How to Visually Tell New from Old Silicon?
Re: How to Visually Tell New from Old Silicon?
The getChipRevision function in Arduino has a bug, by the way, as it has "&& EFUSE_RD_CHIP_VER_RESERVE_V" instead of "& EFUSE_RD_CHIP_VER_RESERVE_V". Also, the 8-bit EFUSE_RD_CHIP_VER_RESERVE field is used to encode a bunch of different things.
Lower 3 bits encode the package (0 = D0WDQ6, 1 = D0WDQ5, 2 = D2WDQ5), next 4 bits are reserved, the MSB is used for silicon version (0 = rev0, 1 = rev1).
We will have a function to check the chip revision/package in IDF soon and the updated efuse_reg.h file with these bit fields.
Ah, thank you Ivan,
now we get some more "new" details
we can test if the parcel delivery earliest next week ....
rudi
btw "new" details:
Who always keeps such information back to the end,
The silicon vallery, the manufacturer, the developer, the "discoverer" .....
love this "Salami tactics"
rudi
btw "new" details:
Thank you to both
Saw that piece of code being used in a driver, so I guess they are confident the method itself (which is similar to what rudi posted) works:
Source: https://github.com/espressif/esp-idf/bl ... clk.c#L133
uint32_t is_rev0 = (GET_PERI_REG_BITS2(EFUSE_BLK0_RDATA3_REG, 1, 15) == 0);
btw: LoLESP_igrr wrote:
The getChipRevision function in Arduino has a bug, by the way, as it has "&& EFUSE_RD_CHIP_VER_RESERVE_V" instead of "& EFUSE_RD_CHIP_VER_RESERVE_V". ....
https://github.com/espressif/arduino-es ... p.cpp#L120
uint8_t EspClass::getChipRevision(void)
return (REG_READ(EFUSE_BLK0_RDATA3_REG) >> EFUSE_RD_CHIP_VER_RESERVE_S) && EFUSE_RD_CHIP_VER_RESERVE_V;
int cpu_revission() {
One writes the same "error" from the other
More Interesting:
@Mike
the snippet code read register comes in esp-idf in past 14 days ( 2017 April 11 )
https://github.com/espressif/esp-idf/co ... b9e4abR133
the arduino got this "error" version on 2017 Feb 23 by "third party"
- added function to retrieve chip revision from eFuse
https://github.com/espressif/arduino-es ... 32/Esp.cpp
rudi
I pushed a PR
https://github.com/espressif/arduino-esp32/pull/704
May the efuse be changed ?
I mean, can a fraudolent seller change the efuse bit and so sell old rev 0 for a rev 1 ?
Reading through exposed APIs, I seem to find an ESP-IDF API called "esp_chip_info" which now reports a variety of items include:
* model
* features
* number of cores
* revision
I believe the revision fields is the silicon revision described in this post. This is a high level API and is probably more consumable that some of the other bit twiddlings.
* model
* features
* number of cores
* revision
I purchased a WROOM32 module a month ago after reading some reviews from buyers that mentioned they had received a rev 1 chip.
Looking for code to check the revision, I found Arduino code on instructables (and the same in a youtube video series on the ESP32)
http://www.instructables.com/id/How-to- ... our-ESP32/
I run this and it returns a chip revision of 0. Am pissed off, but then see that the code is obviously wrong - it's using a logical && instead of a bitmask &.
RTFM right ? So I downloaded the latest TRM and in Table 64, I see that the bitfield chip_version is in bits 12:9 of register EFUSE_BLK0_RDATA3_REG
So I run my own arduino code
which gives me
Still pissed off that I have a rev 0 chip. But I then find this page
https://github.com/espressif/esptool/issues/206
and on running 'python espefuse.py -p COM4 summary' I get the result
which tells me (phew) that I do have a ESP32-D0WDQ6 silicon revision 1 chip.
On running espefuse.py with a WROOM32 module I purchased last year, I found that it is a revision 0 chip, and my code returns
So i'm guessing the chip_version bitfield is bit 15:12, not 12:9
int getChipRevision()
return (REG_READ(EFUSE_BLK0_RDATA3_REG) >> (EFUSE_RD_CHIP_VER_RESERVE_S)&&EFUSE_RD_CHIP_VER_RESERVE_V) ;
#include "soc/efuse_reg.h"
void setup() {
Serial.begin(115200);
uint32_t reg = REG_READ(EFUSE_BLK0_RDATA3_REG);
Serial.printf("\r\nEFUSE_BLK0_RDATA3_REG = %08X\r\n", reg );
uint8_t chipRevision = (uint8_t)((REG_READ(EFUSE_BLK0_RDATA3_REG) >> 9 ) & 0x0F);
Serial.printf("Chip revision = %X\r\n" , chipRevision );
void loop() {
EFUSE_BLK0_RDATA3_REG = 00008000
Chip revision = 0
CHIP_VERSION Chip version = 8 R/W (0x8)
CHIP_PACKAGE Chip package identifier = 0 R/W (0x0)
EFUSE_BLK0_RDATA3_REG = 00000000
Chip revision = 0
For those who might be confused (like I was), here are the respective expected outputs as of 19th July 2018. Unfortunately I don't have a v0 chip to compare, but I presume the below all indicate that mine is a v1.
From instructables, after using the new shift globals:
result:
From espefuse.py:
From esptool.py chip_info:
return (REG_READ(EFUSE_BLK0_RDATA3_REG) >> (EFUSE_CHIP_VER_REV1_S)&&EFUSE_CHIP_VER_REV1_V) ;
REG_READ(EFUSE_BLK0_RDATA3_REG) 1010000000000000
EFUSE_CHIP_VER_REV1_S 1111
EFUSE_CHIP_VER_REV1_V 1
Chip Revision (official version): 1
Chip Revision from shift Opration 1
Identity fuses:
MAC MAC Address
= aa:aa:aa:aa:aa:aa (CRC 23 OK) R/W
CHIP_VER_REV1 Silicon Revision 1 = 1 R/W (0x1)
CHIP_VERSION Reserved for future chip versions = 2 R/W (0x2)
esptool.py v2.5.0
Serial port COM3
Connecting........__
Detecting chip type... ESP32
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse
MAC: aa:aa:aa:aa:aa:aa
Uploading stub...
Running stub...
Stub running...
Warning: ESP32 has no Chip ID. Reading MAC instead.
Hard resetting via RTS pin...
yep, the actually merged function use this method, so now the getChipRevision() return the correct hw revisionkolban wrote:Reading through exposed APIs, I seem to find an ESP-IDF API called "esp_chip_info" which now reports a variety of items include:
* model
* features
* number of cores
* revision
Users browsing this forum: No registered users and 196 guests
