failed to connect SSID2 if SSID1 is failed
ht_main1
Postby ht_main1 » Sun Jul 05, 2020 10:48 am
i have 2 routers, for fail safe i have coded both ssid in code,
cont char* ssid1 = "htMark_01"
cont char* ssid2 = "htMark_02"
so if 1st failed connect to 2nd ssid, the problem i face is whenever ssid1 fails, ssid2 also keep failing, i also scan ap list, i do get ssid2 in scanned list still i get failure on connect.
even when i switch ssid2 and ssid1 i got same result, if 1st fails, then it wont connect to 2nd also.
i do call esp_wifi_disconnect before connecting to ssid2 , still i get failure
[APP] IDF version: v4.0
JSON of scan list
[{"ssid":"htMark_03","chan":6,"rssi":-44,"auth":3,"rom":0},
{"ssid":"htMark_02","chan":6,"rssi":-45,"auth":3,"rom":1},
{"ssid":"RCDigital","chan":5,"rssi":-72,"auth":3,"rom":0}]
[0m
[0;32mI (23198) esp32: Event Handler invoked[0m
[0;32mI (23198) esp32: [state]failed to connect ssid = htMark_02
is there anyway to do this? how should i debug ?
Users browsing this forum: Bing [Bot], Google [Bot], PeterR and 36 guests
