Page 1 of 2
ESP32 BLE : Dynamic data advertisment
Posted: Tue May 19, 2020 3:29 am
by Swagger
I'm trying to use ESP32 BLE GATT server code to advertise a data with my specific manufacture data. So I need to update manufacture data every seconds using a timer.
This is my manuafacture data looks like.
uint8_t advtimer_value = 0x22;
"uint8_t manufacture_specific_data[8] = {0x0b, advtimer_value, 0x02, 0x00};"
Till her it works and if i change the value in between then iam not able to update this advtimer_value in esp32. It says not a const . How should overcome this. Or is there any other way which i can achieve my goal.
Please help.
Re: ESP32 BLE : Dynamic data advertisment
Posted: Tue May 19, 2020 4:15 am
by chegewara
uint8_t manufacture_specific_data[8] = {0x0b, 0x0, 0x02, 0x00};
manufacture_specific_data[1] = advtimer_value;
Posted: Tue May 19, 2020 4:56 am
by Swagger
Hi , do i need to do anything on the below functions to get the changes reflected in my advertising frames.
case ESP_GAP_BLE_ADV_DATA_SET_COMPLETE_EVT:
adv_config_done &= (~ADV_CONFIG_FLAG);
if (adv_config_done == 0)
esp_ble_gap_start_advertising(&adv_params);
break;
case ESP_GAP_BLE_SCAN_RSP_DATA_SET_COMPLETE_EVT:
adv_config_done &= (~SCAN_RSP_CONFIG_FLAG);
break;
And my "advtimer_value" will be inside a timer, so do i just need to change the value there or do i need to make any changes in the BLE code.
Posted: Tue May 19, 2020 5:00 am
by Swagger
Hi thanks for the quick reply,
Do i need to make any changes in the belwo functions to reflect the changes in my advertsing frames,
break;
break;
My "advtimer_value" will be updated inside a timer functions, so do i just neeed to update the advtimer_value value ther or do i need to make any changes in the BLE functions.
Posted: Tue May 19, 2020 8:40 am
by chegewara
When advtimer_val is updated somewhere else, then you have to stop advertising, update manufacturer data and start advertising again.
Posted: Wed May 20, 2020 3:17 am
by Swagger
hi , thanks for your response.
uint8_t manufacture_specific_data[4] = {0x0b, 0xFF, 0x02, 0x00};
// scan response data
static esp_ble_adv_data_t scan_rsp_data = {
.set_scan_rsp = true,
.include_name = true,
.include_txpower = false,
.min_interval = 0x0006,
.max_interval = 0x0010,
.appearance = 0x00,
.manufacturer_len = sizeof(manufacture_specific_data),
.p_manufacturer_data = manufacture_specific_data,
.service_data_len = 0,
.p_service_data = NULL,
.service_uuid_len = ESP_UUID_LEN_128,
.p_service_uuid = service_uuid,
.flag = (ESP_BLE_ADV_FLAG_GEN_DISC | ESP_BLE_ADV_FLAG_BREDR_NOT_SPT),
I want to change the manufacture_specific_data[2]= advtimer_value ;
advtimer_value will be updated every second based on a timer.
But the advertising value is not getting any changes even if the " advtimer_value " in the time is changing every second. every time I change the value I am stopping the advertisement as you said and after changing the value restarting the advertisement.
What I am doing wrong.
Posted: Wed May 20, 2020 4:06 am
by chegewara
I dont have IDF example now, but here is simplest arduino example to show you idea:
#include <BLEDevice.h>
#include <BLEServer.h>
BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
uint8_t val;
void setup() {
  BLEDevice::init("esp32");
  BLEServer *pServer = BLEDevice::createServer();
void loop() {
  String _val = String(val++);
  BLEAdvertisementData data;
  data.setFlags(0x6);
  data.setManufacturerData(_val.c_str());
  pAdvertising->setAdvertisementData(data);
  pAdvertising->start();
  delay(1000);
Posted: Wed May 20, 2020 7:29 am
by Swagger
Iam using esp gatt server demo code
:https://github.com/espressif/esp-idf/bl ... tts_demo.c
uint8_t manufacture_specific_data[8] = { 0x0b, 0xFF, 0x02, 0x00};
uint8_t checkNum = 0;
/* The length of adv data must be less than 31 bytes */
static esp_ble_adv_data_t adv_data = {
.set_scan_rsp = false,
.include_name = false,
.min_interval = 0x20,
.max_interval = 0x40, //slave connection max interval, Time = max_interval * 1.25 msec
.appearance = 0x00,
// .manufacturer_len = sizeof(manufacture_specific_data),
// .p_manufacturer_data = &manufacture_specific_data,
.p_service_uuid = Huilan_service_uuid,
.appearance = 0x00,
static esp_ble_adv_params_t adv_params = {
.adv_int_min = 0x20,
.adv_int_max = 0x40,
.adv_type = ADV_TYPE_IND,
.own_addr_type = BLE_ADDR_TYPE_PUBLIC,
.channel_map = ADV_CHNL_ALL,
.adv_filter_policy = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
This is the timer call back where I updated the manufacture data
void periodic_timer_callback(void *arg)
checkNum++;
int64_t time_since_boot = esp_timer_get_time();
ESP_LOGI(timer_tag, "Periodic timer called, time since boot: %lld us", time_since_boot);
if (checkNum != 250)
dyn_adv_update(false);
manufacture_specific_data[2] = checkNum;
dyn_adv_update(true);
else
ESP_ERROR_CHECK(esp_timer_stop(periodic_timer));
ESP_ERROR_CHECK(esp_timer_delete(periodic_timer));
ESP_LOGI(timer_tag, "Stopped and deleted timers");
void dyn_adv_update(bool param)
if (param == false)
esp_ble_gap_stop_advertising();
if (param == true)
so that each time the periodic timer is called the manufacture data needs to be updated. The timer works fine. But the data is not getting updated when advertising.
Posted: Wed May 20, 2020 10:29 am
by kubera
Hi ,
I am also trying the same code from esp32 gatt server demo.
is there anything to do with the initialization of manufacture specifi data.
Posted: Wed May 20, 2020 11:11 am
by chegewara
You need to call this function only, and code you already have will take care of rest (will start advertising thru events):
esp_ble_gap_config_adv_data()
https://github.com/espressif/esp-idf/bl ... emo.c#L208
https://github.com/espressif/esp-idf/bl ... emo.c#L202
