I want to do some simple async input via UART_0 and pass that through to other UARTs. Instead of doing scanf or getc, can I simply read UART_0 or will that cause core to crash since some other task is probably monitoring UART_0 and I suspect read and write on uarts are not thread safe (and shouldn't be anyway).
I would like to read stdin without having to hit enter, in case you wonder why I wanted to do this.
Thanks.
Getting input from console by reading UART_0
Re: Getting input from console by reading UART_0
int ch = fgetc(stdin);
Thanks Mike!
I just tried getchar(). It looks like getchar() does NOT block execution so I can get characters in real time but if I copy/paste, it is too fast to catch all characters. I have a 100ms delay in the loop that catches the characters. Isn't there a buffer for console input?
Will getc(stdin) have a buffer but then has to wait for enter? I'll try and post back.
No, getc() also doesn't seem to be buffered. I copy and pasted 14 bytes of text to console, and esp32 got about 8. Why is it not buffered?
You need to create your own buffering scheme. There is an example of this in the examples directory.
Users browsing this forum: No registered users and 116 guests
