is there code for non blocking TCP recv call ?
ht_main1
Postby ht_main1 » Fri Nov 01, 2019 7:04 am
hi, i am using TCP socket for multiple connection,
i want to use non blocking recv call, i tried using
fcntl(connect_socket, F_SETFL, O_NONBLOCK); /* Change the socket into non-blocking state	*/
function after
connect_socket = accept(server_socket, (struct sockaddr *)&client_addr, &socklen);
but i dont see any change in recv call, it blocks the function and i receive both continuous data from 2 socket instance/client.
how to receive data from tcp socket without blocking the call ? incase i have multiple socket connection i need to be non blocking.
need help in this
regards
Sushant
Re: is there code for non blocking TCP recv call ?
Postby ESP_Sprite » Fri Nov 01, 2019 9:05 am
Not an answer to your question, but the canonical way to handle multiple sockets is to use one select() call on all of them, then handle whichever becomes active.
ht_main1
Postby ht_main1 » Sat Nov 02, 2019 11:23 am
thanks for your input i have read and tried implementing select ,
it works
Users browsing this forum: Rckyan and 163 guests
