Getting started with FreeRtos
guillaume55
Postby guillaume55 » Thu Mar 02, 2017 8:09 am
I'm new in FreeRtos coding (and coding). I've red tutorials about Freertos and watched videos but my code does not execute like I tkinked.
I use platformio IDE and esp32 devKit
#include <stdio.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "nvs_flash.h"
void task_priority1(void *pvParameter)
  while(1) {
    printf("priority = 1\n");
    vTaskDelay(1000
      /portTICK_RATE_MS);
void task_priority2(void *pvParameter)
  while(1) {
    printf("priority = 2\n");
    vTaskDelay(1000/portTICK_RATE_MS);
void task_priority3(void *pvParameter)
  while(1) {
    printf("priority = 3\n");
void task_priority4(void *pvParameter)
  while(1) {
    printf("priority = 4\n");
void app_main()
    system_init();
     xTaskCreate(&task_priority1, "priority1", 2048, NULL, 1, NULL);
     xTaskCreate(&task_priority2, "priority2", 2048, NULL, 2, NULL);
     xTaskreate(&task_priority3, "priority3", 2048, NULL, 3, NULL);
     xTaskCreate(&task_priority4, "priority4", 2048, NULL, 4, NULL);
    vTaskStartScheduler();
What happend :
priority = 2
priority = 1
priority = 3
priority = 4
a pause, and a lot of :
Register dump:
PC      Guru Meditation Error: Core  0 panic'ed (Interrupt wdt timeout on CPU0)
and then :
Register dump:
PC      Guru Meditation Error: Core  0 panic'ed (abort)
Backtrace: 0x40084d55:0x3ffc2440 0x00040023:0x3ffc2500 0x40084d55:0x3ffc2520 0x400
850e7:0x3ffc25a0 0x40080f9c:0x3ffc25e0
CPU halted.
I don't understand why this happend. On my mind this should print :
priority = 4
priority = 3
priority = 2
priority = 1
priority = 4
priority = 3
priority = 2
priority = 1
I hope you can explain why we begin by priority 2 and then 1, 3, 4 and why it crashs.
Guillaume
ESP_Sprite
Re: Getting started with FreeRtos
Postby ESP_Sprite » Thu Mar 02, 2017 8:48 am
First of all, you should end your tasks with vTaskDelete(NULL) to kill it. Returning from the task function is not allowed in FreeRTOS. Secondly, as soon as you schedule a task, it will immediately start running. Chances are it gets some runtime in before you schedule the next task, allowing it to do a printf; chances are also that it may not. It doesn't help that you're not pinning your tasks to a core: the ESP32 has 2 cores, so two tasks can be running at the same time, even if one has a higher priority than the other. (And this is literally 'at the same time', not the 'FreeRTOS fakes multiple tasks running at the same time by quickly switching between them'.)
All in all: at this moment, you're just testing the timing your tasks happen to be started at rather than task priority.
ESP_igrr
Postby ESP_igrr » Thu Mar 02, 2017 10:57 am
Also don't call vTaskStartScheduler(), this function is called before app_main starts. In fact, app_main runs within a FreeRTOS task already.
guillaume55
Postby guillaume55 » Thu Mar 02, 2017 11:20 am
The program works, thanks a lot
mbelda
Postby mbelda » Fri Oct 23, 2020 10:41 am
And what priority has app_main to run before the other tasks?
Users browsing this forum: No registered users and 40 guests
