Trouble Wifi connection
Atelier R2D2
Postby Atelier R2D2 » Thu Jan 14, 2021 10:54 am
Configuration :
- Microcontroller: ESP-VROOM-32D
- Software: IDE Arduino v1.8.13
- Library : Wifi by Arduino v1.2.7
Program : https://pastebin.pl/view/30e9fa8c (The identifiers are removed, however I checked and the problem does not come from there).
When I load this program, I don't get any error. However, it does not connect to the desired wifi network. This program worked however, I did some more tests and then it did not work. I tried it on three same ESP (including a new one).
Does the problem come from the library? Or is it the ESP that is the problem?
Thank you in advance for your help
Users browsing this forum: No registered users and 38 guests
