power save in esp32 with running can bus
divakara G R
Postby divakara G R » Mon Dec 02, 2019 7:02 am
Hi all
How can i implement power save mode in ESP32 while running CAN bus. Please anyone suggest me the any methods
Regards
Divakara G R
PeterR
Re: power save in esp32 with running can bus
Postby PeterR » Mon Dec 02, 2019 6:02 pm
What do you mean 'running the CAN bus'?
Do you mean 'will the hardware generate the ACK whilst in sleep mode'?
I don't know but easy enough to test with two ESPs back to back.
divakara G R
Postby divakara G R » Thu Dec 05, 2019 4:31 am
Running CAN means i need to wake-up esp when ever data from CAN bus without any data loss
Regards
Divakara G R
divakara G R
Postby divakara G R » Thu Dec 05, 2019 4:33 am
And also am worrying about WiFi Ap's DTIM period and beacon interval, how much it will affect the power consumption of esp32
Regards
Divakara G R
WiFive
Postby WiFive » Thu Dec 05, 2019 6:54 am
If you use an external can controller maybe you can use light sleep, otherwise probably not much.
divakara G R
Postby divakara G R » Fri Dec 06, 2019 4:36 am
THANK YOU
In Wifi whats the benefits of beacon interval and DTIM
Can you please suggest me the benefits of beacon interval and DTIM and in which power save mode its useful means shall we use these in light sleep and deep sleep also, because in light sleep and deep seep we are putting wifi to off then switching esp to power save mode so that?
Regards
Divakara G R
divakara G R
Postby divakara G R » Tue Dec 17, 2019 7:51 am
Hi All,
I have enabled automatic light sleep in esp-idf and using esp32 both Bluetooth and WiFi, its not going to sleep.
can anyone help me please as soon.....
Regards
Divakara G R
divakara G R
Postby divakara G R » Tue Dec 17, 2019 12:56 pm
Hello all
can anyone please do reply
Regards
Divakara G R
jcsbanks
Postby jcsbanks » Tue Dec 17, 2019 1:47 pm
AFAIK you cannot power save whilst being able to receive on CAN without losing data, unless the ESP32 is the only device on the bus doing the ACK, then there should be retransmits. You can wake the ESP32 on CAN bus activity due to change in level on the Rx pin.
divakara G R
Postby divakara G R » Wed Dec 18, 2019 5:13 am
Hi
Thank you, for your reply,
Okay we will use CAN as GPIO wake-up.
Can you please help me in another task there am using both Bluetooth and WiFi, and trying to put esp32 to light by configuring auto light sleep enable, but its not working esp32 is still consuming 100mA
Regards
Divakara G R
Users browsing this forum: Baidu [Spider], pad_52 and 20 guests
