header file of class and problem of including esp32 components
kyrpav
Postby kyrpav » Wed May 20, 2020 12:11 am
i have a c++ project and i want to control a motor. I created a class (.h and .cpp files separated) that should implement the mcpwm.
I can include the "driver/mcpwm.h" in the .cpp file but in the .h file (where i want to declare some variables and the functions) the autocomplete does not find driver folder so the header can not be included.
PeterR
Re: header file of class and problem of including esp32 components
Postby PeterR » Wed May 20, 2020 1:14 pm
Autocomplete?
Usually you just:
#include "mcpwm.h"
Might help to quote your IDF version, makefile etc.
kyrpav
Postby kyrpav » Wed May 20, 2020 7:51 pm
IDF version 4.2
makefile is :
cmake_minimum_required(VERSION 3.5)
project(motors)
when i say autocomplete is that when i write
#include ""
i can use ctl+space to give me the available headers as i am writing inside quotes.
Index is rebuild but it is not resolved. I can do it normally in .cpp file where i allows me to add
#include "driver/mcpwm.h"
but not in .h file.
As you can imagine i can not create an mcpwm_unit_t cause type can not be resolved (again in .h file)
PeterR
Postby PeterR » Wed May 20, 2020 11:55 pm
What IDE are you using and how is it setup?
It is nice to have a well setup IDE but sometimes you can over sweat this stuff and good old typing is quicker ;)
kyrpav
Postby kyrpav » Fri May 22, 2020 6:45 am
IDE is Eclipse 2020-03 and installation is done with the latest plugin version. System is Debian.
Used a blink example and changed the .c to .cpp and the makefile in proper way. I is working normally with other classes that i have separate .h and .cpp file.
I just can not include the components headers to the .h files.
Users browsing this forum: Bing [Bot] and 38 guests
