How to setup RMT timings for neopixel LED's
zazas321
Postby zazas321 » Thu May 06, 2021 5:32 am
Hello. I am learning about the RMT and neopixels. I have found adafruit neopixel library :
https://github.com/adafruit/Adafruit_NeoPixel
The library is using RMT to drive the neopixels.
I have also read espressif documentation on rmt and found this great example project:
Both projects are very simmilar in terms of RMT, however, it is still not fully clear to me how RMT timings are setup. In the espressif RMT example, the rmt_item_t is setup as following :
 const rmt_item32_t bit0 = {{{ 32767, 1, 15000, 0 }}}; //Logical 0
 const rmt_item32_t bit1 = {{{ 32767, 1, 32767, 0 }}}; //Logical 1
I want t understand how these values correspond to actual time . What is the formula behind it?
In the neopixel adafruit library the things get even more confusing , please see the following functions
static void IRAM_ATTR ws2812_rmt_adapter(const void *src, rmt_item32_t *dest, size_t src_size,
                                         size_t wanted_num, size_t *translated_size, size_t *item_num)
    if (src == NULL || dest == NULL)
        *translated_size = 0;
        *item_num = 0;
        return;
    const rmt_item32_t bit0 = {{{t0h_ticks, 1, t0l_ticks, 0}}}; //Logical 0
    const rmt_item32_t bit1 = {{{t1h_ticks, 1, t1l_ticks, 0}}}; //Logical 1
    size_t size = 0;
    size_t num = 0;
    uint8_t *psrc = (uint8_t *)src;
    rmt_item32_t *pdest = dest;
    while (size < src_size && num < wanted_num)
        for (int i = 0; i < 8; i++)
            // MSB first
            if (*psrc & (1 << (7 - i)))
                pdest->val = bit1.val;
            else
                pdest->val = bit0.val;
            num++;
            pdest++;
        size++;
        psrc++;
    *translated_size = size;
    *item_num = num;
void espShow(uint8_t pin, uint8_t *pixels, uint32_t numBytes)
    // Reserve channel
    rmt_channel_t channel = ADAFRUIT_RMT_CHANNEL_MAX;
    for (size_t i = 0; i < ADAFRUIT_RMT_CHANNEL_MAX; i++)
        if (!rmt_reserved_channels[i])
            rmt_reserved_channels[i] = true;
            channel = i;
    if (channel == ADAFRUIT_RMT_CHANNEL_MAX)
        // Ran out of channels!
        return;
    // Match default TX config from ESP-IDF version 3.4
    rmt_config_t config = {
        .rmt_mode = RMT_MODE_TX,
        .channel = channel,
        .gpio_num = pin,
        .clk_div = 2,
        .mem_block_num = 1,
        .tx_config = {
            //.carrier_freq_hz = 38000,
            //.carrier_level = RMT_CARRIER_LEVEL_HIGH,
            .idle_level = RMT_IDLE_LEVEL_LOW,
            //.carrier_duty_percent = 33,
            .carrier_en = false,
            .loop_en = false,
            .idle_output_en = true,
    rmt_config(&config);
    rmt_driver_install(config.channel, 0, 0);
    // Convert NS timings to ticks
    uint32_t counter_clk_hz = 0;
    // this emulates the rmt_get_counter_clock() function from ESP-IDF 3.4
    if (RMT_LL_HW_BASE->conf_ch[config.channel].conf1.ref_always_on == RMT_BASECLK_REF)
        cout << "hello, world ref" << endl; // Say Hello
        //Serial.println("hello mate ref");
        uint32_t div_cnt = RMT_LL_HW_BASE->conf_ch[config.channel].conf0.div_cnt;
        uint32_t div = div_cnt == 0 ? 256 : div_cnt;
        counter_clk_hz = REF_CLK_FREQ / (div);
    else
        cout << "hello, world apb" << endl; // Say Hello
        //std:cout<<"hello mate apb"<<std<<endl;
        counter_clk_hz = APB_CLK_FREQ / (div);
    // NS to tick converter
    float ratio = (float)counter_clk_hz / 1e9;
    t0h_ticks = (uint32_t)(ratio * WS2812_T0H_NS);
    t0l_ticks = (uint32_t)(ratio * WS2812_T0L_NS);
    t1h_ticks = (uint32_t)(ratio * WS2812_T1H_NS);
    t1l_ticks = (uint32_t)(ratio * WS2812_T1L_NS);
    // Initialize automatic timing translator
    rmt_translator_init(config.channel, ws2812_rmt_adapter);
    // Write and wait to finish
    rmt_write_sample(config.channel, pixels, (size_t)numBytes, true);
    rmt_wait_tx_done(config.channel, pdMS_TO_TICKS(100));
    // Free channel again
    rmt_driver_uninstall(config.channel);
    rmt_reserved_channels[channel] = false;
    gpio_set_direction(pin, GPIO_MODE_OUTPUT);
In the esp_show function, the timings for t0h,t1h,t0l,t1l are being setup, but I cannot grasp how are they doing it...
Could someone please clarify this. Any help is appreciated
Users browsing this forum: No registered users and 257 guests
