C library linkage fail in C++
urbanze
Postby urbanze » Mon Nov 18, 2019 4:52 pm
I trying to use "tinyexpr" library (C) in my main.cpp file but even with 'extern "C" {}', link can't completed. However, when I change my file to main.c, link can be completed. https://github.com/codeplea/tinyexpr
1. Here, is my real ambient (main.cpp file), trying to include tinyexpr C library. Yes, I need to declare app_main() as extern to compile .cpp. I believe the problem is here, but I can't remove extern "C" of app_main() .I've done dozens of tests, removing extern, including .c and so on...
extern "C"
    #include "tinyexpr/tinyexpr.h"
extern "C" void app_main()
    printf("%f\n", te_interp("5*5", 0)); /* Prints 25. */
2. Here, is my test ambient (main.c file) and work nicelly. I made this test only to know if library work.
#include "tinyexpr/tinyexpr.c"
void app_main()
Output error when main.cpp:
/build/main/libmain.a(main.o):(.literal.app_main+0x10): undefined reference to `te_interp'
/build/main/libmain.a(main.o): In function `app_main':
/main/main.cpp:9878: undefined reference to `te_interp'
collect2: error: ld returned 1 exit status
make: *** [/esp-idf/make/project.mk:517: /build/esp32.elf] Error 1
nvannote
Re: C library linkage fail in C++
Postby nvannote » Tue Nov 19, 2019 5:52 pm
While I did not flash a device to do a test run (I am sure it will work fine); This works perfectly fine for me (both as C and as C++).
#include <stdio.h>
#include <tinyexpr.h>
#ifdef __cplusplus
extern "C"
#endif
void app_main() {
I suspect what is happening in your case is that the tinyexpr.h is declaring the tinyexpr functions linkage as extern “C” during a C++ compile (which it will) and then you included the C source file into your C++ source, which will just result in the C source being compiled as C++. Hence the linker cannot resolve the extern “C” tinyexpr functions.
I would just allow tinyexpr.c be compiled as C standalone and all should be good.
What I did in my test harness was create a project local “components” directory and threw a symbolic link pointing to the tinyexpr directory (elsewhere where I keep third-party "stuff") along with an appropriately wired component.mk file.
My apologies if any of that wasn’t clear.
Regards,
Neil
urbanze
Postby urbanze » Wed Nov 20, 2019 11:27 am
#include <stdio.h>
#ifdef __cplusplus
extern "C"
#endif
void app_main() {
Regards,
Neil
Yes, tinyexpr.h use extern "C". I made some tests and none worked, see all:
1. NO
#ifdef __cplusplus
extern "C" {
#endif
void app_main()
#ifdef __cplusplus
#endif
2. NO
extern "C"
#ifdef __cplusplus
extern "C" {
#endif
void app_main()
#ifdef __cplusplus
#endif
Now, I removed extern "C" in tinyexpr.h library:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
3. Same then test 1, NO.
4. Same then test 2, NO.
What hell I need to do, I tryed all of my tips? :LOL:
PS: My main file is .cpp
PeterR
Postby PeterR » Wed Nov 20, 2019 7:45 pm
You cannot remove:
The ESP32 wants to call you and so your app_main() must be declared as "C" call style.
You can still stuff your app_main() full of vectors, maps etc but you must do as above (don't use { with app_main()).
nvannote
Postby nvannote » Wed Nov 20, 2019 8:00 pm
#include <stdio.h>
#ifdef __cplusplus
extern "C"
#endif
void app_main() {
Regards,
Neil
1. NO
#ifdef __cplusplus
extern "C" {
#endif
void app_main()
#ifdef __cplusplus
#endif
2. NO
extern "C"
#ifdef __cplusplus
extern "C" {
#endif
void app_main()
#ifdef __cplusplus
#endif
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
Hard to say, it could be any number of things.
Perhaps you compiled tinyexpr.c as a C++ source at one point and its object file is still floating around in your build directory; or perhaps tinyexpr.c is not getting built and included in the link at all?
I really don’t know how you have your project setup, what esp-idf and toolchain you’re using, or how you’re kicking off the build (make/cmake/manually). But I do know if you follow my reply above, it will work as C or C++, no problem.
I would start by getting a clean copy of tinyexpr as it doesn’t need modification (as far as I can tell), clear your build directory and start clean.
Regards,
Neil
urbanze
Postby urbanze » Wed Nov 20, 2019 11:33 pm
You cannot remove:
Well, I drag the exact same code, no work (same error)
Image of code and terminal output (https://drive.google.com/file/d/1nGyyAd ... sp=sharing).
Ps: Ignore compiler/ulp versions warnings from my raspberry, it always worked to all codes.
Error (always the same):
ESP_Angus
Postby ESP_Angus » Thu Nov 21, 2019 1:19 am
It looks like maybe your main component.mk doesn't add the "tinyexpr" subdirectory to COMPONENT_SRCDIRS?
This means the tinyexpr.c file is never compiled as part of the build. The hack where you #include "tinyexpr/tinyexpr.c" main.c works, because now the files are compiled as part of main.c.
Check your project's main/component.mk has some line like this:
COMPONENT_SRCDIRS := . tinyexpr
urbanze
Postby urbanze » Thu Nov 21, 2019 7:44 pm
Well, this worked! I just need to drag source files of library in the same folder of main.cpp and add "COMPONENT_SRCDIRS := . tinyexpr" to .mk
Thanks guys! I really needed this library to be included in our product.
Users browsing this forum: No registered users and 35 guests
