Where is GPIO pin 25 on the ESP32 S2 Saola?
MEL_21
Postby MEL_21 » Sun May 02, 2021 3:31 pm
Hello all,
I want to use I2S to read samples from a microphone and looked at the sample code (in the ESP-IDF Programming Guide) to configure the reading:
static const i2s_pin_config_t pin_config = { .bck_io_num = 26,
.ws_io_num = 25,
.data_out_num = 22,
    .data_in_num = I2S_PIN_NO_CHANGE
the ESP32 S2 Saola has no pins 22,23,24,25 - how is this supposed to be configured? which pins can I use for I2S?
Thanks for reading,
Markus
ESP_krzychb
Contact:
Re: Where is GPIO pin 25 on the ESP32 S2 Saola?
Postby ESP_krzychb » Mon May 03, 2021 2:12 am
Hello Markus,
The example is indeed incorrect (likely it has been carried over from ESP32 and not revised afterwards). Sorry for confusion!
You can configure any other pins you have available on your board following some restrictions mentioned in https://docs.espressif.com/projects/esp ... /gpio.html
Users browsing this forum: No registered users and 206 guests
