Getting started with ESP32-S
tacitdesign
Postby tacitdesign » Mon Jan 13, 2020 2:38 pm
I am new to ESP32-S and have not used it before.
Of course, I am an experienced embedded firmware and hardware developer.
Are there any documents that help me to get info such as:
- Do I have to program my own WiFi stack or BLE stack?
- Does ESP32-S come preprogrammed with WiFi stack/BLE stack?
- How to program/debug the user defined code?
- I intent to use existing ESP32-S module and add my application functions.
Any help on this request will be appreciated.
Regards,
KMM
ESP_krzychb
Contact:
Re: Getting started with ESP32-S
Postby ESP_krzychb » Tue Jan 14, 2020 4:49 am
Hi KMM,
No.
Some modules, including ESP32-S, come preprogrammed with AT firmware.
See https://docs.espressif.com/projects/esp ... debugging/.
Note that modules loaded with stock AT firmware cannot be debugged with JTAG, see https://esp32.com/viewtopic.php?f=13&t= ... 837#p49837.
When using AT firmware the "application functions" should be placed in some external MCU sending the AT commands to the ESP32-S over UART.
To place your application functions inside ESP32-S, you can use one of several existing development frameworks, e.g. Arduino, MicroPython, ESP-IDF, to name a few.
tacitdesign
Postby tacitdesign » Tue Jan 14, 2020 7:11 am
Thank you for a quick response - appreciate that.
Let me share more info on what I want to achieve using ESP32-S module.
In my application, I want both WiFI and BT connectivity which will be provided by ESP32-S.
Now, I want to add RTC(for timestamp), add a switch(user input) to ESP32-S.
I don't have a plan to use another MCU to communicate with ESP32-S over UART/SPI for sending/receiving AT commands. I want to use the capability of ESP32-S for WiFi+BT and add my applications requirement(RTC and switch inputs as mentioned above).
Can you please help me to get started with?
I have installed Ardunio IDE. I am exploring which ESP32-S module to be used. Your suggestion on selecting ESP32-S module is welcome.
Regards,
KMM
ESP_krzychb
Contact:
Postby ESP_krzychb » Wed Jan 15, 2020 4:32 pm
Hello KMM,
I am not sure if there are more ESP32-S modules besides that I found in internet and linked in my previous post.
Maybe you meant recently released ESP32-S2 chip that is younger brother of mature ESP32? The ESP32-S2 does not have Bluetooth.
To get started quickly, as opposed to a bare module, I would use a board with USB port, e.g. ESP32-Dev-KitC.
Using a board with USB interface saves you once extra step to hook up a USB-to-UART adapter to the module for application loading.
You can then switch to using a module, once the application is ready.
The are numerous examples and videos describing use of Arduino IDE with ESP32-DevKitC that cover applications you mentioned.
I suggest starting with https://randomnerdtutorials.com/ or https://lastminuteengineers.com/ that I like for going into more advanced topis.
Users browsing this forum: Bing [Bot] and 71 guests
