WDT timeout in bootloader for ESP32s2
Re: WDT timeout in bootloader for ESP32s2
See the ESP32-S2-Wrover datasheet, and specifically the note for GPIO26: "By default, IO26 is connected to the CS pin of the PSRAM and cannot be used for other functions."
I have just got it from the datasheet.
Is there a way do disable PSRAM SPICS1 so that GPIO26 can be used for general purpose?
Notice:
• By default, IO26 is connected to the CS pin of the PSRAM and cannot be used for other functions.
• For peripheral pin configurations, please refer to ESP32-S2 Datasheet.
Well, the issue is not in the ESP32, the issue is that you still physically have the PSRAM connected to that pin. Using it as a GPIO means that whenever that GPIO is low, the PSRAM will listen on commands on the SPI bus and respond to them... which is a bit of a problem as normally the flash also tries to communicate there, and the psram will 'overwrite' its responses. So in practice: generally no, that pin is not usable as GPIO on a module with PSRAM.
Users browsing this forum: No registered users and 142 guests
