The startup output log is as follows:
******2021/2/19 16:48:22******
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6352
ho 0 tail 12 room 4
load:0x40078000,len:11332
load:0x40080400,len:6564
entry 0x40080760
[0;32mI (30) boot: ESP-IDF v3.3 2nd stage bootloader[0m
[0;32mI (30) boot: compile time 06:11:15[0m
[0;32mI (30) boot: Enabling RNG early entropy source...[0m
[0;32mI (34) boot: SPI Speed : 40MHz[0m
[0;32mI (39) boot: SPI Mode : DIO[0m
[0;32mI (43) boot: SPI Flash Size : 4MB[0m
[0;32mI (47) boot: Partition Table:[0m
[0;32mI (50) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (58) boot: 0 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (65) boot: 1 otadata OTA data 01 00 00010000 00002000[0m
[0;32mI (73) boot: 2 nvs WiFi data 01 02 00012000 0000e000[0m
[0;32mI (80) boot: 3 at_customize unknown 40 00 00020000 000e0000[0m
[0;32mI (87) boot: 4 ota_0 OTA app 00 10 00100000 00180000[0m
[0;32mI (95) boot: 5 ota_1 OTA app 00 11 00280000 00180000[0m
[0;32mI (102) boot: End of partition table[0m
[0;32mI (107) boot: No factory image, trying OTA 0[0m
[0;32mI (112) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x247c4 (149444) map[0m
[0;32mI (173) esp_image: segment 1: paddr=0x001247ec vaddr=0x3ffbdb60 size=0x03028 ( 12328) load[0m
[0;32mI (178) esp_image: segment 2: paddr=0x0012781c vaddr=0x40080000 size=0x00400 ( 1024) load[0m
[0;32mI (180) esp_image: segment 3: paddr=0x00127c24 vaddr=0x40080400 size=0x083ec ( 33772) load[0m
[0;32mI (203) esp_image: segment 4: paddr=0x00130018 vaddr=0x400d0018 size=0xee128 (975144) map[0m
[0;32mI (545) esp_image: segment 5: paddr=0x0021e148 vaddr=0x400887ec size=0x0f108 ( 61704) load[0m
[0;32mI (571) esp_image: segment 6: paddr=0x0022d258 vaddr=0x400c0000 size=0x00064 ( 100) load[0m
[0;32mI (585) boot: Loaded app from partition at offset 0x100000[0m
[0;32mI (619) boot: Set actual ota_seq=1 in otadata[0][0m
[0;32mI (619) boot: Disabling RNG early entropy source...[0m
2.0.0
max tx power=78,ret=0
If the official program cannot be started after compiling and burning, the effect is as follows:
******2021/2/19 16:36:46******
load:0x3fff001c,len:6992
ho 0 tail 12 room 4
load:0x40078000,len:13712
load:0x40080400,len:4260
entry 0x400806e4
[0;32mI (73) boot: Chip Revision: 1[0m
[0;32mI (73) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m
[0;32mI (40) boot: ESP-IDF v4.0.1-193-ge7ac221b4 2nd stage bootloader[0m
[0;32mI (40) boot: compile time 16:07:36[0m
[0;32mI (41) boot: Enabling RNG early entropy source...[0m
[0;32mI (46) boot: SPI Speed : 40MHz[0m
[0;32mI (50) boot: SPI Mode : DIO[0m
[0;32mI (54) boot: SPI Flash Size : 4MB[0m
[0;32mI (58) boot: Partition Table:[0m
[0;32mI (62) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (69) boot: 0 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (77) boot: 1 otadata OTA data 01 00 00010000 00002000[0m
[0;32mI (84) boot: 2 nvs WiFi data 01 02 00012000 0000e000[0m
[0;32mI (92) boot: 3 at_customize unknown 40 00 00020000 000e0000[0m
[0;32mI (99) boot: 4 ota_0 OTA app 00 10 00100000 00180000[0m
[0;32mI (107) boot: 5 ota_1 OTA app 00 11 00280000 00180000[0m
[0;32mI (114) boot: End of partition table[0m
[0;32mI (119) boot: No factory image, trying OTA 0[0m
[0;32mI (123) boot_comm: chip revision: 1, min. application chip revision: 0[0m
[0;32mI (131) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x294b0 (169136) map[0m
[0;32mI (200) esp_image: segment 1: paddr=0x001294d8 vaddr=0x3ffbdb60 size=0x03950 ( 14672) load[0m
[0;32mI (206) esp_image: segment 2: paddr=0x0012ce30 vaddr=0x40080000 size=0x00400 ( 1024) load[0m
[0;32mI (207) esp_image: segment 3: paddr=0x0012d238 vaddr=0x40080400 size=0x02dd8 ( 11736) load[0m
[0;32mI (221) esp_image: segment 4: paddr=0x00130018 vaddr=0x400d0018 size=0x107a38 (1079864) map[0m
[0;32mI (611) esp_image: segment 5: paddr=0x00237a58 vaddr=0x400831d8 size=0x19810 (104464) load[0m
[0;32mI (655) esp_image: segment 6: paddr=0x00251270 vaddr=0x400c0000 size=0x00064 ( 100) load[0m
[0;32mI (673) boot: Loaded app from partition at offset 0x100000[0m
[0;32mI (706) boot: Set actual ota_seq=1 in otadata[0][0m
[0;32mI (706) boot: Disabling RNG early entropy source...[0m
2.1.0
At program cannot be started after burning binary file
Users browsing this forum: Baidu [Spider], morsisko and 46 guests
