Flash read error, 1000 on custom PCB
Kaydrae
Postby Kaydrae » Mon Apr 19, 2021 9:23 pm
I have this PCB that I designed around the esp32-wroom-32D and I am using an esp32-wroom-32 programmer to be able to connect it through serial. But when I connect it I get the following error in the serial output:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
ets Jun  8 2016 00:22:57
I am not sure what the problem is, The board was assembled from jlcpcb, so I soldered nothing on there. I have posted the schematic. Am I missing something? Thanks in advance.
Schematic_Rob_Tank_2021-04-19.pdf
(200.05 KiB) Downloaded 273 times
WiFive
Re: Flash read error, 1000 on custom PCB
Postby WiFive » Tue Apr 20, 2021 5:27 am
boot:0x32
Gpio12 is high which is selecting 1.8v sdio voltage. You need to burn the efuse to lock it to 3.3v
Kaydrae
Postby Kaydrae » Tue Apr 20, 2021 6:40 am
How would I do that? Could I also ground gpio12 to fix the problem?
Users browsing this forum: Baidu [Spider] and 218 guests
