ESP32 mqtt client ws_read() failure
PeterR
Re: ESP32 mqtt client ws_read() failure
Postby PeterR » Wed Sep 30, 2020 11:39 am
Thanks; great call!
A task delay works.
At the start of the investigation I added logic to test & set timeout to 1000mS if zero - but it sill failed. Must have put that in the wrong place!
The take away is:
(1) The fault happens when the ESP-IDF MQTT client receives a fragmented WS frames; when the header & payload do not arrive at the same time.
(2) I use the ESP-IDF websocket server to transmit MQTT server packets (both httpd_ws_send_frame_async() & httpd_ws_send_frame() produce this error).
Checking httpd_ws.c & WS header & payload are indeed sent seperately.
I would suggest that this is a fault in the ESP-IDF Websocket transport layer. It is perfectly possibly for header and payload to land at different times & indeed this is guarenteed when using the ESP-IDF Websocket server (albeit the segments may land close enough not to matter)!
I will go back and look at my timeout logic again and see if I can suggest a more polished fix.
Thanks again for the support & happy holidays!
PeterR
Postby PeterR » Wed Sep 30, 2020 1:28 pm
I had my timeout logic in the wrong place.
Setting:
timeout_ms = 1000;
after the header has been grabbed also works.
We discussed the timeout at the start of this topic & I think I now understand why you do not want a timeout on header search but you definitely want a timeout after!
PeterR
Postby PeterR » Tue Oct 06, 2020 9:17 am
Adding a timeout seems to fix.
There seems to be another websocket issue as detailed here:
ESP-Marius
Postby ESP-Marius » Fri Oct 09, 2020 10:13 am
Mind testing if this works for you? (without any of your timeouts)
Attached a diff
diff.txt
(1011 Bytes) Downloaded 12 times
PeterR
Postby PeterR » Mon Oct 12, 2020 11:26 am
The patch does not apply to my IDF: SHA-1: 84b51781c80740fda92784dafcfc96c13b0d8b66
The patch needs to be applied to latest IDF: SHA-1: 8bc19ba893e5544d571a753d82b44a84799b94b1
If I swap over to latest IDF & make -j8 flash then:
The following Python requirements are not satisfied:
gdbgui==0.13.2.0
pygdbmi<=0.9.0.2
reedsolo>=1.5.3,<=1.5.4
bitstring>=3.1.6
The recommended way to install a packages is via "pacman". Please run "pacman -Ss <package_name>" for searching the package database and if found then "pacman -S mingw-w64-i686-python-<package_name>" for installing it.
NOTE: You may need to run "pacman -Syu" if your package database is older and run twice if the previous run updated "pacman" itself.
Please read https://github.com/msys2/msys2/wiki/Using-packages for further information about using "pacman"
Diagnostic information:
    IDF_PYTHON_ENV_PATH: (not set)
    Python interpreter used: C:/msys32/mingw32/bin/python.exe
    Warning: python interpreter not running from IDF_PYTHON_ENV_PATH
    PATH: C:\msys32\mingw32\bin;C:\msys32\opt\xtensa-esp32-elf\bin;C:\msys32\mingw32\bin;C:\msys32\usr\local\bin;C:\msys32\usr\bin;C:\msys32\usr\bin;C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\msys32\usr\bin\site_perl;C:\msys32\usr\bin\vendor_perl;C:\msys32\usr\bin\core_perl
I've been down this path before & even with a clean MINGW toolchain I was unable to quickly resolve.
I have a working change (time-out). Happy to try yours though if you make a 84b51781c80740fda92784dafcfc96c13b0d8b66 patch.
PeterR
Postby PeterR » Thu Oct 22, 2020 10:49 am
@ESP-Marius
My timeout logic is not perfect. I still get:
TRANSPORT_WS: Error read data
TRANSPORT_WS: Error reading payload data
Would you please create your patch for my SHA 84b51781c80740fda92784dafcfc96c13b0d8b66 ?
ESP-Marius
Postby ESP-Marius » Fri Oct 23, 2020 10:44 am
@ESP-Marius
You can try the one I've attached now and see if that applies/helps.
ws.diff.txt
(8.36 KiB) Downloaded 12 times
PeterR
Postby PeterR » Tue Oct 27, 2020 10:32 am
Thanks, that looks good. I will comment again in a couple of weeks when it has been bedded in.
Had a couple of whitespace issues fixed with:
git apply --whitespace=fix ws.diff.txt
EDIT: PS - would you describe the change please? You modified the ESP MQTT client but packet to frame may be (0..1 : 0..1). Not had a chance to review in detail but interested in what you think was wrong with ESP MQTT client.
I know; gift horse etc....
Users browsing this forum: No registered users and 39 guests
