_CONN 8
#define TRUE 1
#define FALSE 0
#define PORT 8242
static EventGroupHandle_t s_wifi_event_group;
const int CONNECTED_BIT = BIT0;
static const char *TAG = "WIFI_PRINTER";
static esp_err_t event_handler(void *ctx, system_event_t *event)
switch(event->event_id) {
case SYSTEM_EVENT_AP_STACONNECTED:
printf( "station:"MACSTR" join, AID=%d",
MAC2STR(event->event_info.sta_connected.mac),
event->event_info.sta_connected.aid);
case SYSTEM_EVENT_AP_STADISCONNECTED:
printf( "station:"MACSTR"leave, AID=%d",
MAC2STR(event->event_info.sta_disconnected.mac),
event->event_info.sta_disconnected.aid);
default:
return ESP_OK;
void wifi_init_softap() // calling this func from main
if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
ESP_ERROR_CHECK( ret );
s_wifi_event_group = xEventGroupCreate();
tcpip_adapter_init();
ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));
wifi_config_t wifi_config = {
.ap = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.ssid_len = strlen(EXAMPLE_ESP_WIFI_SSID),
.password = EXAMPLE_ESP_WIFI_PASS,
.max_connection = EXAMPLE_MAX_STA_CONN,
.authmode = WIFI_AUTH_WPA_WPA2_PSK
if (strlen(EXAMPLE_ESP_WIFI_PASS) == 0) {
wifi_config.ap.authmode = WIFI_AUTH_OPEN;
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
printf("wifi_init_softap finished.SSID:%s password:%s",EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
void tcp_server_task(void *pvParameter)
int opt = TRUE;
int master_socket , addrlen , new_socket , client_socket[8] ,max_clients = 8 , activity, i , valread,sd=0 ;
int max_sd;
struct sockaddr_in MySock;
MySock.sin_family = AF_INET;
MySock.sin_addr.s_addr = INADDR_ANY;
MySock.sin_port = htons( PORT );
//char buffer[990];
fd_set readfds;
char *message = "Connected to socket \r\n";
for (i = 0; i < max_clients; i++)
client_socket = 0;
if( (master_socket = socket(AF_INET , SOCK_STREAM , 0)) == 0)
perror("socket failed");
printf("socket failed\n");
exit(EXIT_FAILURE);
//set master socket to allow multiple connections ,
//this is just a good habit, it will work without this
if( setsockopt(master_socket, SOL_SOCKET, SO_REUSEADDR, (char *)&opt,
sizeof(opt)) < 0 )
perror("setsockopt");
exit(EXIT_FAILURE);
if (bind(master_socket, (struct sockaddr *)&MySock, sizeof(MySock))<0)
perror("bind failed");
printf("bind failed\n");
exit(EXIT_FAILURE);
printf("Listener on port %d \n", PORT);
if (listen(master_socket, 5) < 0)
perror("listen");
printf("listen failed\n");
exit(EXIT_FAILURE);
addrlen = sizeof(MySock);
puts("Waiting for connections ...");
while(TRUE)
FD_ZERO(&readfds);
vTaskDelay(10/ portTICK_PERIOD_MS);
FD_SET(master_socket, &readfds);
max_sd = master_socket;
for ( i = 0 ; i < max_clients ; i++)
sd = client_socket;
if(sd > 0)
FD_SET( sd , &readfds);
if(sd > max_sd)
max_sd = sd;
activity = select( max_sd + 1 , &readfds , NULL , NULL , NULL);
if ((activity < 0) && (errno!=EINTR))
printf("select error");
if (FD_ISSET(master_socket, &readfds))
if ((new_socket = accept(master_socket,
(struct sockaddr *)&MySock, (socklen_t*)&addrlen))<0)
perror("accept");
printf("accept failed\n");
exit(EXIT_FAILURE);
printf("New connection , socket fd is %d , ip is : %s , port : %d\n" , new_socket , inet_ntoa(MySock.sin_addr) , ntohs
(MySock.sin_port));
if( send(new_socket, message, strlen(message), 0) != strlen(message) )
perror("send");
puts("Welcome message sent successfully");
if( client_socket == 0 )
client_socket = new_socket;
printf("Adding to list of sockets as %d\n" , i);
sd = client_socket;
if (FD_ISSET( sd , &readfds))
if ((valread = read( sd , CIRCULAR_RECEIVE_BUFFER, 990)) == 0)
getpeername(sd , (struct sockaddr*)&MySock ,(socklen_t*)&addrlen);
printf("Host disconnected , ip %s , port %d \n" ,
inet_ntoa(MySock.sin_addr) , ntohs(MySock.sin_port));
close( sd );
client_socket = 0;
else
FLAG.Wait_one_second_to_enable_print_flag = 1;
CIRCULAR_RECEIVE_BUFFER[valread] = '\0';
// for(int inx=0;buffer[inx]!='\0';inx++,RX_TOTAL_COUNT++)
// CIRCULAR_RECEIVE_BUFFER[RX_TOTAL_COUNT % BUFFER_SIZE] =buffer[inx];
// CIRCULAR_RECEIVE_BUFFER[RX_TOTAL_COUNT]='\0';
printf("buffer=%s\n",CIRCULAR_RECEIVE_BUFFER);
// send(sd , CIRCULAR_RECEIVE_BUFFER , strlen(CIRCULAR_RECEIVE_BUFFER) , 0 );
//memset(CIRCULAR_RECEIVE_BUFFER,0,990);
#endif
the above code, iam using for hosting the wifi(AP), for me its getting connected to the client device but if i want to send any command or something, it is saying like "Host is not found" ,(using TCP telnet terminal app) so please can anyone help me out.
ESP32 wifi ap mode
Return to “General Discussion”
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- 全国大学生物联网设计竞赛乐鑫答疑专区
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: No registered users and 129 guests
- All times are UTC
- Top
- Delete cookies
About Us
