I have been working on a project that need WiFi and Bluetooth to work together. Since ESP32 antenna works for Bluetooth and WiFi, I was wondering if I could solder a SMA antenna to the ESP board and make it work only for WiFi or only for Bluetooth, and the built in antenna to will work for only WiFi or only Bluetooth too. If it is possible would I need to change something inside Software from ESP32, or I would only need to solder the SMA antenna?
I would need to make them work together because, In my project, when the user types "delete" from the Bluetooth connection, the WiFi ssid and password are going to be deleted, so the user can type the new ssid and new password.
If you need a more specific details from my project: https://stackoverflow.com/questions/656 ... 9#65639339
ESP32 Adding SMA Antenna only for WiFi or Bluetooth
Re: ESP32 Adding SMA Antenna only for WiFi or Bluetooth
You can't separate BT and WiFi as apart from the antenna, they also share the radio they use to send and receive signals.
We have pretty good WiFi and BLE coexistence, and there is no reason why you wouldn't be able to keep a BT connection going while you disconnect and reconnect WiFi, especially if all you do is move some text over BT.
I heard ESP32 can not well support data transaction of Wi-Fi softAP and Bluetooth simutaneously ..ESP_Sprite wrote: ↑Tue Jan 12, 2021 6:46 amYou can't separate BT and WiFi as apart from the antenna, they also share the radio they use to send and receive signals.
We have pretty good WiFi and BLE coexistence, and there is no reason why you wouldn't be able to keep a BT connection going while you disconnect and reconnect WiFi.
https://github.com/espressif/esp-idf/is ... -745136514
Sure, but if you use BT to connect to an (existing I assume?) WiFi access point, you wouldn't need SoftAP.
I haven't been able to work with that. I have attempted to, but if WiFi gets connected Bluetooth gets disconnected.ESP_Sprite wrote: ↑Tue Jan 12, 2021 6:46 amYou can't separate BT and WiFi as apart from the antenna, they also share the radio they use to send and receive signals.
Users browsing this forum: Bing [Bot], bobolink, Google [Bot] and 39 guests
