Allocation of Dynamic Memory
srinivas27194
Postby srinivas27194 » Thu Jul 30, 2020 3:47 pm
We are trying to capture six signals each with 4096 samples and sampling at 500 Hz.
vImag = 0.0;
vReal = (3.3/4095.0)*analogRead(25);
vReal1=(3.3/4095.0)*analogRead(26);
vReal2=(3.3/4095.0)*analogRead(27);
vImag1 = 0.0;
vImag = 0.0;
There was an error "dram segment data does not fit"
So we modified the code by referring to various suggestions provided online by adding pointers and using calloc function.
vReal = (float*)calloc(1,4096);
vImag = (float*)calloc(1,4096);
This time there was no error but when we displayed the result in serial monitor, there was a stack overflow message and there was no output displayed. Please let us know what could be the possible reason and how we could overcome this issue.
boarchuz
Re: Allocation of Dynamic Memory
Postby boarchuz » Thu Jul 30, 2020 4:30 pm
Are you sure it's a stack overflow? You can try increasing the task stack size, or share the code here if you think it shouldn't be happening.
Check those allocs. If you want enough memory for 4096 floats, you'll need 4096 * sizeof(float).
srinivas27194
Postby srinivas27194 » Tue Aug 04, 2020 7:58 am
I have attached the code for your reference.
MMD_Lite_tested.txt
(3.9 KiB) Downloaded 10 times
Users browsing this forum: Bing [Bot] and 60 guests
