Ah that is interesting. So vdd_sdio is powered on before efuse is read. I guess if it wasn't then it would impact flash startup time. So this applies to WROVER as well?ESP_igrr wrote:Okay, can i finally give the reason why we don't burn the efuse for 1.8V in D2WD. The reason is, if the VDD_SDIO is configured by efuse, it takes some time for the hardware to read efuse values at startup. If the strapping pin configures VDD_SDIO to be 3.3V, then during this time, VDD_SDIO will be 3.3V. As soon as efuse read is complete, the regulator will switch to 1.8V.
D0WD D2WD WROOM-32 WROVER deep sleep SPI Flash pSRAM
Re: D0WD D2WD WROOM-32 WROVER deep sleep SPI Flash pSRAM
WiFive wrote:[
@ivan
thank you for the clarification - this is a "must2know" detail.
@WiFive
the procedure to start and read efuses / bootstrap pins i tink is the same - but not sure that this is so.
rudi
from the readthedocs
the standing theme 1.8V from flash and psram speak detailed 1.8V:
alternate: but we can use 3.3 flash and 3.3 pSRAM-32 too right?
it is not a must2take 1.8V doing, or? then there is no need to use bootstrap or efuse.
does this Interfering ULP or deep sleep?
rudi
ESP-64 then support 64MBit pSRAM 3.3V - and 64MBit pSRAM 1.8V too ? )
rudi
Users browsing this forum: No registered users and 221 guests
