how to read i2c with esp32 NodeMCU
A.Mourazo
Postby A.Mourazo » Wed Nov 11, 2020 2:49 pm
I'm trying to read the i2c data from a scl30 sensor co2, but the esp32 don't doing anything, I'm write the sketch with Arduino IDE, how can I read sda y scl for gpio34 and gpio35 pins? The sensor works with an arduino and, with esp32 the power supply it's on, I see the infrared ligth but when I try to read the data the serial monitor it's empty and not recive data. What can I do? Thanks in advance
#include <Wire.h>
#include "SparkFun_SCD30_Arduino_Library.h" //Click here to get the library: http://librarymanager/All#SparkFun_SCD30
SCD30 airSensor;
void setup()
  Serial.println("SCD30 Example");
  Wire.begin(35,34, 1000000);
  if (airSensor.begin() == false)
    Serial.println("Air sensor not detected. Please check wiring. Freezing...");
    while (1)
  //The SCD30 has data ready every two seconds
void loop()
  if (airSensor.dataAvailable())
    Serial.print("co2(ppm):");
    Serial.print(airSensor.getCO2());
    Serial.print(" temp(C):");
    Serial.print(airSensor.getTemperature(), 1);
    Serial.print(" humidity(%):");
    Serial.print(airSensor.getHumidity(), 1);
    Serial.println();
  else
    Serial.println("Waiting for new data");
  delay(500);
felmue
Re: how to read i2c with esp32 NodeMCU
Postby felmue » Mon Nov 16, 2020 4:50 pm
Hello
GPIO34 and GPIO35 can only be used as inputs. SCL requires an output and SDA needs to be input and output.
Please see Pin Definition here: https://www.espressif.com/sites/default ... eet_en.pdf
Felix
Users browsing this forum: xlfdan and 39 guests
