ESP32-S2 Deep sleep Power consumption
chal7401
Postby chal7401 » Tue Apr 13, 2021 5:12 pm
Hi, Firts post here
I'm making a program for the ESP32-S2 on ESP-IDF that takes a measurement, reports it and goes to sleep, the datasheet says the module should consume around 25 uA when using RTC_Memory an I get that when I just write a code that puts the module to sleep, but when a flash the program for my application it consumes 200 uA, before it was over 1mA but noticed the ADC module was still on, after turning it off it came down to the mentioned 200uA, can you guys help me figure out what else might be still on while on deep sleep?
I can't share the whole code but here is the configuration part.
    gpio_config_t io_conf;
    io_conf.intr_type = GPIO_PIN_INTR_DISABLE;
    io_conf.pull_down_en = 0;
    io_conf.pull_up_en = 0;
    io_conf.mode = GPIO_MODE_INPUT;
    io_conf.pin_bit_mask = INPUT_LIST;
    gpio_config(&io_conf);
    io_conf.mode = GPIO_MODE_OUTPUT;
    io_conf.pin_bit_mask = OUTPUT_LIST;
    esp_adc_cal_check_efuse(ESP_ADC_CAL_VAL_EFUSE_TP);
    adc1_config_width(width);
    adc1_config_channel_atten(channel_VIN, atten);
    adc1_config_channel_atten(channel_EM3242, atten);
    adc_chars = calloc(1, sizeof(esp_adc_cal_characteristics_t));
    esp_adc_cal_characterize(unit, atten, width, 1100, adc_chars);
    esp_sleep_enable_ext0_wakeup(BTN_SC, false);
I have 2 outputs and 2 inputs(1 being analog), I don't keep any output either high or low when going into deep sleep, ulp is powered off, the code uses wi-fi for the report but I turn it off properly before going to sleep, I also use NVS_Flash.
chal7401
Re: ESP32-S2 Deep sleep Power consumption
Postby chal7401 » Wed Apr 14, 2021 8:02 pm
Ok so it seems like is beacuse of the EXT0 wake up source, Am I not configuring it properly or does it always consume more by using EXT0?
I'm using esp_deep_sleep(120000000); for going into deep sleep, the debugging log dumps all of the RTC domains On when going into deep sleep, but it also show that when consuming just 25uA.
Users browsing this forum: No registered users and 273 guests
