GPIO21 - Issues
Foxabilo
GPIO21 - Issues
Postby Foxabilo » Tue May 09, 2017 10:06 am
Hi All,
Having a bit of an Issue with GPIO21
In essence I am setting GPIO21 to Input and attempting to set it floating, no matter what setting I seem to apply to that particular pin I can only get it to read a change in level when using a less than 780 Ohm resistor in series, i.e. GPIO36 will change no problem even with a 50k R in series , all of the other pins seems to be just fine, not sure what I could be doing wrong to make GPIO21 so difficult to change voltage level on.
I have tried setting the pins as a group and setting them individually, same result each time. Any pointers would be great.
These are the different bits of code I have tried.
#include <string.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "driver/uart.h"
#include "lwip/err.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include "lwip/netdb.h"
#include "lwip/dns.h"
#include "lwip/pppapi.h"
#include "driver/gpio.h"
#include "BootLoadNXP.h"
#include "NXPuart_events.h"
#include "driver/adc.h"
#define GPIO_OUTPUT_PIN_SEL  (GPIO_SEL_25 | GPIO_SEL_26 | GPIO_SEL_32 | GPIO_SEL_13 | GPIO_SEL_14)
#define GPIO_INPUT_PIN_SEL  (GPIO_SEL_36 | GPIO_SEL_21)
#define Tamper GPIO_NUM_36
#define POWER_CHANNEL GPIO_NUM_21
#define ESP_INTR_FLAG_DEFAULT 0
int Set_Pin_Input(int PinNumber)
	return gpio_set_direction(PinNumber, GPIO_MODE_INPUT);
int Set_Pin_Float(int PinNumber)
	return gpio_set_pull_mode(PinNumber, GPIO_FLOATING);
int Set_Pin_PullUp(int PinNumber)
	return gpio_set_pull_mode(PinNumber, GPIO_PULLUP_ONLY);
int Set_Pin_PullDown(int PinNumber)
	return gpio_set_pull_mode(PinNumber, GPIO_PULLDOWN_ONLY);
void app_main()
	gpio_config_t io_conf;
    //disable interrupt
    io_conf.intr_type = GPIO_PIN_INTR_DISABLE;
    //set as output mode
    io_conf.mode = GPIO_MODE_OUTPUT;
	//bit mask of the pins that you want to setf,e.g.GPIO18/19
    io_conf.pin_bit_mask = GPIO_OUTPUT_PIN_SEL;
    //disable pull-down mode
    io_conf.pull_down_en = 0;
    //disable pull-up mode
    io_conf.pull_up_en = 0;
	gpio_config(&io_conf); // Works Fine
	//disable interrupt
	io_conf.intr_type = GPIO_INTR_NEGEDGE;
	io_conf.mode = GPIO_MODE_INPUT;
	io_conf.pin_bit_mask = GPIO_INPUT_PIN_SEL;
	int n;
	n=0;
	while(n<10)
		if (gpio_get_level(Tamper) == 0) printf("TAMPER!!\n");
		printf("The Power Level is value:%d\n",gpio_get_level(POWER_CHANNEL));
		n++;
	gpio_pad_select_gpio(Tamper);
	if (Set_Pin_Input(Tamper) != ESP_OK) printf("Error Selecting Tamper Pin as Input\n");  //Works FINE
	if (Set_Pin_Float(Tamper) != ESP_OK) printf("Error Setting Tamper Pin as Floating\n"); //Works FINE
	n=0;
	while(n<10)
		n++;
	gpio_pad_select_gpio(POWER_CHANNEL);
	if (Set_Pin_Input(POWER_CHANNEL) != ESP_OK) printf("Error Selecting POWER INDICATOR Pin as Input\n");  //Seems to Work Fine
	if (Set_Pin_Float(POWER_CHANNEL) != ESP_OK) printf("Error Setting POWER INDICATOR Pin as Floating\n"); //Seems to Work Fine
	while(1)
ESP_Sprite
Re: GPIO21 - Issues
Postby ESP_Sprite » Wed May 10, 2017 1:58 am
What hardware are you doing this on? Are you sure there's no external resistor pulling the gpio up or down?
Foxabilo
Re: GPIO21 - Issues
Postby Foxabilo » Mon Jul 03, 2017 6:18 am
Problem solved.... I had a voltage divider on the pin... just get it to change state for a given input (a power input detector with battery backup) and SOMEONE... who will remain nameless forgot to solder one of the divider resistors on.....
Thanks for the help.... Error between Chair and Keyboard ...
Users browsing this forum: Baidu [Spider] and 134 guests
