Hi everyone.
I'll develop the sensor using the Bluetooth and Lora.
There are 30 sensors, each sensor sensing the temperature and send data.
Each 3 sensors are 1 Set.
My plan is that 3 sensors send data by Bluetooth.
Last one send all data to Lora Receiver using Lora.
Then Lora Receiver is shown all temperature data.
I don't use the Cloud.
I want to monitor the temperature at local panel display.
1. Can I use the Bluetooth and Lora at a same time?
(I think that using the time latency)
2. Is it possible the Lora Receiver can received data from 10 sensor or more?
(Each sensor have a own ID)
Thank you.
Using Bluetooth and Lora
- Lora.PNG (12.99 KiB) Viewed 2913 times
Re: Using Bluetooth and Lora
1. Yes
2. Yes, you have to follow usage policies if you are using lorawan but not with plain Lora.
Thanks Wifive to reply.
Users browsing this forum: Google [Bot] and 144 guests
