Hi dear,
After the program adjustment yesterday,the GPIO12/13/14/15 not be used now and the JTAG can normally build breakpoints,Thank you very much for your help these days~
thanks for your help,
regards,
Alisa
when use ESP-WROVER-KIT,always getting the message"Localhost:3333:Connection timed out."
Re: when use ESP-WROVER-KIT,always getting the message"Localhost:3333:Connection timed out."
No problem, great to hear you got it working.
@ESP_Sprite
How can one JTAG debug when SDCard is attached to the same pins as it is in Espressif WROVER and Olimex EVB designs??
Glenn
Glenn
Sorry, that's not possible. The SDMMC and JTAG pins conflict, so if you use the SDMMC pins to drive a SD-card, you cannot use JTAG. On the WROVER at least, the hardware does not interfere, so if you do not use SDMMC, JTAG works fine.
Users browsing this forum: Bing [Bot], Vineethad and 224 guests
