I have a device with a large number of connections, and I'm trying to conserve as many GPIO pins as possible.
Would it be safe to use GPIO0 and GPIO3 with the I2C or I2S peripherals? I know these pins are needed by the serial bootloader, but they aren't needed once application code is running, right?
Using GPIO0 and GPIO3 for I2C or I2S
Re: Using GPIO0 and GPIO3 for I2C or I2S
I've verified this experimentally and it does actually work. I'm able to detect an I2C device and read registers, even while using the serial monitor. I assume that sending bytes via the monitor could cause issues, but I don't plan to be doing that in my use case.
Users browsing this forum: Baidu [Spider], Google [Bot], Majestic-12 [Bot] and 204 guests
