I am using ESP-WROOM-32 module of size 16Mb with esp-idf 3.3 version .
we connected a gsm module to ESP-WROOM-32 through Uart .
Unable to receive data through Uart above 120 bytes . I will receive maximum of 900 bytes through mqtt calls.
please suggest a solution or any code reference to receive data above 120 bytes through Uart .
Re: Unable to receive data through Uart above 120 bytes
How did you initialise the UART? How often do you get data from the UART?
I send 1000's of bytes up/down the UART so this issue seems related to how you setup your UART.
Post a MVE. Using PC and serial port its a few lines with a putty script/instruction.
thanks for response .
I am able to receive the data above 120 bytes with no problem using UART_NUM_0.
But i am unable to receive through using UART_NUM_1.
when i am sending data above 120 bytes to UART_NUM_1 . code is getting restarted with panic handler .
but when i send data below 120 bytes it able to receive . But the problem i with data above 120 bytes through UART_1
I used esp-idf-3.3 example code :
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "driver/uart.h"
#include "esp_log.h"
static const char *TAG = "uart_events";
* This example shows how to use the UART driver to handle special UART events.
* It also reads data from UART0 directly, and echoes it to console.
* - Port: UART0
* - Receive (Rx) buffer: on
* - Transmit (Tx) buffer: off
* - Flow control: off
* - Event queue: on
* - Pin assignment: TxD (default), RxD (default)
#define EX_UART_NUM UART_NUM_1
#define PATTERN_CHR_NUM (3) /*!< Set the number of consecutive and identical characters received by receiver which defines a UART pattern*/
#define BUF_SIZE (1024)
#define RD_BUF_SIZE (BUF_SIZE)
static QueueHandle_t uart0_queue;
static void uart_event_task(void *pvParameters)
uart_event_t event;
size_t buffered_size;
uint8_t* dtmp = (uint8_t*) malloc(RD_BUF_SIZE);
for(;;) {
//Waiting for UART event.
if(xQueueReceive(uart0_queue, (void * )&event, (portTickType)portMAX_DELAY)) {
bzero(dtmp, RD_BUF_SIZE);
ESP_LOGI(TAG, "uart[%d] event:", EX_UART_NUM);
switch(event.type) {
//Event of UART receving data
/*We'd better handler data event fast, there would be much more data events than
other types of events. If we take too much time on data event, the queue might
be full.*/
case UART_DATA:
ESP_LOGI(TAG, "[UART DATA]: %d", event.size);
uart_read_bytes(EX_UART_NUM, dtmp, event.size, portMAX_DELAY);
ESP_LOGI(TAG, "[DATA EVT]:");
uart_write_bytes(EX_UART_NUM, (const char*) dtmp, event.size);
//Event of HW FIFO overflow detected
case UART_FIFO_OVF:
ESP_LOGI(TAG, "hw fifo overflow");
// If fifo overflow happened, you should consider adding flow control for your application.
// The ISR has already reset the rx FIFO,
// As an example, we directly flush the rx buffer here in order to read more data.
uart_flush_input(EX_UART_NUM);
xQueueReset(uart0_queue);
//Event of UART ring buffer full
case UART_BUFFER_FULL:
ESP_LOGI(TAG, "ring buffer full");
// If buffer full happened, you should consider encreasing your buffer size
//Event of UART RX break detected
case UART_BREAK:
ESP_LOGI(TAG, "uart rx break");
//Event of UART parity check error
case UART_PARITY_ERR:
ESP_LOGI(TAG, "uart parity error");
//Event of UART frame error
case UART_FRAME_ERR:
ESP_LOGI(TAG, "uart frame error");
//UART_PATTERN_DET
case UART_PATTERN_DET:
uart_get_buffered_data_len(EX_UART_NUM, &buffered_size);
int pos = uart_pattern_pop_pos(EX_UART_NUM);
ESP_LOGI(TAG, "[UART PATTERN DETECTED] pos: %d, buffered size: %d", pos, buffered_size);
if (pos == -1) {
// There used to be a UART_PATTERN_DET event, but the pattern position queue is full so that it can not
// record the position. We should set a larger queue size.
// As an example, we directly flush the rx buffer here.
uart_read_bytes(EX_UART_NUM, dtmp, pos, 100 / portTICK_PERIOD_MS);
uint8_t pat[PATTERN_CHR_NUM + 1];
memset(pat, 0, sizeof(pat));
uart_read_bytes(EX_UART_NUM, pat, PATTERN_CHR_NUM, 100 / portTICK_PERIOD_MS);
ESP_LOGI(TAG, "read data: %s", dtmp);
ESP_LOGI(TAG, "read pat : %s", pat);
//Others
default:
ESP_LOGI(TAG, "uart event type: %d", event.type);
free(dtmp);
dtmp = NULL;
vTaskDelete(NULL);
void app_main()
esp_log_level_set(TAG, ESP_LOG_INFO);
/* Configure parameters of an UART driver,
* communication pins and install the driver */
uart_config_t uart_config = {
.baud_rate = 115200,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
uart_param_config(EX_UART_NUM, &uart_config);
//Set UART log level
//Set UART pins (using UART0 default pins ie no changes.)
uart_set_pin(EX_UART_NUM, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
//Install UART driver, and get the queue.
uart_driver_install(EX_UART_NUM, BUF_SIZE * 2, BUF_SIZE * 2, 20, &uart0_queue, 0);
//Set uart pattern detect function.
uart_enable_pattern_det_intr(EX_UART_NUM, '+', PATTERN_CHR_NUM, 10000, 10, 10);
//Reset the pattern queue length to record at most 20 pattern positions.
uart_pattern_queue_reset(EX_UART_NUM, 20);
//Create a task to handler UART event from ISR
xTaskCreate(uart_event_task, "uart_event_task", 2048, NULL, 12, NULL);
#include <stdio.h>
#include <string.h>
* - Port: UART0
* - Event queue: on
uart_event_t event;
for(;;) {
be full.*/
case UART_DATA:
case UART_FIFO_OVF:
case UART_BREAK:
//UART_PATTERN_DET
if (pos == -1) {
//Others
default:
free(dtmp);
dtmp = NULL;
vTaskDelete(NULL);
void app_main()
If you put your code within [/code] tags it will be easier to read.
Post the panic message as well.
At a guess I would say your task's stack size is too small. 2048 is not a lot if yoiu are going to log/printf. Try 5K and work back from that.
[code]
As a per ESP Wroom 32 , the flash interface pins are GPIO_10 and GPIO_9 which are WP and HD .
Can we use this Pins as UART1 ?
Is this cause a problem ?
Thanks for support
Thanks for support
It is in the datasheet
Note:
* Pins SCK/CLK, SDO/SD0, SDI/SD1, SHD/SD2, SWP/SD3 and SCS/CMD, namely, GPIO6 to GPIO11 are connected
to the integrated SPI flash integrated on ESP-WROOM-32 and are not recommended for other uses
Users browsing this forum: Google [Bot], Vineethad and 239 guests
