Interest in developer preview?
Re: Interest in developer preview?
Postby rudi ;-) » Sat Aug 27, 2016 1:35 pm
[ advanced note ]
AES_IDLE_REG
*) i have not used this in preview code, for certain reasons.
but want now use - not sure - so i ask:
in technical reference manual read,
we wait for AES_IDLE_REG until reads 1
*) just in time missed a VAR for it or a define.
in esp32_technical_reference_manual_en
AES_IDLE_REG is described on side 116 with address 0x3FF01004
for a try i added directly in eagle.fpga32.rom.addr.v7.ld
PROVIDE (AES_IDLE_REG = 0x3FF01004 );
and define in global app code
extern int AES_IDLE_REG;
in app code i wait for the AES_IDLE_REG reads 1
while ( AES_IDLE_REG != 1) ;
not sure - is this just in time the right way for AES_IDLE_REG ? ( int ? )
compile & link done - can't test flash - have no modul with esp32 release.
edit: ( S. 117 )
but think this is not the right way, because
register 10.2: AES_IDLE_REG (0x004)
is 32bit
your further help and critical ("never change the ld file" )
is welcome :)
Postby rudi ;-) » Sun Aug 28, 2016 10:40 pm
rudi ;-) wrote:
full app with decrypt comes asap in example code folder
for a flashing you must wait :)
i have no modul from ESP32 Release :)
uploaded a demo (beta ) code with crypt and decrypt.
jmattsson
Postby jmattsson » Wed Aug 31, 2016 6:59 am
Whoa... no kidding that things have changed! :)
This is going to take a while to digest...
@ESP_Sprite: Do you know if the ESP8266 will get a similar IDF (to replace the RTOS-SDK, perhaps)?
Postby ESP_Sprite » Wed Aug 31, 2016 10:14 am
ESP-IDF for the ESP8266: Maybe. It should be pretty easy to take the existing binary libraries and put them into the ESP-IDF framework, that's not an issue. To make support for the ESP8266 in ESP-IDF as full-featured as the ESP32 is, is a different story. We're not sure what the plans are with regards to that.
jmattsson
Postby jmattsson » Thu Sep 01, 2016 12:34 am
Thanks for the update! At the moment it feels like the esp8266 and esp32 sdks are diverging rather than converging, and I'm trying to figure out the best way for the NodeMCU project to support both platforms with as little maintenance effort as possible. From a "lazy developer" point of view, I'd love to see the esp8266 sdk take the same path (and pace) as the esp32.
ESP_igrr
Postby ESP_igrr » Fri Sep 02, 2016 12:51 am
jmattsson: are you interested in getting the 8266 RTOS or non-OS SDK within ESP-IDF?
jmattsson
Postby jmattsson » Fri Sep 02, 2016 1:27 am
@igrr__: The RTOS SDK. I don't really consider it feasible to support a non-OS SDK ESP8266 and a RTOS SDK ESP32 in the same code branch. And the RTOS is much nicer to work with, even if it comes at a bit of a memory cost.
cvgaviao
Postby cvgaviao » Sun Sep 04, 2016 2:32 pm
ESP_Sprite wrote:Okay, we released the SDK.
Well, I have to congrats the Espressif team for this excellent job.
I tried the ESP-IDF today. its embedded documentation is clean and it is much easier to setup than ESP8266 one.
the menu config is awesome !
thank you all, well done !!!
jmattsson
Thoughts on the IDF
Postby jmattsson » Thu Sep 22, 2016 1:58 am
Having now actively worked with the IDF over the last week, I must say this is really, really nice! Despite it still being the early days, it's feeling very slick, powerful and friendly. Sure, the docs are still a bit short in quantity, but certainly not in quality.
And while I've certainly got a soft spot for the old NonOS-SDK's rough, hackish charm, there's just no comparison. The IDF is already feeling like a mature offering and I can only see it getting better. Great work, everyone! :)
Users browsing this forum: No registered users and 66 guests
