Page 1 of 2
jlink openocd error ?
Posted: Mon Nov 25, 2019 4:55 pm
by tabulous
Anyone know why this is happening ?
> Executing task: openocd -f interface/jlink.cfg -f board/esp-wroom-32.cfg <
Open On-Chip Debugger v0.10.0-esp32-20191114 (2019-11-14-14:19)
Licensed under GNU GPL v2
For bug reports, read
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 1000 kHz
Info : Configured 2 cores
Error: type 'esp32' is missing virt2phys
Info : J-Link EDU Mini V1 compiled Jul 10 2019 16:32:48
Info : Hardware version: 1.00
Info : VTarget = 3.206 V
Info : clock speed 1000 kHz
Info : esp32: Debug controller 0 was reset.
Info : esp32: Core 0 was reset.
Re: jlink openocd error ?
Posted: Wed Nov 27, 2019 11:51 am
by tabulous
bump ???
Posted: Thu Nov 28, 2019 4:23 am
by ESP_Sprite
Not sure why it specifically gives you an error, but indeed, ESP32 doesn't really have virtual memory. Does it work otherwise? If so, you can ignore that line.
Posted: Thu Nov 28, 2019 12:24 pm
by tabulous
This is all i get....
Info : J-Link EDU Mini V1 compiled Oct 22 2019 16:28:45
Info : VTarget = 3.212 V
Info : esp32: Debug controller 1 was reset.
Info : esp32: Core 1 was reset.
Posted: Fri Nov 29, 2019 2:30 am
by ESP_Sprite
Is there any program running on the ESP32? This smells like the watchdog timer keeps resetting it.
Posted: Mon Dec 02, 2019 12:01 pm
by tabulous
surely the JTAG should stop the watchdog ?
dont know what is running as its a new device.
Device is the esp32-pico-d4
Posted: Tue Dec 03, 2019 2:14 am
by ESP_Sprite
Can you try uploading a known-good program via flash? Not sure if the WDT gets disabled this early in the process.
Posted: Tue Dec 03, 2019 7:53 am
by tabulous
is there any way to clear the flash sections so just the bootlooader is there ?
thus if it was a wdg issue no apps would be running.
Posted: Wed Dec 04, 2019 2:36 am
by ESP_Sprite
No app being available is the problem, actually: the bootloader tries to load an app, sees none, then waits for the WDT to reset it. I *think* you can try to work around this by starting the ESP32 in download mode by pulling down GPIO0, but I'm not sure about that.
Posted: Thu Dec 05, 2019 2:15 pm
by tabulous
So if i hold the boot switch whilst cycling EN switch i get
C:\Users\LTrueman>openocd -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Info : VTarget = 3.234 V
but what is this
Error: type 'esp32' is missing virt2phys ???
