ESP32 crashes if I use vTaskDelay in app_main function
mdaupu
Postby mdaupu » Sun Sep 13, 2020 6:52 pm
Hello everyone,
I have written a simple program using amazon freertos. I am using ESP32-WROOM-32UE module. If I use vTaskDelay in the app_main function, the ESP32 restarts. But if I use 9 or less than 9 value in the vTaskDelay, it works.
My question is, why esp32 restarts if I use more than 9ms delay in the app_main function?
My Code:
int app_main(void)
      printf("Hello World \r\n");
      prvMiscInitialization();
      config_gpio();
      display_task_create();
      while(1){
        vTaskDelay(100 / portTICK_PERIOD_MS);
  return 0;
Error Code:
Guru Meditation Error: Core 0 panic'ed (Unhandled debug exception)
Debug exception reason: BREAK instr
Core 0 register dump:
PC : 0x40081258 PS : 0x00000016 A0 : 0x40080306 A1 : 0x3ffc01b0
ESP_Sprite
Re: ESP32 crashes if I use vTaskDelay in app_main function
Postby ESP_Sprite » Mon Sep 14, 2020 7:48 am
Hard to say. Perhaps the initialization routines you call before the vTaskDelay corrupt something? What happens if you comment those out?
abansal22
Postby abansal22 » Mon Sep 14, 2020 5:28 pm
Hello everyone,
My Code:
int app_main(void)
      config_gpio();
      while(1){
  return 0;
Error Code:
Could you post the entire code and also let me know from where you get the source I could execute and let you know if same problem is with me or not!
PeterR
Postby PeterR » Mon Sep 14, 2020 9:07 pm
Great offer!
Or try adding 10K to your main & display task. You have a simple program so do 10/20K as a no brainer - you have the ram. Premature optimisation & all....
9 out of 10 crash issues tend to be stack size (assuming you know one end of a pointer from another).
LOG/printf() will burn a lot of stack & stack issues are hard to debug as you cannot diagnostic printf() without dieing (doh!)
If +10K stack doesn't do you then your into daft pointer issues IMHO.
chegewara
Postby chegewara » Mon Sep 14, 2020 9:56 pm
Just idea, are you sure that display_task_create(); task does not exit?
I see you are using esp-idf v3.3 and im not 100% sure that exiting task will display proper error message.
mdaupu
Postby mdaupu » Fri Sep 18, 2020 6:50 pm
Thank you guys for your replies. I have found the solution of this issue. In the main.c file, there is a define named IDLE_TASK_SIZE. The value was 100. I have changed it to 1000. Now I can use different vTaskDelay in the app_main function. The ESP32 does not reset now.
Users browsing this forum: Majestic-12 [Bot] and 51 guests
