Where is uart_read_bytes_available()
murray_lang
Postby murray_lang » Tue Feb 28, 2017 6:29 am
Why is there no function such as "uart_read_bytes_available()" i the UART API?
I have implemented my own by copying uart_read_bytes() and taking out the stuff that consumes the data:
size_t uart_read_bytes_available(uart_port_t uart_num)
    UART_CHECK((uart_num < UART_NUM_MAX), "uart_num error", (-1));
    uint8_t* data = NULL;
    size_t avail = 0;
    size_t size;
    if(xSemaphoreTake(p_uart_obj[uart_num]->rx_mux, 100/portTICK_RATE_MS) != pdTRUE) {
        return 0;
    if(p_uart_obj[uart_num]->rx_cur_remain == 0) {
        data = (uint8_t*) xRingbufferReceive(p_uart_obj[uart_num]->rx_ring_buf, &size, 100/portTICK_RATE_MS);
        if(data) {
            p_uart_obj[uart_num]->rx_head_ptr = data;
            p_uart_obj[uart_num]->rx_ptr = data;
            p_uart_obj[uart_num]->rx_cur_remain = size;
    avail = p_uart_obj[uart_num]->rx_cur_remain;
    xSemaphoreGive(p_uart_obj[uart_num]->rx_mux);
    return avail;
Although highly dubious, I have copied this into uart.c in order to have access to static objects defined therein. It would make life much nicer if such a function could be provided by the SDK.
Regards,
Murray
LozzaGMK
Re: Where is uart_read_bytes_available()
Postby LozzaGMK » Fri Apr 09, 2021 5:47 pm
Tried to post a reply but it didn't work...
How about
uart_get_buffered_data_len()
Thought I'd reply, even though this is an old comment, as I had the same issue.
Users browsing this forum: BeratK and 130 guests
